JargMarbin Posted May 5, 2009 Posted May 5, 2009 I'm currently in the process of exploring my options for a bipolar power supply capable of delivering +12v and -12v for my MIDIbox CV project. I've never built one before, and I don't want to work with anything dangerous. I found the following kit:http://www.paia.com/proddetail.asp?prod=9770R-12Would this kit work? How much does it cost to build one?
lylehaze Posted May 6, 2009 Posted May 6, 2009 From the photo and link you posted, it looks like a fairly standard bipolar supply.They appear to be using 7812 and 7912 regulators, and a wall transformer that is capable of about 300ma.Would this kit work? If you need + and - 12 volts at 300 ma or less, yes.However, you'll probably need a separate power connection for the core +5 volts. I have not looked over the CV project too closely, but I assume it has a core, and maybe a display too?If you choose a transformer with larger current capacity, you could power everything off of it, including this board. Most bipolar (positive and negative) supplies require a center tapped secondary on the transformer.How much does it cost to build one? The link you provided says :Price: $41.45 and I don't want to work with anything dangerous.Then avoid nILS.No, seriously.. PAiA have a good reputation. I think $41 is a bit expensive, but I'm sure the product will do what it claims to do.Have Fun,LyleHaze
nILS Posted May 6, 2009 Posted May 6, 2009 Then avoid nILS.;) I am not dangerous. And I never do dangerous stuff like mod tubeamps or the likes ;D
Soclt Posted May 11, 2009 Posted May 11, 2009 I have made 3 different power supplies (+5V, +15V, -15V) using MC34063A. -15V from +12V gives up to 150mA current. Read datasheet for more information, the schematic is really small, I could draw it later if someone needs.
