dreamer Posted September 11, 2009 Posted September 11, 2009 Hello all,I was wondering if there is a way to play SID tunes over midi on the MB6582. I would love to hear those tunes again. Before the stereo sid the old SID project was able to do this with a buggy program, but it worked. I was just wondering if the same is possible with the stereo SID?Grtz
Wilba Posted September 11, 2009 Posted September 11, 2009 yes... MB-SID app can play SID tunes just like a SidStation... you have to use the ASID XP program with Windows.You can find ASID XP here: http://www.elektron.se/support/
dreamer Posted September 12, 2009 Author Posted September 12, 2009 If i can remember correct, you needed to install application called sid-play (or something like that) then i could connect with asid-xp player on the pc. But that was for sid V1. I don't know if that's possible on SID V2.
TK. Posted September 12, 2009 Posted September 12, 2009 The SID Player is integrated into the MIDIbox SID V2 firmware. It will start automatically once ASID sends the SysEx stream.Best Regards, Thorsten.
dreamer Posted September 16, 2009 Author Posted September 16, 2009 :o no kidding. super!! thanks. Will try it right away :D
Smithy Posted August 27, 2010 Posted August 27, 2010 (edited) I've only now spotted that an updated version of ASID XP came out in December 2009. Current version is now 1.02. http://www.elektron.se/products/sidstation One sid in paticular that was problematic on the older version was track 3 of Target Renegade.sid. It now plays fine with no issues, but still no perfect last ninja 2 playback. :( It should now have better compatibility with certain sid files at least. :) Edited August 27, 2010 by Smithy
dreamer Posted August 27, 2010 Author Posted August 27, 2010 Too bad that asid xp is still very buggy. But also there is nothing out that does the same like asid xp. Maybe some c++ guru here can make a nice program?? (hope, hope) grtz
nILS Posted August 29, 2010 Posted August 29, 2010 Too bad that asid xp is still very buggy. But also there is nothing out that does the same like asid xp. Not quite true. If you poke around the forum a bit you'll find a thread called "Another way to play .sid tunes" (or sth similar). IIRC there's some info on another tool/way of playing sid files :)
wintermute Posted September 23, 2010 Posted September 23, 2010 Is there a way to use my old v1.72 SIDbox to play SID files without uploading the software again and again every time I want to listen to SIDs :(. It would be great to see an option when starting the SIDbox where one can select the SIDplayer or the MIDI SIDbox software. Can this be done or are there any restrictions in design that make it impossible to implement such an option?
nILS Posted September 23, 2010 Posted September 23, 2010 are there any restrictions in design that make it impossible to implement such an option? Yes. Upgrade to v2 (which does exactly that) or keep uploading the apps to your outdated and unmaintained v1.
TK. Posted September 23, 2010 Posted September 23, 2010 Can this be done or are there any restrictions in design that make it impossible to implement such an option? There isn't enough free memory in the PIC18F452 to add the code for the SID player. This was one of the reasons why I started with V2 on a new PIC Here the update instructions: http://www.ucapps.de/midibox_sid_manual_up.html Best Regards, Thorsten.
