Rio Posted May 18, 2024 Posted May 18, 2024 (edited) @dwestbury Vice/vsid runs stable and well on Windows (also as a x64 build). Do you currently have a Sidplay build for the mac version with ASID support at hand, which will also run on the latest macOS versions (maybe Arm64 Silikon support)? I can try to compile it according to your description... Edited May 18, 2024 by Rio
Rio Posted May 28, 2024 Posted May 28, 2024 On 5/18/2024 at 8:49 AM, Rio said: I can try to compile it according to your description... I am quoting myself, but just to confirm that it is possible to compile & run on a Mac M2. Thank you for the concise instructions two answers ago. However, there are a few visual glitches and a few crashes (but unrelated for working playback), probably due to using outdated classes. Crashes occur with sidplay by midi device list detection due to previously connected midi device, by window resizing and sometimes midipatch bay crashes when exiting.
Rio Posted November 15, 2024 Posted November 15, 2024 (edited) Maybe someone is interested in the latest binaries & sources. Current MacOS binaries can be found here (Sidplay5 adaption): https://github.com/Alexco500/sidplay5/releases/tag/v5.1.0_111 ..so no one has to go through the agony of xcode compiling/signing ;) and for Windows (32Bit/64Bit) you can find the binaries for Vice 3.2 with ASID (based on aTc's code) here: https://sourceforge.net/projects/vice-emu/files/misc/WinVICE-3.2-asid/ Have a nice day! Edited March 24, 2025 by Rio MacOS, Versions update
