15 LED Circular "Hi-Eff RED"
dstamand
I will order now 100 Peaces of Ledrings
does anybody have a library for a fitting on the market aviable Encoder with pusbutton?
I have finished the Ledring Library.
I have finished the Ledring shematic section.
I have not finished the Encoder shematic section. - have no library, or encoder type!
I have not finished the board layout! (have startet it....)
Here are all the Files...  ;)
ledring.rar
4310_doutshem_jpg9598ac58a6016e380f0a5db
4312_pcb_jpgbfe725593be3e2d97ea6de4730ca
ledring.rar
Link to comment
Share on other sites
  • Replies 59
  • Created
  • Last Reply
Top Posters In This Topic
your .0881 dim should be .079
Hm, I cant do this job... I dont know wtf they want from me in this fk datasheet ??? It seems to be all ok, but not the edge!
.If somebody would change (later for milling!!!!!)- that would very nice...All files..are includet in my last post....
Link to comment
I dont know is solid edge 3d, like 3d max?,
Can you export it in DXF DWG? so I can make a script SCR that I can use in Eagle, for making a library?
because I dont know the idges and step format...normally I work with autocard (day by day :)) and eagle...a little bit 3dmax...but 3d max i have not @ home.
Link to comment
With the ledrings, i want to use my Soundwell encoders that i bought last year, i have 100 of them and my P-401 Knobs that i bought from Nebula but it requires an extension for the encoder shaft, the female side of the extension use a set screw to lock on the shaft. Without the shaft extension, the knobs not enough tight and became loose fast because to short shaft. Here's how i did it. See attachment.
4389_idea-2_jpeg5cf2381e2ca49573b791f070
4391_idea-cut-2_jpegbe0a2178f47064238a21
Link to comment
Hmmm I have got today this mail:
> Attached is order# W910951. I just want to let you know Production  make a
> re-count in our inventory and find out we have only 93pcs in stock.
> the lead time at this moment is 4-6 weeks. If you want me to ship 93pcs.
> and cancel the 7pcs. due to the lead time, please let me know and I will
> ship 93pcs only. Please advised.
what should I do? wait?
Link to comment
Guest
Reply to this topic...
