Lan (Ethernet) to Midi interface
I am looking for a hardware solution to play a pipe organ via LAN over a long distance.
Sending out Midi information from the computer over LAN is no problem, there are several good software solutions like Ipmidi, etc. But I did not find any kind of interface to convert the LAN signal back to midi, except the VERY expensive Ethermidi interface from Dmexx.  This little box is about 800$ !!
Any help is highly appreciated,
Thomas
Im no expert in this area, but maybe you could use a Microchip ENC28J60 chip..its a 28pin 10mbit ethernet controller with spi interface, so its very easy to control it with a PIC18 mcu (or others that support spi), and then use the PIC18 to output the midi signals.. :)
Just an idea tho..maybe the guru's inhere have a better suggestion :D
It would be really cool to have LAN MIDI hardware especially WiFi. I search the net from time to time in hope somebody will do it but haven`t got some luck by now.
OK now that it has been mentioned elsewhere, I can suggest that the new core module, not yet released and a long time away, may be well suited to this job...
no need to build a PC for that, any old computer(even a 468 can) with an ethernet, compatible ipmidi software and a midi system will do.
Wouldn't it be wonderful if an Amiga can do it ?.
