TheAncientOne Posted March 14, 2008 Report Posted March 14, 2008 Updated - All Parts ArrivedIt will probably come in more than one batch, due to the usual stock problems, but I can now pad out the Digikey orders to get free postage for a reasonable number of orders.Does anyone need programmed AVRs?The attached text file is a list of the parts I am preparing to order. If you want to join in this order, download the text file attached, fill it in, and email to the adddress in the file As an Attachment. Put 'x0xb0x bulk parts order' in the subject line.Once I've done the sorting, I'l order and PayPal you once it has arrived.Remember that this is a contract to buy.If you can't do paypal, contact me first with an alternative.UpdateOrders for:Sashab-funkMTEkokiPsihoGoblinzasafnetzerTheProfKartoshkaJulian VoirinStatus:NKK switches arrived from FarnellMouser order #1 arrivedDigikey Order #1 arrivedMouser Order #2 ArrivedDigikey Order #2 ArrivedFarnell Order #2 ArrivedAll parts now in stock bar 1% resistors, (and only 2 people wanted them). I have a lot of accounting to do to match all the currencies, but I should be invoicing and dispatching from 22 of September.OrderForm02.txtOrderForm02.txt Quote
asafnetzer Posted March 14, 2008 Report Posted March 14, 2008 Hi Prof,Regarding the list, As Far as I know the x0xb0x need 3 of the panasonic detent type pots. (list has 1 as standard)Asaf Quote
ganchan Posted March 14, 2008 Report Posted March 14, 2008 Hi Prof,Regarding the list, As Far as I know the x0xb0x need 3 of the panasonic detent type pots. (list has 1 as standard)Asafdetent? not detent :) Quote
Kartoshka Posted March 14, 2008 Report Posted March 14, 2008 the x0xb0x need 3 of the panasonic detent type pots. (list has 1 as standard)from ladyada mods page:Detent Tuning knobWhen we designed the x0xb0x, we put in a non-detent tuning pot because that was what the original 303 had. However, this may drive you a little crazy. Panasonic part number P3I9503, an equivalent 50K linear potentiometer with a center detent, is available from DigiKey. Note that you may have to retune the synth once in a while to keep the center detent 'correct' 'Tuning' knob by default is coming without detent, but can be substituted by one with detent.P3I9503 POT 50K OHM 9MM VERT PLA BUSHING@mike: then, my guess, the list is missing 2 (or 3 if tuning not substituted) of 50K D log pots: P3L2503 POT 50K OHM 9MM VERT PLA BUSHINGand, USB B-type Jack is not in the list as well. i also need some minor 2 resistors which i couldn't find on futurlec Quote
TheAncientOne Posted March 15, 2008 Author Report Posted March 15, 2008 You are right. I will update the file when I get home (I'm on a friends machine here). I will assume anyone that has ordered pots on the old form wants a full set.Thanks for that, Two of us checked it and we still missed an item.I'll put the USB jack on as an option too. Quote
MTE Posted March 15, 2008 Report Posted March 15, 2008 Please cancel my order, Ill reorder and send you the list updated again, I can get the caps, usb-jack and some other things at reichelt ;)I hope this is OK for you and makes no trouble...EDIT : Can I use the standard WIMA-capacitors for the x0x ?EDIT 2 : Ok, I see now there isnt every cap available at Reichelt (no 18nf) :-\EDIT 3 : Order canceled and sent new one ;) Quote
TheAncientOne Posted March 17, 2008 Author Report Posted March 17, 2008 Quick thought - is is worth me getting the 1% resistors in bulk from my usual supplier. they work out at about £0.02 each. i.e. 1% resistor pack?Sheet will be updated soon. Quote
ganchan Posted March 17, 2008 Report Posted March 17, 2008 all x0x resistors or just the ladyada BOM suggested Prof? Quote
TheAncientOne Posted March 17, 2008 Author Report Posted March 17, 2008 The 1% ones on the LadyAda BOM - not the ones for the LED's, which you will need to adjust for which type of LED you have, and how bright you want them.I think everyone can get 5% basic resistors.. Quote
Sasha Posted March 17, 2008 Report Posted March 17, 2008 Mike, I really appreciate every help that you are offering here but i don`t believe it makes sense you bother with those resistors and common part like electrolytes. Everybody can find those locally and it is fairly inexpensive. It is not like we need 1000 of them for x0x. We need to shop some more common pars locally anyway so please dont complicate things for you very much. I really don`t expect you send us all the parts as we could expect from ladyada. Doing a Digikey and Mouser bulk and getting all rare parts is already almost as we are getting full kit. But suit yourself. I`m satisfied whatever you decide. Quote
Goblinz Posted March 17, 2008 Report Posted March 17, 2008 I wouldn't mind a pack of resistors/common bits. Componants seem to be very expensive in the UK so it would save a bit; I'm not sure if it would save people in other countries much though. Although it would be nice (and lazy!) to have a kit containing all(/most) of the componants arrive at my door, it would be a lot of work to make the kits up. Basically I'd be in for a couple of resistor sets, but please don't commit too much time for it if you're busy. G Quote
Sasha Posted March 17, 2008 Report Posted March 17, 2008 Lets not forget Mike offered to check 500pcs of 733`s for hfe so each of us gets even part of high gain trannies. I did it with 120pcs the other day and it wasn`t fun. ::) Quote
Kartoshka Posted March 17, 2008 Report Posted March 17, 2008 i have all the resistors and caps already, so i vote no. it was really easy to go thru the list and order them all from local supplier or a webshop, took me only one evening rechecking every part about 5 times. Quote
Kartoshka Posted April 15, 2008 Report Posted April 15, 2008 I have a q about resonators: on Mike's list there's a set of 2 resonators, 16 and 8 mhz. Limor advises to use 16 and 6Mhz.... i guess it's typo..? :-[ Quote
MTE Posted April 15, 2008 Report Posted April 15, 2008 Wow thats really bad typo....follow the x0x-page, it must be a 6-mhz-one ;) Quote
TheAncientOne Posted April 15, 2008 Author Report Posted April 15, 2008 You're right. Thanks folks. Funnily enough, in my master list here, it's 6MHz, (I was getting them from Rapid), but I misread the BOM spreadsheet, and thought it was an 8, when I typed out the parts list.I'll update the text file now.I've had a few things to sort out here, but I'll get this one 'back on the stove' properly, next week. Quote
Kartoshka Posted May 2, 2008 Report Posted May 2, 2008 :-[ not that i'm pushing... not that i'm getting impatient too, anyway will not touch soldering iron before late summer.just making sure we're not loosing interest in this thread. Quote
Goblinz Posted May 2, 2008 Report Posted May 2, 2008 No, still interested. Prof won't have forgotten about it. G Quote
ganchan Posted May 8, 2008 Report Posted May 8, 2008 CT3011-ND ENCODER 2 BIT QUAD SPST W/DETEN aviable on 06/04/2008the never ending story. :-\ Quote
Sasha Posted May 8, 2008 Report Posted May 8, 2008 Damn it. Last time I checked the pots and grayhill stock was pretty low too. So, we might be missing even more parts again.It really is neverending story. Quote
Kartoshka Posted May 8, 2008 Report Posted May 8, 2008 sure, and it always will be, that's the reason we need to place an order asap, LET THEM solve the stocking questions.note: i'm waiting for green light from Mike to send him my list. i know he's not participating in the forum for some solid reason - so i wait silently, and not shouting loud. :-[ Quote
Sasha Posted May 8, 2008 Report Posted May 8, 2008 I believe it is possible to hold the order until the all ordered parts be on stock and than ship it all together. Like this, we will never get those parts.It is absurd that getting all those rare parts is easier than those still in production. OK Mike had luck to get it for us from same supplier but I managed to get all the rare parts from few sources myself without much hassle. Quote
ganchan Posted May 9, 2008 Report Posted May 9, 2008 the reason is this, if you look at adafruit site, you see 1 day 30 stock pcb, the day after 10, than 0. ;Dseems that a new acid era it's coming..or it was never ended? :) Quote
opkod Posted May 9, 2008 Report Posted May 9, 2008 I've bought two of the last pcbs... until they will be availiable soon I think. They will continue to sell pcbs I think.... ;D Quote
