Audio Output Issue
napierzaza
Is this an electrical issue?
Well, I assume the audio cables that you're plugging into the mixer, are also connected to the MBFM? If so, it's an electrical issue; otherwise you have poltergeists.
I guess you made a soldering error on the MBFM, if this issue doesn't effect other synths. Time to grab your multimeter and a copy of the schematic....
You could use a DI box between your MB & Desk.. it sounds like some grounding issue to me.. like there is a voltage potential between your MB's ground, and your desks ground.. (For the hell of it, measure it with your multimeter)
http://www.wikirecording.org/DI_box
It will need to be fixed, but a DI or even an audio transormer could help for the mean time.
Regards
Mike
How could such a large ground difference happen though? I have them plugged into the exact same outlet. Would it be better if I connected my GND to my metal case? This in turn is connected to the GND of the outlet.
That could help, but because your MB is crashing when you connect it to something that is earthed, doing the above might just stop it from working..?
did you try, as smash said, reversing the audio outputs?
I'm still thinking it's something to do with the way you have wired up your power transformer.. triple check it's how it should be.. (Or are you running of a wall wart?)
Regards
Mike
No I have not tried that. Is this a good thing or a bad thing?
Also I am worried about grounding my +-12v power supply to my case, it's a Canakit where the middle gnd appears to be one of the AC lines. This does not seem kosher to me, but I have no idea about such a thing.
I can't find a picture, but will take on this evening, someone on this page recommended it. It doesn't require a center tap and it uses a 7912 and a 7812.
I can make one of my own if I have to, does anyone have a schematic? I have a transformer with two separate 15vAC and I have a single 24vAC I can use.
I want to get this thing working finally, I feel very lazy for not playing with the actual synth yet. Too much troubleshooting.
Also, would it be bad news if I applied power to the amps without the 5v being on?
...it's a Canakit where the middle gnd appears to be one of the AC lines. ...
i have little doubt that this is the source of your troubles.  it must be that you have the neutral ac line connected to ground in your circuit, which is in turn connected to the shield on your cables.  this is no good in general, and very bad if the outlet wiring has hot and neutral reversed (a common error)
if so, you should be able to break the connection between the ac side and your circuit ground at the psu...
and only the earth ac line (not neutral) should ever be connected to the chassis
...But I guess I still can't ground the common to the case?...
i wouldn't, but it might be difficult to avoid if you use metal jacks...
Also, if anyone does have a schematic for a bipolar circuit using either two transformers or a center-tap, I'm all ears.
they're all over the net.
here's a good one:
http://www.cgs.synth.net/modules/cgs14_psu.html
here's one in our own wiki:
http://www.midibox.org/dokuwiki/doku.php?id=bipolar_12v_psu
here's a better dual wave circuit:
http://www.musicfromouterspace.com/analogsynth/WALLWARTSUPPLY/WALLWARTSUPPLY.php
