Goblinz Posted October 15, 2008 Posted October 15, 2008 No chips here just yet.Mind you, I do live all the way up here:That's the problem, your map is upside down, your chips are currently floating around in the Arctic Ocean.
lemonhorse Posted August 21, 2013 Posted August 21, 2013 I've tried *everything* with the chip - no noise. So whatever the other guys did - this specific chip we have does NOT make noise. Johnmx found a solution. Some Chips need a RESET after power on. MBAY V2.2 [bUILD 20130821] AY38912A/P & AY38912A/P from Microchip with Noise enabled. http://www.midibox.org/dokuwiki/doku.php?id=midibox_ay_ym_v2&#software But it takes a little modification: do add a RESET line (see: CS-Button & LED Config / 4xDOUT pin 31) http://www.midibox.org/dokuwiki/doku.php?id=midibox_ay_ym_v2&#hardware Best Regards, - Lemonhorse
