Labelwhore Posted December 8, 2009 Posted December 8, 2009 So last night I finished building my sammichSID. I used midi ox to upload the patches but after uplaoding, every other patch is empty. I have a feeling that there is a setting in midi ox I have to change, but the help file in midi ox isn't helping me much. Has anyone else seen this before? and if so, how did you fix it? I did read that I had to enable a delay after the F7 command, but I can't seem to find a setting like that in midi ox.
nILS Posted December 8, 2009 Posted December 8, 2009 Yes this has happened before and the answer is in the forum. Keep digging :) IIRC Wilba posted a screenie with the correct values for the delays.
Labelwhore Posted December 9, 2009 Author Posted December 9, 2009 I never found the thread, but I found the setting in midi ox :)
nILS Posted December 9, 2009 Posted December 9, 2009 And to keep the rest of us from searching you're just about to post a screenie here, right? :yes:
Labelwhore Posted December 9, 2009 Author Posted December 9, 2009 (edited) No screenie, but I can tell you that it's the buffer settings window accessed via the sysex panel's menu rather than the buffer settings that can be accessed via the options menu. I enabled the delay after F7 and set the delay up to 1000 and set the chunk size to 60 (which was overkill but worked) Edited December 9, 2009 by Labelwhore
kroutshev Posted December 10, 2009 Posted December 10, 2009 Hi Sid freaks ! Sorry for my newbie question but where i can find patch to upload into my sammichSID ? I have looking for on ucapps but i have found nothing. I have donwloaded the editor V5 but there's only .jar file into the zip ??? Thanks.
nILS Posted December 10, 2009 Posted December 10, 2009 I assume you downloaded the latest .zip with the firmware. If you take a look you'll notice a "presets" folder ;)
kroutshev Posted December 10, 2009 Posted December 10, 2009 I have downloaded this http://www.ucapps.de/midibox_sid/v2_editor/MBSIDV2_Editor_v0_5.zip and there's only one .jar file !! I think that's not in the good zip !! But where is the other with presets ? Thanks.
Labelwhore Posted December 10, 2009 Author Posted December 10, 2009 I have downloaded this http://www.ucapps.de/midibox_sid/v2_editor/MBSIDV2_Editor_v0_5.zip and there's only one .jar file !! I think that's not in the good zip !! But where is the other with presets ? Thanks. the presets are on the MIOS download page in the .zip hat has the MB SID firmware
kroutshev Posted December 10, 2009 Posted December 10, 2009 Ok it's in that's file : http://ucapps.de/mios/midibox_sid_v2_0_rc34.zip Thanks !!
cshesse Posted January 13, 2010 Posted January 13, 2010 Ok it's in that's file : http://ucapps.de/mios/midibox_sid_v2_0_rc34.zip Thanks !! Open Midi-Ox View->SysEx SysEx->Configure... Change both sizes from 256 to 60 Change delay after F7 to 1000 Save File->Send SysEx File... Select the .syx preset file included with the midibox sid .hex file in the presets sub directory. Well that would do it, from everything I have found, the file sends and all, but I don't see these presets anywhere so I don't really know why it's not working.
cshesse Posted January 14, 2010 Posted January 14, 2010 Alright, for everyone arriving from Google, if you have Windows use http://www.ucapps.de/howto_tools_syxloader_18f.html Serge's SysEx Loader (SysExBox). It is easy to use and loads the patches without a problem. If you have Mac or Linux, I recommend booting Windows to use it.
Wilba Posted January 14, 2010 Posted January 14, 2010 Why are people using MIDI OX instead of the patch editor? http://www.ucapps.de/midibox_sid_manual_ed.html
cshesse Posted January 15, 2010 Posted January 15, 2010 Why are people using MIDI OX instead of the patch editor? http://www.ucapps.de/midibox_sid_manual_ed.html The patch editor crashed on my mac and couldn't find my midibox on Windows, I had way less problems with MIDI OX and it actually worked when I used the SysExBox thing. For PatchTurkey or whatever nils made, I couldn't figure out how to actually get it to upload things.
