protofuse Posted September 25, 2009 Report Posted September 25, 2009 (edited) hello, fortunately, I built my common anode matrix rgb led driver (THANKS TO LUCEM who detailed me all the process, and made me understand!) - row (anodes) driver is SR + resistor 1k + transistor BC547 used as a switch to source 5V to rows.. - column (cathodes) driver is 3 ULN to sink current + 3 SR. (3 = one for each color) I have a little problem now with the code (only the code, I guess) When I basically turn pins high in Init(), it works very fine ! But the process has to be done in ISR via SR_Service_Prepare() when I do that, no led are up... 1st SR is for ROW driver 2, 3, 4th are for RBG color COLUMN driver here are the code involved: ///////////////////////////////////////////////////////////////////////////// // Include files ///////////////////////////////////////////////////////////////////////////// #include <cmios.h> #include <pic18fregs.h> #include <protodeck.h> #include "main.h" ///////////////////////////////////////////////////////////////////////////// // Global variables ///////////////////////////////////////////////////////////////////////////// // status of application (see bitfield declaration in main.h) app_flags_t app_flags; ///////////////////////////////////////////////////////////////////////////// // Local variables ///////////////////////////////////////////////////////////////////////////// // last ain/din/dout unsigned char last_ain_pin; unsigned char last_din_pin; unsigned char last_dout_pin; // we create a 2-dimensional array with 23 entries for mapping between potentiometers movements & events associated // each entry consists of two bytes: // o one for the first MIDI byte (MIDI status) => 0xb* means CC message for Channel * // o a second for the second MIDI byte (=> CC number) // The meaning of the bytes can be found in the MIDI spec // (-> http://www.harmony-central.com/MIDI/Doc/table1.html) // (-> http://www.harmony-central.com/MIDI/Doc/table2.html) // (-> http://www.harmony-central.com/MIDI/Doc/table3.html) const unsigned char pot_event_map[23][2] = { //AIN 11 // Pots 1-12 = drums controls pots => channel 10 {0xb9, 0x01}, {0xb9, 0x02}, {0xb9, 0x03}, {0xb9, 0x04}, {0xb9, 0x05}, {0xb9, 0x06}, {0xb9, 0x07}, {0xb9, 0x08}, {0xb9, 0x09}, {0xb9, 0x0A}, {0xb9, 0x0B}, {0xb9, 0x0C}, // Pots 13-18 = EQ = channel 16 {0xbF, 0x01}, {0xbF, 0x02}, {0xbF, 0x03}, {0xbF, 0x04}, {0xbF, 0x05}, {0xbF, 0x06}, // Pot 19 = Master Volume = channel 16 {0xbF, 0x07}, // Pots 20-23 = multifunctionnal purpose pots = channel 16 {0xbF, 0x08}, {0xbF, 0x09}, {0xbF, 0x10}, {0xbF, 0x0A}, }; // we create a 2-dimensional array with 64 entries for mapping between switches push & events associated // each entry consists of two bytes: // o one for the first MIDI byte (MIDI status) => 0x9* means Note message for Channel * // o a second for the second MIDI byte (=> Note number) // This const is parsed lower by void DIN_NotifyToggle() // The meaning of the bytes can be found in the MIDI spec // (-> http://www.harmony-central.com/MIDI/Doc/table1.html) // (-> http://www.harmony-central.com/MIDI/Doc/table2.html) // (-> http://www.harmony-central.com/MIDI/Doc/table3.html) const unsigned char button_event_map[64][2] = { //------- clip matrix control //-------- DIN11 // Buttons 1-8 = tracks mute = channel 1-8 {0x90, 0x01}, {0x91, 0x01}, {0x92, 0x01}, {0x93, 0x01}, {0x94, 0x01}, {0x95, 0x01}, {0x96, 0x01}, {0x97, 0x01}, // Buttons scenes 1 = 9-16 = channel 1-8 {0x90, 0x02}, {0x91, 0x02}, {0x92, 0x02}, {0x93, 0x02}, {0x94, 0x02}, {0x95, 0x02}, {0x96, 0x02}, {0x97, 0x02}, // Buttons scenes 2 = 17-24 = channel 1-8 {0x90, 0x03}, {0x91, 0x03}, {0x92, 0x03}, {0x93, 0x03}, {0x94, 0x03}, {0x95, 0x03}, {0x96, 0x03}, {0x97, 0x03}, // Buttons scenes 3 = 25-32 = channel 1-8 {0x90, 0x04}, {0x91, 0x04}, {0x92, 0x04}, {0x93, 0x04}, {0x94, 0x04}, {0x95, 0x04}, {0x96, 0x04}, {0x97, 0x04}, //-------- DIN12 // Buttons scenes 4 = 33-40 = channel 1-8 {0x90, 0x05}, {0x91, 0x05}, {0x92, 0x05}, {0x93, 0x05}, {0x94, 0x05}, {0x95, 0x05}, {0x96, 0x05}, {0x97, 0x05}, // Buttons scenes 5 = 41-48 = channel 1-8 {0x90, 0x06}, {0x91, 0x06}, {0x92, 0x06}, {0x93, 0x06}, {0x94, 0x06}, {0x95, 0x06}, {0x96, 0x06}, {0x97, 0x06}, // Buttons scenes 6 = 49-56 = channel 1-8 {0x90, 0x07}, {0x91, 0x07}, {0x92, 0x07}, {0x93, 0x07}, {0x94, 0x07}, {0x95, 0x07}, {0x96, 0x07}, {0x97, 0x07}, // Buttons scenes control = 57-62 = CHANNEL 16 {0x9F, 0x01}, {0x9F, 0x02}, {0x9F, 0x03}, {0x9F, 0x04}, {0x9F, 0x05}, {0x9F, 0x06}, // Buttons offset control = 63,64 = CHANNEL 16 {0x9F, 0x07}, {0x9F, 0x08} }; static unsigned int clipButtons[8] = { 0,0,0,0,0,0,0,0 }; // we create a 2-dimensional array with 64 entries for led color storage for the clip matrix controller part // each entry consists of 1 byte coded like that: // 0x00 = OFF // 0x10 = RED // 0x20 = GREEN // 0x40 = BLUE // 0x30 = RED + GREEN = YELLOW // 0x60= GREEN + BLUE = CYAN // 0x50 = RED + BLUE = MAGENTA // 0x70 = WHITE // The meaning of the bytes can be found in the MIDI spec // (-> http://www.harmony-central.com/MIDI/Doc/table1.html) // (-> http://www.harmony-central.com/MIDI/Doc/table2.html) // (-> http://www.harmony-central.com/MIDI/Doc/table3.html) // // structure is matrix[ROW][COLUMN]=COLOR static unsigned char matrix[8][8] = { {0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10}, {0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20}, {0x30,0x30,0x30,0x30,0x30,0x30,0x30,0x30}, {0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40}, {0x50,0x50,0x50,0x50,0x50,0x50,0x50,0x50}, {0x60,0x60,0x60,0x60,0x60,0x60,0x60,0x60}, {0x70,0x70,0x70,0x70,0x70,0x70,0x70,0x70}, {0x00,0x30,0x00,0x50,0x00,0x70,0x00,0x00} }; ///////////////////////////////////////////////////////////////////////////// // This function is called by MIOS after startup to initialize the // application ///////////////////////////////////////////////////////////////////////////// void Init(void) __wparam { // configure the core1 as midibox-link FORWARD Point // see infos about midibox-link here: http://www.ucapps.de/midibox_link.html MIOS_MIDI_MergerSet(MIOS_MIDI_MERGER_MBLINK_EP); // set shift register update frequency MIOS_SRIO_UpdateFrqSet(1); // ms // we need to set at least one IO shift register pair MIOS_SRIO_NumberSet(NUMBER_OF_SRIO); // debouncing value for DINs MIOS_SRIO_DebounceSet(DIN_DEBOUNCE_VALUE); MIOS_SRIO_TS_SensitivitySet(DIN_TS_SENSITIVITY); // initialize the AIN driver MIOS_AIN_NumberSet(AIN_NUMBER_INPUTS); #if AIN_MUXED_MODE MIOS_AIN_Muxed(); #else MIOS_AIN_UnMuxed(); #endif MIOS_AIN_DeadbandSet(AIN_DEADBAND); // all pin of row driver low MIOS_DOUT_SRSet(0, 0); } ///////////////////////////////////////////////////////////////////////////// // This function is called by MIOS in the mainloop when nothing else is to do ///////////////////////////////////////////////////////////////////////////// void Tick(void) __wparam { } ///////////////////////////////////////////////////////////////////////////// // This function is periodically called by MIOS. The frequency has to be // initialized with MIOS_Timer_Set ///////////////////////////////////////////////////////////////////////////// void Timer(void) __wparam { } ////////////////////////////////////////////////////////////////////////////// // This function is called by MIOS when the display content should be // initialized. Thats the case during startup and after a temporary message // has been printed on the screen ///////////////////////////////////////////////////////////////////////////// void DISPLAY_Init(void) __wparam { // clear screen MIOS_LCD_Clear(); // print static messages MIOS_LCD_CursorSet(0x00); // first line MIOS_LCD_PrintCString("1AIN DIN DOUT"); MIOS_LCD_CursorSet(0x40); // second line MIOS_LCD_PrintCString("xx:xxx xxxx xxxx"); // request display update app_flags.DISPLAY_UPDATE_REQ = 1; } ///////////////////////////////////////////////////////////////////////////// // This function is called in the mainloop when no temporary message is shown // on screen. Print the realtime messages here ///////////////////////////////////////////////////////////////////////////// void DISPLAY_Tick(void) __wparam { // do nothing if no update has been requested if( !app_flags.DISPLAY_UPDATE_REQ ) return; // clear request app_flags.DISPLAY_UPDATE_REQ = 0; // print status of AIN MIOS_LCD_CursorSet(0x40 + 0); MIOS_LCD_PrintBCD2(last_ain_pin + 1); MIOS_LCD_PrintChar(':'); MIOS_LCD_PrintBCD3(MIOS_AIN_Pin7bitGet(last_ain_pin)); // print status of DIN MIOS_LCD_CursorSet(0x40 + 7); MIOS_LCD_PrintBCD3(last_din_pin + 1); MIOS_LCD_PrintChar(MIOS_DIN_PinGet(last_din_pin) ? 'o' : '*'); // print status of DOUT MIOS_LCD_CursorSet(0x40 + 12); MIOS_LCD_PrintBCD3(last_dout_pin + 1); MIOS_LCD_PrintChar(MIOS_DOUT_PinGet(last_dout_pin) ? '*' : 'o'); } ///////////////////////////////////////////////////////////////////////////// // This function is called by MIOS when a MIDI byte has been received ///////////////////////////////////////////////////////////////////////////// void MPROC_NotifyReceivedByte(unsigned char byte) __wparam { } ///////////////////////////////////////////////////////////////////////////// // This function is called by MIOS when a complete MIDI event has been received ///////////////////////////////////////////////////////////////////////////// void MPROC_NotifyReceivedEvnt(unsigned char evnt0, unsigned char evnt1, unsigned char evnt2) __wparam { int channelIndex = evnt0; int noteIndex = evnt1; unsigned char value = evnt2; // _COLOR_OFF 0x00 00000000 // _COLOR_RED 0x10 00010000 // _COLOR_GREEN 0x20 00100000 // _COLOR_BLUE 0x40 01000000 // _COLOR_CYAN 0x60 01100000 // _COLOR_MAGENTA 0x50 01010000 // _COLOR_YELLOW 0x30 00110000 // _COLOR_WHITE 0x70 01110000 /*if (channelIndex >= 0 && channelIndex < 8) { if ( noteIndex > _NOTE_RECEIVE_OFFSET && noteIndex < _NOTE_RECEIVE_OFFSET +8 ) { matrix[noteIndex-_NOTE_RECEIVE_OFFSET][channelIndex] = value ; } }*/ } ///////////////////////////////////////////////////////////////////////////// // This function is called by MIOS when a MIDI event has been received // which has been specified in the MIOS_MPROC_EVENT_TABLE ///////////////////////////////////////////////////////////////////////////// void MPROC_NotifyFoundEvent(unsigned entry, unsigned char evnt0, unsigned char evnt1, unsigned char evnt2) __wparam { } ///////////////////////////////////////////////////////////////////////////// // This function is called by MIOS when a MIDI event has not been completly // received within 2 seconds ///////////////////////////////////////////////////////////////////////////// void MPROC_NotifyTimeout(void) __wparam { } void DisplayLED(unsigned char column, unsigned char color) __wparam { color >>= 4; MIOS_DOUT_PinSet(column+8, (color & 0x01)); // RED color >>= 1; MIOS_DOUT_PinSet(column+8+8, (color & 0x01)); // BLUE color >>= 1; MIOS_DOUT_PinSet(column+8+8+8, (color & 0x01)); // GREEN } ///////////////////////////////////////////////////////////////////////////// // This function is called by MIOS before the shift register are loaded ///////////////////////////////////////////////////////////////////////////// void SR_Service_Prepare(void) __wparam { // HELPED BY BUGFIGHT => http://www.midibox.org/forum/index.php/topic,12786.0.html static unsigned char row; static unsigned char lastrow; unsigned int x; row = ++row & 0x07; // 8 cycle = 6.25% duty cycle MIOS_DOUT_PinSet0(lastrow); // row driver pin of last row on pulled OFF MIOS_DOUT_PinSet1(row); // row driver pin #row ON for (x = 0; x < 8; x++) { DisplayLED(x , matrix[row][x]); // for the row row, cycle all column } lastrow = row; } ///////////////////////////////////////////////////////////////////////////// // This function is called by MIOS after the shift register have been loaded ///////////////////////////////////////////////////////////////////////////// void SR_Service_Finish(void) __wparam { } ///////////////////////////////////////////////////////////////////////////// // This function is called by MIOS when an button has been toggled // pin_value is 1 when button released, and 0 when button pressed ///////////////////////////////////////////////////////////////////////////// void DIN_NotifyToggle(unsigned char pin, unsigned char pin_value) __wparam { // a button has been pressed, send Note at channel 1 // MIOS_MIDI_BeginStream(); // MIOS_MIDI_TxBufferPut(0x90); // Note at channel 1 // MIOS_MIDI_TxBufferPut(pin); // pin number corresponds to note number // MIOS_MIDI_TxBufferPut(pin_value ? 0x00 : 0x7f); // buttons are high-active // MIOS_MIDI_EndStream(); unsigned char channel; unsigned char note; channel = button_event_map[pin][0]; note = button_event_map[pin][1]; if (pin_value == 0) { if (clipButtons[channel] != 0) { return; } clipButtons[channel] = 1; } else { clipButtons[channel] = 0; } MIOS_MIDI_BeginStream(); MIOS_MIDI_TxBufferPut(channel); // first value from table = CHANNEL MIOS_MIDI_TxBufferPut(note); // second value from table = NOTE MIOS_MIDI_TxBufferPut(pin_value ? 0x00 : 0x7f); // 1 MIOS_MIDI_EndStream(); // notify display handler in DISPLAY_Tick() that DIN value has changed last_din_pin = pin; app_flags.DISPLAY_UPDATE_REQ = 1; } ///////////////////////////////////////////////////////////////////////////// // This function is called by MIOS when an encoder has been moved // incrementer is positive when encoder has been turned clockwise, else // it is negative ///////////////////////////////////////////////////////////////////////////// void ENC_NotifyChange(unsigned char encoder, char incrementer) __wparam { } ///////////////////////////////////////////////////////////////////////////// // This function is called by MIOS when a pot has been moved ///////////////////////////////////////////////////////////////////////////// void AIN_NotifyChange(unsigned char pin, unsigned int pin_value) __wparam { // // a pot has been moved, send CC#<pin-number> at channel 1 // MIOS_MIDI_BeginStream(); // MIOS_MIDI_TxBufferPut(0xb0); // CC at channel 1 // MIOS_MIDI_TxBufferPut(pin); // pin number corresponds to CC number // MIOS_MIDI_TxBufferPut(MIOS_AIN_Pin7bitGet(pin)); // don't send 10bit pin_value, but 7bit value // MIOS_MIDI_EndStream(); // send mapped CC value MIOS_MIDI_BeginStream(); MIOS_MIDI_TxBufferPut(pot_event_map[pin][0]); // first value from table MIOS_MIDI_TxBufferPut(pot_event_map[pin][1]); // second value from table MIOS_MIDI_TxBufferPut(MIOS_AIN_Pin7bitGet(pin)); // 7bit pot value MIOS_MIDI_EndStream(); // notify display handler in DISPLAY_Tick() that AIN value has changed last_ain_pin = pin; app_flags.DISPLAY_UPDATE_REQ = 1; } void ClearMatrix(void) __wparam { unsigned int column = 0; unsigned int row = 0; for (row = 0; row < 8; row++) { for (column = 0; column < 8; column++) { matrix[row][column] = _COLOR_OFF; } } } Indeed, it is the same code used by noofny/mike with his common cathode matrix. but the hardware matches this code too, no? if someone could help me . . . :) Edited November 10, 2009 by protofuse 1
protofuse Posted September 26, 2009 Author Report Posted September 26, 2009 I retested.1) I tried 10ms and this code: a static light pattern for the led.I only post Init() and SR_Service_Prepare() :void Init(void) __wparam { // configure the core1 as midibox-link FORWARD Point // see infos about midibox-link here: http://www.ucapps.de/midibox_link.html MIOS_MIDI_MergerSet(MIOS_MIDI_MERGER_MBLINK_EP); // set shift register update frequency MIOS_SRIO_UpdateFrqSet(10); // ms // we need to set at least one IO shift register pair MIOS_SRIO_NumberSet(NUMBER_OF_SRIO); // debouncing value for DINs MIOS_SRIO_DebounceSet(DIN_DEBOUNCE_VALUE); MIOS_SRIO_TS_SensitivitySet(DIN_TS_SENSITIVITY); // initialize the AIN driver MIOS_AIN_NumberSet(AIN_NUMBER_INPUTS); #if AIN_MUXED_MODE MIOS_AIN_Muxed(); #else MIOS_AIN_UnMuxed(); #endif MIOS_AIN_DeadbandSet(AIN_DEADBAND); // all pin of row driver low MIOS_DOUT_SRSet(0, 0); MIOS_DOUT_SRSet(1, 0); MIOS_DOUT_SRSet(2, 0); MIOS_DOUT_SRSet(3, 0); } void SR_Service_Prepare(void) __wparam { MIOS_DOUT_PinSet(2+8, 0x01); MIOS_DOUT_PinSet(2+8+8, 0x01); MIOS_DOUT_PinSet(2+8+8+8,0x01); MIOS_DOUT_PinSet(7+8, 0x00); MIOS_DOUT_PinSet(7+8+8, 0x01); MIOS_DOUT_PinSet(7+8+8+8,0x01); }ok it works!no cycle, all hardcoded.2) the same light pattern in init() and not in ISRit works too.but the code posted in the first post doesn't work anymoreany ideas?even with update SR refresh is 1ms or 10ms ... etc.. all the same.
protofuse Posted September 26, 2009 Author Report Posted September 26, 2009 with the following code, it works fine and fast (no flickering...etc) void DisplayLED(unsigned char column, unsigned char color) __wparam { color >>= 4; MIOS_DOUT_PinSet(column+8, (color & 0x01)); // RED color >>= 1; MIOS_DOUT_PinSet(column+8+8, (color & 0x01)); // BLUE color >>= 1; MIOS_DOUT_PinSet(column+8+8+8, (color & 0x01)); // GREEN } ///////////////////////////////////////////////////////////////////////////// // This function is called by MIOS before the shift register are loaded ///////////////////////////////////////////////////////////////////////////// void SR_Service_Prepare(void) __wparam { // HELPED BY BUGFIGHT => http://www.midibox.org/forum/index.php/topic,12786.0.html static unsigned char row; static unsigned char lastrow; unsigned int x; row = ++row & 0x07; // 8 cycle = 6.25% duty cycle //MIOS_DOUT_SRSet(0, 0); MIOS_DOUT_PinSet0(lastrow); // lastrow ON made OFF MIOS_DOUT_PinSet1(row); // row driver pin #row ON for (x = 0; x < 8; x++) { //DisplayLED(x , matrix[row][x]); // for the row row, cycle of all column MIOS_DOUT_PinSet(x+8+8, 0x01); MIOS_DOUT_PinSet(x+8+8+8,0x01); } lastrow = row; } So I guess the problem comes from the DisplayLED() parser. Indeed, in the ISR, I'm calling this function to parse the following "lookup table" : // we create a 2-dimensional array with 64 entries for led color storage for the clip matrix controller part // each entry consists of 1 byte coded like that: // 0x00 = OFF // 0x10 = RED // 0x20 = GREEN // 0x40 = BLUE // 0x30 = RED + GREEN = YELLOW // 0x60= GREEN + BLUE = CYAN // 0x50 = RED + BLUE = MAGENTA // 0x70 = WHITE // The meaning of the bytes can be found in the MIDI spec // (-> http://www.harmony-central.com/MIDI/Doc/table1.html) // (-> http://www.harmony-central.com/MIDI/Doc/table2.html) // (-> http://www.harmony-central.com/MIDI/Doc/table3.html) // // structure is matrix[ROW][COLUMN]=COLOR static unsigned char matrix[8][8] = { {0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10}, {0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20}, {0x30,0x30,0x30,0x30,0x30,0x30,0x30,0x30}, {0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40}, {0x50,0x50,0x50,0x50,0x50,0x50,0x50,0x50}, {0x60,0x60,0x60,0x60,0x60,0x60,0x60,0x60}, {0x70,0x70,0x70,0x70,0x70,0x70,0x70,0x70}, {0x00,0x30,0x00,0x50,0x00,0x70,0x00,0x00} };unsigned char isn't probably the good type... am I right?the result of (color & 0x01) seems to be 0 everytime ...(or something ^= 1) (where color = an element of the matrix[][] lookup table.if someone could guide me, it would be very appreciated :)
WickedBlade Posted September 26, 2009 Report Posted September 26, 2009 I don't know exactly what you're trying to achieve with this code, but it is quite certain that it can't work, since you're doing basically 0xn0 & 1 (where n i a number between 0 and F), and this is always equal to 0. In my opinion, the problem is not the type (unsigned char), which is quite fine, but either the values in your matrix or the "& 1" operation you're applying.(to understand better this "0xn0 & 1" thing, consider that doing "& 1" is asking if the number is odd -impair in french-, and you're asking this of a number that is a multiple of 16, so no, it's never odd)
protofuse Posted September 26, 2009 Author Report Posted September 26, 2009 could you explain me why the code equals always 0?0x10>>4 = 11&0x01 = ..... 1 no?so for 0x10 it equals 1 for the red component....
WickedBlade Posted September 26, 2009 Report Posted September 26, 2009 My mistake, I hadn't noticed the shifting.So I guess the code does pretty much what you say, i.e. you get 1 for every other row in your matrix.Arrays of arrays are always a pain to manage. Could it be that you're accessing it wrongly? Have you tried inverting the elements and calling this instead?DisplayLED(x , matrix[x][row]);
protofuse Posted September 26, 2009 Author Report Posted September 26, 2009 array is 8x8so inverted or normal are the same thing (I mean, it cannot cause an error with a outbounds or something like that!)
protofuse Posted September 27, 2009 Author Report Posted September 27, 2009 unfortunately, I don't have any 18F452 to test if it is a processor type problem (it would be weird but when we test, we have to test ALL)PROBLEM DATA- I have a Lookup Table (LUT) which I convert to 1-dimension (C ansi only specifies that and multi-dimensional array are weird - thanks lucem to be my spiritual code guide) // 0x00 = OFF // 0x10 = RED // 0x20 = GREEN // 0x40 = BLUE // 0x30 = RED + GREEN = YELLOW // 0x60= GREEN + BLUE = CYAN // 0x50 = RED + BLUE = MAGENTA // 0x70 = WHITE static unsigned char matrix[64] = { 0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10, 0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20, 0x30,0x30,0x30,0x30,0x30,0x30,0x30,0x30, 0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40, 0x50,0x50,0x50,0x50,0x50,0x50,0x50,0x50, 0x60,0x60,0x60,0x60,0x60,0x60,0x60,0x60, 0x70,0x70,0x70,0x70,0x70,0x70,0x70,0x70, 0x00,0x30,0x00,0x50,0x00,0x70,0x00,0x00 }; - I have a function to parse this LUT : DisplayLED() void DisplayLED(unsigned char column, unsigned char color) __wparam { color >>= 4; MIOS_DOUT_PinSet(column+8,(color & 0x01)); // RED color >>= 1; MIOS_DOUT_PinSet(column+8+8,(color & 0x01)); // BLUE color >>= 1; MIOS_DOUT_PinSet(column+8+8+8,(color & 0x01)); // GREEN } - I have a SR_Service_Prepare() that called cyclically the LUT parser: void SR_Service_Prepare(void) __wparam { // HELPED BY BUGFIGHT => http://www.midibox.org/forum/index.php/topic,12786.0.html static unsigned char row; static unsigned char lastrow; unsigned int x; row = ++row & 0x07; // 8 cycle = 6.25% duty cycle MIOS_DOUT_PinSet0(lastrow); // lastrow OFF MIOS_DOUT_PinSet1(row); // current row ON for (x = 0; x < 8; x++) { DisplayLED(x , matrix[x+row*8]); // for the row row, cycle of all column } lastrow = row; }TEST RESULTSthis code doesn't light up any led.if I replace DisplayLED(x , matrix[x+row*8]); in the ISR by DisplayLED(x , 0x10);, all the matrix is RED, without any flickering, and it is beautiful :)Of course, if I replace it by 0x20, or 0x50 etc ... it works fine with the correct color !CONCLUSIONthe LUT parser doesn't work and I really don't know why !!!I have no warning at the compilation state. nothing strange appears.I tried to force unsigned char cast but it is all the same.Is it a function call problem? a type problem? a curse problem ? ;)How could I make it working?I add one question:should I recompile the 18F4620 libs for sdcc ?
lylehaze Posted September 27, 2009 Report Posted September 27, 2009 common anode matrix rgb led driver ...- row (anodes) driver is SR + resistor 1k + transistor BC547 used as a switch to source 5V to rows..OK, so I have no time to read the code, and I'm feeling more like a hardware guy this week anyway.But the above statement has a problem..A "common anode" LED matrix requires some sort of driver to supply +5 volts to each row(or column, if you turn it sideways) This will be more current than a PIC pin (or DOUT pin) can usually handle. so far, so good.In the case (rough example) of an 8X8 RGB matrix, up to 24 LEDs in each row(column) may be lit at once, requiring maybe 20 ma X 24 = 480 ma (1/2 amp). So you'll certainly need a driver there.My problem.. you said "BC547", which seems to be a NPN transistor. Since it is supplying the + side, I would expect a PNP transistor there, unless you're playing some weird biasing tricks.Normally, (a truly dangerous word around here) NPN transistors provide a switch on the LOW side of the circuit, and a PNP is a "high side" switch. Or simplified, NPN is negative, and PNP is positive.So either you quoted the wrong number, or I'm confused, or we just found the problem in hardware!Hey, I could be all wrong here.. but it might be worth checking out.Have Fun,LyleHaze
protofuse Posted September 28, 2009 Author Report Posted September 28, 2009 hello lylehaze,thanks for the post, but... indeed by reading the code, we can see that thé hardware works fine!if i dont use this lut, it works finei can control colors, x,y led position etc.
protofuse Posted September 28, 2009 Author Report Posted September 28, 2009 (edited) lylehaze, here is the diagram attached. we discussed with lucem about that, as I didn't use BC547 before... I rewrite: without using the Lookup table, all (seems) to work fine. I mean: I can light up x,y led, I can "choose" the color etc. So, considering that, could it be a NPN/PNP problem? I mean, if it was, nothing wouldn't work no? Edited November 10, 2009 by protofuse
lucem Posted September 28, 2009 Report Posted September 28, 2009 The BC547 will work okay here, because the necessary voltage drop from base to emitter of apprix. .7V does not pose a problem, as in the collector-emitter trackabout the same voltage is lost even in switch mode; so, one can expect to deliver about 4.3V to the resistor / LED combination, which is even enough for blue LEDs.I really think there is a problem with his software, but unfortunately I haven't had time yet to look into it.
protofuse Posted September 28, 2009 Author Report Posted September 28, 2009 Ok.thanks lucem for your confirmation.as I wrote, indeed, if I replace the DisplayLED() call by directly MIOS_DOUT_PinSet() correclty feeded by SR pin values, I see blue, red, green, red +blue etc etcall is fine, stable, no flickering.no strange current problem etc etc!the problem is the parsing of my unsigned char lookup table ??? ??? ??? ??? ??? ??? ??? ??? ???I'm stuck ...
lylehaze Posted September 28, 2009 Report Posted September 28, 2009 As long as it works, :)Thanks,LyleHaze
protofuse Posted September 28, 2009 Author Report Posted September 28, 2009 As long as it works, :)Thanks,LyleHazeyou're right.the hardware works.the code doesn't ???
protofuse Posted September 28, 2009 Author Report Posted September 28, 2009 as it is a little bit upper, the summarize of the problem is : [iurl=http://www.midibox.org/forum/index.php/topic,14109.msg121487.html#msg121487]here[/iurl]
TK. Posted September 28, 2009 Report Posted September 28, 2009 Withstatic unsigned char matrix[64] = ... your LUT will be located in RAM (the keyword "static" will make the variable local, it doesn't lead to a constant). So far I remember, RAM areas won't be preloaded automatically by the SDCC wrapper. But using (expensive) RAM isn't the right choice anyhow, it's better to store the table in flash. This should be the case if you are writing: const unsigned char matrix[64] = ...Best Regards, Thorsten.
protofuse Posted September 28, 2009 Author Report Posted September 28, 2009 Hi Thorsten,I'll test it in around 3 hours and post here asap.thanks a lot for the explanation.
protofuse Posted September 28, 2009 Author Report Posted September 28, 2009 it doesn't compile: indeed, I have to set matrix[] value during running time.const cannot be write over, right?I need to write in this lookup table. (maybe I use an uncorrect term and it isn't a lookup table)
protofuse Posted September 28, 2009 Author Report Posted September 28, 2009 I have to add something:noofny/mike and I use a very similar code (mine is inspired by his one)here on his site: http://www.noofny.net/files/ain64_din128_dout128_v2b_CORE_1.zip, we can find the code for one of his core.- his LUT is static- he uses the ISR to display led by calling DisplayLED() functionand it works fine for him.I'm really stuck.I'd like to test things, but I don't know what to test now.should I rebuild my toolchain?should I rebuild processor specific *.lib?should I burn all ? :o :o
TK. Posted September 28, 2009 Report Posted September 28, 2009 - his LUT is static- he uses the ISR to display led by calling DisplayLED() functionand it works fine for him.Yes, because his array is preloaded with zeroes:static unsigned int clipButtons[8] = { 0,0,0,0,0,0,0,0 };and this is the default state after MIOS reset.As already assumed, an array located in RAM won't be preloaded.There are two solutions:- either you preload it inside your application from a const table to your RAM table (thats a simple for-i loop in the Init() hook!)- or you search for code in the internet (or SDCC repository) which is doing the copy operation from the C startup routine (I saw something like this in the past, but don't remember where)Anyhow, I think that the first option should give you a working result in 1 minute!should I burn all ? :o :oHaha! ;)Best Regards, Thorsten.
protofuse Posted September 28, 2009 Author Report Posted September 28, 2009 ok thorstenconst is only for testing... ok i didn't understand...indeed, setting value at startup isnt too difficult.I'll do that.btw, the array you quoted from mike isnt thé same array we're tallig about.thanks a lot thorstenI'll keep the community informed about that.
protofuse Posted September 28, 2009 Author Report Posted September 28, 2009 by changing static to const and by commenting the line where I change matrix[] value to avoid error (we cannot change a const...) I have to say:IT WORKS!so, my code worked and I didn't know that.Thorsten, you just rocks!pictures/movie asap!
WickedBlade Posted September 28, 2009 Report Posted September 28, 2009 So the final world on that is that SDCC doesn't properly initialize non-const variables, even though it parses the code without raising an error or warning? :(Maybe this should be written somewhere on the Wiki (maybe it already is, I didn't find it)... But where?
protofuse Posted September 28, 2009 Author Report Posted September 28, 2009 I guess it isn't a bug, but a thing to know/learn.I only booted and waited for light... the matrix was initialized with 0, and never been modified cause I just waited for ...const are loaded.static aren't.If I had tested by sending midi notes, the protodeck would have answer by lighting up led...
