rasteri Posted September 8, 2009 Posted September 8, 2009 You guys seen these?http://www.austriamicrosystems.com/eng/Products/Magnetic-EncodersLooks like you basically dangle a magnet above them and they give you the absolute angle over a serial interface. I got some samples, I'll let you know how they turn out.
Soclt Posted September 12, 2009 Posted September 12, 2009 I have ordered some samples too. Not only in serial interface. There are some with normal interface for quadrature outputs.
spongebob Posted September 30, 2009 Posted September 30, 2009 rasteri, Soclt, there are any news?I have ordered samples (AS5035) too.But I don't know what to do this them :)
Phattline Posted October 12, 2009 Posted October 12, 2009 the mainly question is where to get the magnet for that... and whats the priceing for that....5$ are a bit to much for peace of silicium :o , if this would be cheaper then a mechanical encoder ;) - i would start to thinking of cnc designes for axis, shafts and so on... but with 5$ i dont start to think about that...
SLP Posted October 12, 2009 Posted October 12, 2009 the mainly question is where to get the magnet for that... and whats the priceing for that....5$ are a bit to much for peace of silicium :o , if this would be cheaper then a mechanical encoder ;) - i would start to thinking of cnc designes for axis, shafts and so on... but with 5$ i dont start to think about that...http://www.magnetportal.de/small magnets (cheap!) and BIG (!!!) magnets
Phattline Posted October 13, 2009 Posted October 13, 2009 :D you may need a tiny tiny tiny magnet... because, you have to put many of this tiny tiny magnets on a tiny tiny disc...and because you need a better resolution then, one step by one turn :Por you could take a magnet disc, and the take magnetic shielding stuff (What ever this is) that is easy to drill with a cnc, and then drill isolation areas in the stuff........ it then may look like a disc from a optical encoder.... then you put the shield-disc on the magnet-disc, and so on......... oh man too komplex...
Screaming_Rabbit Posted October 14, 2009 Posted October 14, 2009 :D you may need a tiny tiny tiny magnet... because, you have to put many of this tiny tiny magnets on a tiny tiny disc...and because you need a better resolution then, one step by one turn :Por you could take a magnet disc, and the take magnetic shielding stuff (What ever this is) that is easy to drill with a cnc, and then drill isolation areas in the stuff........ it then may look like a disc from a optical encoder.... then you put the shield-disc on the magnet-disc, and so on......... oh man too komplex...It needs one radial polarized magnet in the center of the encoder spindle. The encoder works "analog", with hall elements and proximity ratio.Greets, Roger
lemathos Posted April 13, 2010 Posted April 13, 2010 Any one have some news or make some test with this encoders ?
rasteri Posted May 12, 2010 Author Posted May 12, 2010 Any one have some news or make some test with this encoders ? Yeah they work great - so much better than optical encoders, and it makes positioning far more simple.
Phattline Posted January 10, 2011 Posted January 10, 2011 If I want to use this things to replace the encoders from Midibox 64e, what things I have to change - or better: is it possible... If I take this: http://www.austriamicrosystems.com/eng/Products/Magnetic-Encoders/Linear-Encoders/AS5510 that costs 0,6 Dollar @ 1000 Pieces - and work with the IIC Bus (128 encoders then maximum?! per core) I know there is a Mios IIC driver out there. And If it works with the Software (Midibox 64e), the next question is, how to connect them together, is it wrigt that i simply connect all IIC Chips on one Line (2/3Wire) like this: http://www.totalphase.com/image/docs/beagle_datasheet/i2c-01.png What problems can accour?
Imp Posted January 10, 2011 Posted January 10, 2011 This chip has a ball package, which means, you have to solder tiny contacts between chip and pcb. It might be possible to do at home, but i wouldn't recommend...
Phattline Posted January 10, 2011 Posted January 10, 2011 ahh ok thankz --- the others cost more then 2,64$ that is too much....
