Matrix12x Posted December 12, 2009 Posted December 12, 2009 I just noticed this in the last few days, but MIOS Studio suddenly stopped working. I am using OSX 10.5.8 on an Intel based Mac. It was working fine, and I am not sure what caused this. The MBSID editor program is also crashing as well upon opening. I saw someone in the german language forum seems to be having a similar problem. I think he stated that a previous backup of his OSX I reinstalled MMC, Java and my USB/MIDI interface drivers and nothing seems to help. As a side note, it works fine on my Powerbook laptop, OS 10.4.11, PowerPC. same version of MIOS, same MIDI interface. any ideas?
TK. Posted December 12, 2009 Posted December 12, 2009 Just answered to the same issue in the german section: I installed MacOS 10.6 meanwhile, therefore I'm not able to check this (mmj doesn't work under Snow Leopard anymore). Either it's sufficient to activate the 32bit version of Java with the Programs->Utilities->Java Preferences app, or you have to install Mandolane (unfortunately the mmj guys discontinued the development) Best Regards, Thorsten.
Matrix12x Posted December 12, 2009 Author Posted December 12, 2009 Thanks, I turned off Java SE 6 64-bit and everything ran fine.
Matrix12x Posted December 12, 2009 Author Posted December 12, 2009 Oh... that was until I plugged back in my midid interface.... I think it is MMJ.
dcer10 Posted December 21, 2009 Posted December 21, 2009 Im having a similar issue. Im running 10.5.8 (Have 10.6 but the beta drivers for my Presonus Firestudio arent worth using yet). I had installed Mandalone, then used the SID Editor yesterday, also used the MIOS Studio app without issues. Now Neither will load, I get the following error message: Process: java [1863] Path: /usr/bin/java Identifier: com.apple.javajdk15.SIDV2Editor Version: 12.2.0 (12.2.0) Code Type: X86 (Native) Parent Process: Jar Launcher [1862] Interval Since Last Report: 164060 sec Crashes Since Last Report: 1 Per-App Interval Since Last Report: 10397 sec Per-App Crashes Since Last Report: 2 Date/Time: 2009-12-21 18:59:48.219 +1030 OS Version: Mac OS X 10.5.8 (9L31a) Report Version: 6 Anonymous UUID: 9E11DAFB-9B99-4B6C-A35F-BCC2DB841F0B Exception Type: EXC_BAD_ACCESS (SIGBUS) Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000 Crashed Thread: 1 Application Specific Information: Java information: Version: Java HotSpot Client VM (1.5.0_22-147 mixed mode, sharing) Virtual Machine version: Java HotSpot Client VM (1.5.0_22-147) for macosx-x86, built on Nov 6 2009 10:33:51 by root with gcc 4.0.1 (Apple Inc. build 5465) Exception type: Bus Error (0xa) at pc=0x971d968c Current thread (0x010013b0): JavaThread "main" [_thread_in_native, id=-1333784576] Stack: [0xb0001000,0xb0801000) Java frames: (J=compiled Java code, j=interpreted, Vv=VM code) j com.sun.media.sound.MidiInDeviceProvider.nGetName(I)Ljava/lang/String;+0 j com.sun.media.sound.MidiInDeviceProvider.access$100(I)Ljava/lang/String;+1 j com.sun.media.sound.MidiInDeviceProvider$MidiInDeviceInfo.<init>(ILjava/lang/Class;)V+2 j com.sun.media.sound.MidiInDeviceProvider$MidiInDeviceInfo.<init>(ILjava/lang/Class;Lcom/sun/media/sound/MidiInDeviceProvider$1;)V+3 j com.sun.media.sound.MidiInDeviceProvider.createInfo(I)Lcom/sun/media/sound/AbstractMidiDeviceProvider$Info;+17 j com.sun.media.sound.AbstractMidiDeviceProvider.readDeviceInfos()V+101 j com.sun.media.sound.AbstractMidiDeviceProvider.getDeviceInfo()[Ljavax/sound/midi/MidiDevice$Info;+1 j javax.sound.midi.MidiSystem.getMidiDeviceInfo()[Ljavax/sound/midi/MidiDevice$Info;+36 j org.midibox.midi.MidiDeviceManager.rescanDevices()V+0 j org.midibox.midi.MidiDeviceManager.<init>()V+49 j org.midibox.apps.sidv2editor.SIDV2Editor.<init>()V+5 j SIDV2Editor.<init>()V+21 j SIDV2Editor.main([Ljava/lang/String;)V+18 v ~StubRoutines::call_stub Java Threads: ( => current thread ) 0x0100e2e0 JavaThread "Timer-0" daemon [_thread_blocked, id=9074688] 0x0100ddf0 JavaThread "TimerQueue" daemon [_thread_blocked, id=9098240] 0x0100cbd0 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=9039872] 0x0100bc40 JavaThread "AWT-Shutdown" [_thread_blocked, id=8838656] 0x0100b7c0 JavaThread "AWT-AppKit" daemon [_thread_in_native, id=-1608988896] 0x01008ef0 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=8501760] 0x010084e0 JavaThread "CompilerThread0" daemon [_thread_blocked, id=8498176] 0x01007ff0 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=8494592] 0x01007850 JavaThread "Finalizer" daemon [_thread_blocked, id=8476160] 0x01007490 JavaThread "Reference Handler" daemon [_thread_blocked, id=8470016] =>0x010013b0 JavaThread "main" [_thread_in_native, id=-1333784576] Other Threads: 0x01006bf0 VMThread [id=8466432] 0x01009ad0 WatcherThread [id=8411136] VM state:not at safepoint (normal execution) VM Mutex/Monitor currently owned by a thread: None Heap def new generation total 576K, used 388K [0x295a0000, 0x29640000, 0x29a80000) eden space 512K, 63% used [0x295a0000, 0x295f1020, 0x29620000) from space 64K, 99% used [0x29630000, 0x2963fff8, 0x29640000) to space 64K, 0% used [0x29620000, 0x29620000, 0x29630000) tenured generation total 1408K, used 574K [0x29a80000, 0x29be0000, 0x2d5a0000) the space 1408K, 40% used [0x29a80000, 0x29b0fba8, 0x29b0fc00, 0x29be0000) compacting perm gen total 8192K, used 492K [0x2d5a0000, 0x2dda0000, 0x315a0000) the space 8192K, 6% used [0x2d5a0000, 0x2d61b158, 0x2d61b200, 0x2dda0000) ro space 8192K, 63% used [0x315a0000, 0x31ab9710, 0x31ab9800, 0x31da0000) rw space 12288K, 43% used [0x31da0000, 0x322d1868, 0x322d1a00, 0x329a0000) Virtual Machine arguments: Java command: SIDV2Editor launcher type: SUN_STANDARD Thread 0: 0 libSystem.B.dylib 0x91119286 mach_msg_trap + 10 1 libSystem.B.dylib 0x91120a7c mach_msg + 72 2 com.apple.CoreFoundation 0x953fee7e CFRunLoopRunSpecific + 1790 3 com.apple.CoreFoundation 0x953ffaa8 CFRunLoopRunInMode + 88 4 com.apple.HIToolbox 0x959d62ac RunCurrentEventLoopInMode + 283 5 com.apple.HIToolbox 0x959d60c5 ReceiveNextEventCommon + 374 6 com.apple.HIToolbox 0x959d5f39 BlockUntilNextEventMatchingListInMode + 106 7 com.apple.AppKit 0x942876d5 _DPSNextEvent + 657 8 com.apple.AppKit 0x94286f88 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 128 9 com.apple.AppKit 0x9427ff9f -[NSApplication run] + 795 10 libawt.jnilib 0x05e8ff69 +[AWTStarter startAWT:] + 1941 11 libawt.jnilib 0x05e8f786 -[CPerformer perform] + 281 12 com.apple.Foundation 0x94f319ac __NSThreadPerformPerform + 476 13 com.apple.CoreFoundation 0x953ff3c5 CFRunLoopRunSpecific + 3141 14 com.apple.CoreFoundation 0x953ffaa8 CFRunLoopRunInMode + 88 15 java 0x00005135 0x1000 + 16693 16 java 0x00002196 0x1000 + 4502 Thread 1 Crashed: 0 libobjc.A.dylib 0x971d968c objc_msgSend + 28 1 libjsound.jnilib 0x19dc106f Java_com_sun_media_sound_HAEShutdownHook_exiting + 884 2 libjsound.jnilib 0x19dc11d1 Java_com_sun_media_sound_HAEShutdownHook_exiting + 1238 3 libjsound.jnilib 0x19dc125c Java_com_sun_media_sound_HAEShutdownHook_exiting + 1377 4 libjsound.jnilib 0x19dc1cc9 Java_com_sun_media_sound_HAEShutdownHook_exiting + 4046 5 libjsound.jnilib 0x19dc2612 Java_com_sun_media_sound_MidiInDeviceProvider_nGetName + 54 6 ??? 0x035a19b1 0 + 56236465 7 ??? 0x0359baaa 0 + 56212138 8 ??? 0x0359baaa 0 + 56212138 9 ??? 0x0359b9d3 0 + 56211923 10 ??? 0x0359b9d3 0 + 56211923 11 ??? 0x0359baaa 0 + 56212138 12 ??? 0x0359b9d3 0 + 56211923 13 ??? 0x0359baaa 0 + 56212138 14 ??? 0x0359baaa 0 + 56212138 15 ??? 0x0359b9d3 0 + 56211923 16 ??? 0x0359b9d3 0 + 56211923 17 ??? 0x0359b9d3 0 + 56211923 18 ??? 0x0359b9d3 0 + 56211923 19 ??? 0x03599227 0 + 56201767 20 libclient.dylib 0x004d5b5a 0x3bc000 + 1153882 21 libclient.dylib 0x004d5876 0x3bc000 + 1153142 22 libclient.dylib 0x00473822 0x3bc000 + 751650 23 libclient.dylib 0x005d3c20 JNI_CreateJavaVM_Impl + 132944 24 java 0x0000224f 0x1000 + 4687 25 java 0x000040d1 0x1000 + 12497 26 java 0x00004cc6 0x1000 + 15558 27 libSystem.B.dylib 0x9114a155 _pthread_start + 321 28 libSystem.B.dylib 0x9114a012 thread_start + 34 Thread 2: 0 libSystem.B.dylib 0x91119286 mach_msg_trap + 10 1 libSystem.B.dylib 0x91120a7c mach_msg + 72 2 libSystem.B.dylib 0x9118e12f mach_msg_server + 491 3 libclient.dylib 0x003cb295 0x3bc000 + 62101 4 libclient.dylib 0x003cb055 0x3bc000 + 61525 5 libclient.dylib 0x00682311 JVM_RaiseSignal + 442177 6 libSystem.B.dylib 0x91195200 _pthread_body + 27 Thread 3: 0 libSystem.B.dylib 0x91119286 mach_msg_trap + 10 1 libSystem.B.dylib 0x91120a7c mach_msg + 72 2 libclient.dylib 0x004d4a83 0x3bc000 + 1149571 3 libclient.dylib 0x004d491c 0x3bc000 + 1149212 4 libclient.dylib 0x004194dd 0x3bc000 + 382173 5 libclient.dylib 0x00419047 0x3bc000 + 380999 6 libclient.dylib 0x00682311 JVM_RaiseSignal + 442177 7 libSystem.B.dylib 0x91195200 _pthread_body + 27 Thread 4: 0 libSystem.B.dylib 0x91119286 mach_msg_trap + 10 1 libSystem.B.dylib 0x91120a7c mach_msg + 72 2 libclient.dylib 0x004d4b3a 0x3bc000 + 1149754 3 libclient.dylib 0x0041a57a 0x3bc000 + 386426 4 libclient.dylib 0x00419b65 0x3bc000 + 383845 5 libclient.dylib 0x005fc3a1 JVM_MonitorWait + 465 6 ??? 0x035a19b1 0 + 56236465 7 ??? 0x0359b9d3 0 + 56211923 8 ??? 0x0359b9d3 0 + 56211923 9 ??? 0x03599227 0 + 56201767 10 libclient.dylib 0x004d5b5a 0x3bc000 + 1153882 11 libclient.dylib 0x00419a53 0x3bc000 + 383571 12 libclient.dylib 0x00419945 0x3bc000 + 383301 13 libclient.dylib 0x00419885 0x3bc000 + 383109 14 libclient.dylib 0x004197a8 0x3bc000 + 382888 15 libclient.dylib 0x00682311 JVM_RaiseSignal + 442177 16 libSystem.B.dylib 0x91195200 _pthread_body + 27 Thread 5: 0 libSystem.B.dylib 0x91119286 mach_msg_trap + 10 1 libSystem.B.dylib 0x91120a7c mach_msg + 72 2 libclient.dylib 0x004d4b3a 0x3bc000 + 1149754 3 libclient.dylib 0x0041a57a 0x3bc000 + 386426 4 libclient.dylib 0x00419b65 0x3bc000 + 383845 5 libclient.dylib 0x005fc3a1 JVM_MonitorWait + 465 6 ??? 0x035a19b1 0 + 56236465 7 ??? 0x0359b9d3 0 + 56211923 8 ??? 0x0359baaa 0 + 56212138 9 ??? 0x0359baaa 0 + 56212138 10 ??? 0x03599227 0 + 56201767 11 libclient.dylib 0x004d5b5a 0x3bc000 + 1153882 12 libclient.dylib 0x00419a53 0x3bc000 + 383571 13 libclient.dylib 0x00419945 0x3bc000 + 383301 14 libclient.dylib 0x00419885 0x3bc000 + 383109 15 libclient.dylib 0x004197a8 0x3bc000 + 382888 16 libclient.dylib 0x00682311 JVM_RaiseSignal + 442177 17 libSystem.B.dylib 0x91195200 _pthread_body + 27 Thread 6: 0 libSystem.B.dylib 0x911192c2 semaphore_wait_trap + 10 1 libclient.dylib 0x0041adae 0x3bc000 + 388526 2 libclient.dylib 0x0041a955 0x3bc000 + 387413 3 libclient.dylib 0x004197a8 0x3bc000 + 382888 4 libclient.dylib 0x00682311 JVM_RaiseSignal + 442177 5 libSystem.B.dylib 0x91195200 _pthread_body + 27 Thread 7: 0 libSystem.B.dylib 0x91119286 mach_msg_trap + 10 1 libSystem.B.dylib 0x91120a7c mach_msg + 72 2 libclient.dylib 0x004d4b3a 0x3bc000 + 1149754 3 libclient.dylib 0x004d47d9 0x3bc000 + 1148889 4 libclient.dylib 0x0041b3db 0x3bc000 + 390107 5 libclient.dylib 0x0041b0b8 0x3bc000 + 389304 6 libclient.dylib 0x004197a8 0x3bc000 + 382888 7 libclient.dylib 0x00682311 JVM_RaiseSignal + 442177 8 libSystem.B.dylib 0x91195200 _pthread_body + 27 Thread 8: 0 libSystem.B.dylib 0x91119286 mach_msg_trap + 10 1 libSystem.B.dylib 0x91120a7c mach_msg + 72 2 libclient.dylib 0x004d4b3a 0x3bc000 + 1149754 3 libclient.dylib 0x004d491c 0x3bc000 + 1149212 4 libclient.dylib 0x0041b4f0 0x3bc000 + 390384 5 libclient.dylib 0x004197a8 0x3bc000 + 382888 6 libclient.dylib 0x00682311 JVM_RaiseSignal + 442177 7 libSystem.B.dylib 0x91195200 _pthread_body + 27 Thread 9: 0 libSystem.B.dylib 0x91119286 mach_msg_trap + 10 1 libSystem.B.dylib 0x91120a7c mach_msg + 72 2 libclient.dylib 0x004d4a83 0x3bc000 + 1149571 3 libclient.dylib 0x0041bd0f 0x3bc000 + 392463 4 libclient.dylib 0x0041b85a 0x3bc000 + 391258 5 libclient.dylib 0x00682311 JVM_RaiseSignal + 442177 6 libSystem.B.dylib 0x91195200 _pthread_body + 27 Thread 10: 0 libSystem.B.dylib 0x91119286 mach_msg_trap + 10 1 libSystem.B.dylib 0x91120a7c mach_msg + 72 2 libclient.dylib 0x004d4a83 0x3bc000 + 1149571 3 libclient.dylib 0x0041a57a 0x3bc000 + 386426 4 libclient.dylib 0x00419b65 0x3bc000 + 383845 5 libclient.dylib 0x005fc3a1 JVM_MonitorWait + 465 6 ??? 0x035a19b1 0 + 56236465 7 ??? 0x0359b9d3 0 + 56211923 8 ??? 0x0359bcd9 0 + 56212697 9 ??? 0x03599227 0 + 56201767 10 libclient.dylib 0x004d5b5a 0x3bc000 + 1153882 11 libclient.dylib 0x00419a53 0x3bc000 + 383571 12 libclient.dylib 0x00419945 0x3bc000 + 383301 13 libclient.dylib 0x00419885 0x3bc000 + 383109 14 libclient.dylib 0x004197a8 0x3bc000 + 382888 15 libclient.dylib 0x00682311 JVM_RaiseSignal + 442177 16 libSystem.B.dylib 0x91195200 _pthread_body + 27 Thread 11: 0 libSystem.B.dylib 0x91119286 mach_msg_trap + 10 1 libSystem.B.dylib 0x91120a7c mach_msg + 72 2 libclient.dylib 0x004d4b3a 0x3bc000 + 1149754 3 libclient.dylib 0x0041a57a 0x3bc000 + 386426 4 libclient.dylib 0x00419b65 0x3bc000 + 383845 5 libclient.dylib 0x005fc3a1 JVM_MonitorWait + 465 6 ??? 0x035a19b1 0 + 56236465 7 ??? 0x0359b9d3 0 + 56211923 8 ??? 0x0359baaa 0 + 56212138 9 ??? 0x0359baaa 0 + 56212138 10 ??? 0x0359bcd9 0 + 56212697 11 ??? 0x03599227 0 + 56201767 12 libclient.dylib 0x004d5b5a 0x3bc000 + 1153882 13 libclient.dylib 0x00419a53 0x3bc000 + 383571 14 libclient.dylib 0x00419945 0x3bc000 + 383301 15 libclient.dylib 0x00419885 0x3bc000 + 383109 16 libclient.dylib 0x004197a8 0x3bc000 + 382888 17 libclient.dylib 0x00682311 JVM_RaiseSignal + 442177 18 libSystem.B.dylib 0x91195200 _pthread_body + 27 Thread 12: 0 libSystem.B.dylib 0x91119286 mach_msg_trap + 10 1 libSystem.B.dylib 0x91120a7c mach_msg + 72 2 libclient.dylib 0x004d4b3a 0x3bc000 + 1149754 3 libclient.dylib 0x0041a57a 0x3bc000 + 386426 4 libclient.dylib 0x00419b65 0x3bc000 + 383845 5 libclient.dylib 0x005fc3a1 JVM_MonitorWait + 465 6 ??? 0x035a19b1 0 + 56236465 7 ??? 0x0359b9d3 0 + 56211923 8 ??? 0x0359bcd9 0 + 56212697 9 ??? 0x03599227 0 + 56201767 10 libclient.dylib 0x004d5b5a 0x3bc000 + 1153882 11 libclient.dylib 0x00419a53 0x3bc000 + 383571 12 libclient.dylib 0x00419945 0x3bc000 + 383301 13 libclient.dylib 0x00419885 0x3bc000 + 383109 14 libclient.dylib 0x004197a8 0x3bc000 + 382888 15 libclient.dylib 0x00682311 JVM_RaiseSignal + 442177 16 libSystem.B.dylib 0x91195200 _pthread_body + 27 Thread 13: 0 libSystem.B.dylib 0x91119286 mach_msg_trap + 10 1 libSystem.B.dylib 0x91120a7c mach_msg + 72 2 libclient.dylib 0x004d4a83 0x3bc000 + 1149571 3 libclient.dylib 0x0041a57a 0x3bc000 + 386426 4 libclient.dylib 0x00419b65 0x3bc000 + 383845 5 libclient.dylib 0x005fc3a1 JVM_MonitorWait + 465 6 ??? 0x035a19b1 0 + 56236465 7 ??? 0x0359b9d3 0 + 56211923 8 ??? 0x0359b9d3 0 + 56211923 9 ??? 0x03599227 0 + 56201767 10 libclient.dylib 0x004d5b5a 0x3bc000 + 1153882 11 libclient.dylib 0x00419a53 0x3bc000 + 383571 12 libclient.dylib 0x00419945 0x3bc000 + 383301 13 libclient.dylib 0x00419885 0x3bc000 + 383109 14 libclient.dylib 0x004197a8 0x3bc000 + 382888 15 libclient.dylib 0x00682311 JVM_RaiseSignal + 442177 16 libSystem.B.dylib 0x91195200 _pthread_body + 27 Thread 14: 0 libSystem.B.dylib 0x91119286 mach_msg_trap + 10 1 libSystem.B.dylib 0x91120a7c mach_msg + 72 2 com.apple.audio.midi.CoreMIDI 0x19de0f0f XServerMachPort::ReceiveMessage(int&, void*, int&) + 101 3 com.apple.audio.midi.CoreMIDI 0x19dd3477 MIDIInPortThread::Run() + 111 4 com.apple.audio.midi.CoreMIDI 0x19dd707d XThread::RunHelper(void*) + 17 5 com.apple.audio.midi.CoreMIDI 0x19de19ee CAPThread::Entry(CAPThread*) + 96 6 libSystem.B.dylib 0x9114a155 _pthread_start + 321 7 libSystem.B.dylib 0x9114a012 thread_start + 34 Thread 1 crashed with X86 Thread State (32-bit): eax: 0x004dddfb ebx: 0x95417c5a ecx: 0x9722adc8 edx: 0x2cec835b edi: 0x00000000 esi: 0x004dddfb ebp: 0xb07ffbc8 esp: 0xb07ffba4 ss: 0x0000001f efl: 0x00010202 eip: 0x971d968c cs: 0x00000017 ds: 0x0000001f es: 0x0000001f fs: 0x0000001f gs: 0x00000037 cr2: 0x00000000 Binary Images: 0x1000 - 0xaff0 java ??? (???) <9ff77f7c1bd66f7bf1e58e311015b76e> /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Home/bin/java 0x11000 - 0x17fff com.apple.JavaVM 12.5.0 (12.5.0) <8d3f4bb411ac2490335be9a612bb2a22> /System/Library/Frameworks/JavaVM.framework/Versions/A/JavaVM 0x3b000 - 0x42fe0 libverify.dylib ??? (???) <e190c75462e6015bf99969bf28ce9768> /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries/libverify.dylib 0x48000 - 0x4ffff JavaNativeFoundation ??? (???) <1b571e33958e91d3b825da0497373783> /System/Library/Frameworks/JavaVM.framework/Versions/A/Frameworks/JavaNativeFoundation.framework/Versions/A/JavaNativeFoundation 0x63000 - 0x7dfef libjava.jnilib ??? (???) <e6a1c9d585bfaf1f2b26792ce2dfe162> /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries/libjava.jnilib 0x8d000 - 0x98ffb libzip.jnilib ??? (???) <8db8db78b157c73d52941ae9e57f8ea3> /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries/libzip.jnilib 0x3bc000 - 0x70dfe3 libclient.dylib ??? (???) <cb54ecc393cba45b8b0b3f8c2a335c3e> /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries/libclient.dylib 0x5e8e000 - 0x6028fff libawt.jnilib ??? (???) <88490a02b4167da304d84963aff162ea> /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries/libawt.jnilib 0x1615a000 - 0x1615afff libcmm.jnilib ??? (???) <9f7e0175b053e7dec8b5957fe9fd1b3e> /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries/libcmm.jnilib 0x16cbc000 - 0x16ec3fef com.apple.RawCamera.bundle 2.1.0 (474) <48a574d3b3269c8dbdc38d6f67879317> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera 0x16faa000 - 0x17008fff libfontmanager.jnilib ??? (???) <465444f1b8093ed64022697c7acc7923> /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries/libfontmanager.jnilib 0x17023000 - 0x17045fe7 libjpeg.jnilib ??? (???) <c19ad795df0f213161fe6089a5dafa7e> /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries/libjpeg.jnilib 0x19ab1000 - 0x19af9ff3 libsuncmm.jnilib ??? (???) <bf5accb0f0c8a69b1c380a94e3b23be4> /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries/libsuncmm.jnilib 0x19b1e000 - 0x19b2eff7 liblaf.jnilib ??? (???) <a341672abd5ba16783ffae35513a9982> /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries/liblaf.jnilib 0x19b3a000 - 0x19b58fe3 libexpat.1.dylib ??? (???) <caa6d7f83f7e0a3fe26aa5904c6f98a9> /usr/lib/libexpat.1.dylib 0x19d99000 - 0x19dc5ff7 libjsound.jnilib ??? (???) <19112660aafefebd40c63acf98e6e47f> /System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/Libraries/libjsound.jnilib 0x19dcf000 - 0x19decff7 com.apple.audio.midi.CoreMIDI 1.6.1 (42) /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI 0x19e04000 - 0x19e06ffc +libMandoMidiLpJNILib.jnilib ??? (???) <e74adebd41c507f12549b4e38b15031d> /Library/Java/Extensions/libMandoMidiLpJNILib.jnilib 0x8fe00000 - 0x8fe2db43 dyld 97.1 (???) <458eed38a009e5658a79579e7bc26603> /usr/lib/dyld 0x90022000 - 0x903e0fea libLAPACK.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib 0x903e1000 - 0x90474fff com.apple.ink.framework 101.3 (86) <d4c85b5cafa8027fff042b84a8be71dc> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink 0x90475000 - 0x904f2feb com.apple.audio.CoreAudio 3.1.2 (3.1.2) <782a08c44be4698597f4bbd79cac21c6> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio 0x904f3000 - 0x90570fef libvMisc.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib 0x905d8000 - 0x905d8ffc com.apple.audio.units.AudioUnit 1.5 (1.5) /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit 0x905d9000 - 0x905e6fe7 com.apple.opengl 1.5.10 (1.5.10) <e7d1198d869f45f09251f9697cbdd192> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL 0x905f9000 - 0x906b3fe3 com.apple.CoreServices.OSServices 228 (228) <bc83e97f6888673c33f86652677c09cb> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices 0x908be000 - 0x90c5bfef com.apple.QuartzCore 1.5.8 (1.5.8) <18113e06d296230d63a63b58baf35f55> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore 0x90c5f000 - 0x90c7dfff libresolv.9.dylib ??? (???) <0e26b308654f33fc94a0c010a50751f9> /usr/lib/libresolv.9.dylib 0x90c84000 - 0x90c84ff8 com.apple.Cocoa 6.5 (???) <a1bc9247cf65c20f1a44d0973cbe649c> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa 0x90c85000 - 0x90c85ffd com.apple.vecLib 3.4.2 (vecLib 3.4.2) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib 0x90c86000 - 0x90d36fff edu.mit.Kerberos 6.0.13 (6.0.13) <e3baa3d7b3ca7fa92082958af0b36973> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos 0x90e1e000 - 0x90e49fe7 libauto.dylib ??? (???) <4f3e58cb81da07a1662c1f647ce30225> /usr/lib/libauto.dylib 0x90e87000 - 0x90e87ff8 com.apple.ApplicationServices 34 (34) <ee7bdf593da050bb30c7a1fc446eb8a6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices 0x90e88000 - 0x91059ff3 com.apple.security 5.0.5 (36371) <c7f5d1b89c9891d332c81d1c5fe925e3> /System/Library/Frameworks/Security.framework/Versions/A/Security 0x9105a000 - 0x9105efff libGIF.dylib ??? (???) <3c7100e80b7f7ca8809cf9512c1a6004> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib 0x9105f000 - 0x9105fffa com.apple.CoreServices 32 (32) <373d6a888f9204641f313bc6070ae065> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices 0x91060000 - 0x910a9fef com.apple.Metadata 10.5.8 (398.26) <e4d268ea45379200f03cdc7c8bedae6f> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata 0x910aa000 - 0x910aaffb com.apple.installserver.framework 1.0 (8) /System/Library/PrivateFrameworks/InstallServer.framework/Versions/A/InstallServer 0x910fa000 - 0x91116ff3 libPng.dylib ??? (???) <271373dd41f56369a3dfca0ed2be579a> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib 0x91117000 - 0x91117ffd com.apple.Accelerate.vecLib 3.4.2 (vecLib 3.4.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib 0x91118000 - 0x9127fff3 libSystem.B.dylib ??? (???) <ae47ca9b1686b065f8ac4d2de09cc432> /usr/lib/libSystem.B.dylib 0x9134a000 - 0x9134dfff com.apple.help 1.1 (36) <1a25a8fbb49a830efb31d5c0a52939cd> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help 0x9134e000 - 0x9137bfeb libvDSP.dylib ??? (???) <f39d424bd56a0e75d5c7a2280a25cd76> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib 0x913ef000 - 0x91496fec com.apple.CFNetwork 438.14 (438.14) <5f9ee0430b5f6319f18d9b23e777e0d2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork 0x91497000 - 0x914c6fe3 com.apple.AE 402.3 (402.3) <dba512e47f68eea1dd0ab35f596edb34> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE 0x914c7000 - 0x91554ff7 com.apple.framework.IOKit 1.5.2 (???) <7a3cc24f78f93931731203854ae0d891> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit 0x91555000 - 0x91965fef libBLAS.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib 0x91a6d000 - 0x91abeff7 com.apple.HIServices 1.7.1 (???) <ba7fd0ede540a0da08db027f87efbd60> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices 0x91af6000 - 0x91dd0ff3 com.apple.CoreServices.CarbonCore 786.11 (786.14) <d5cceb2fe9551d345d40dd1ecf409ec2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore 0x91dd1000 - 0x922a2fbe libGLProgrammability.dylib ??? (???) <d5cb4e7997a873cd77523689e6749acd> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib 0x922a3000 - 0x922bbfff com.apple.openscripting 1.2.8 (???) <a888b18c8527f71629702ed8dce9c877> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting 0x922bc000 - 0x922e0fff libxslt.1.dylib ??? (???) <adfe90a3d564d824d5ae0fa6df8d6c3f> /usr/lib/libxslt.1.dylib 0x922e1000 - 0x922e9fff com.apple.DiskArbitration 2.2.1 (2.2.1) <ba64dd6ada417b5e7be736957f380bca> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration 0x922ea000 - 0x922f6ff9 com.apple.helpdata 1.0.1 (14.2) /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData 0x922f7000 - 0x92335fff libGLImage.dylib ??? (???) <2e570958595e0c9c3a289158223b39ee> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib 0x924f8000 - 0x92508fff com.apple.speech.synthesis.framework 3.7.1 (3.7.1) <9a71429c74ed6ca43eb35e1f78471b2e> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis 0x92634000 - 0x926dbfeb com.apple.QD 3.11.57 (???) <35f058678972d42b88ebdf652df79956> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD 0x926dc000 - 0x926e6feb com.apple.audio.SoundManager 3.9.2 (3.9.2) <df077a8048afc3075c6f2d9e7780e78e> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound 0x926e7000 - 0x926edfff com.apple.print.framework.Print 218.0.3 (220.2) <8c541d587e4068a5fe5a5ce8ee208516> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print 0x926ee000 - 0x926f5ffe libbsm.dylib ??? (???) <fa7ae5f1a621d9b69e7e18747c9405fb> /usr/lib/libbsm.dylib 0x926f6000 - 0x926f6ffd com.apple.Accelerate 1.4.2 (Accelerate 1.4.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate 0x928b4000 - 0x928b5ffc libffi.dylib ??? (???) <eaf10b99a3fbc4920b175809407466c0> /usr/lib/libffi.dylib 0x928b6000 - 0x92997ff7 libxml2.2.dylib ??? (???) <b3bc0b280c36aa17ac477b4da56cd038> /usr/lib/libxml2.2.dylib 0x92998000 - 0x929a8ffc com.apple.LangAnalysis 1.6.5 (1.6.5) <d057feb38163121ffd871c564c692804> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis 0x929af000 - 0x929c5fff com.apple.DictionaryServices 1.0.0 (1.0.0) <7d20b8d1fb238c3e71d0fa6fda18c4f7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices 0x92d65000 - 0x92eb7ff3 com.apple.audio.toolbox.AudioToolbox 1.5.2 (1.5.2) /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox 0x92eb8000 - 0x92ee0ff7 com.apple.shortcut 1.0.1 (1.0) <37e4b08cfaf9edb08b8682a06c4ec844> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut 0x92ee6000 - 0x92ef2ffe libGL.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib 0x92ef3000 - 0x92f32fef libTIFF.dylib ??? (???) <801873cbd85ba7bdfe7646fe97a54ca3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib 0x92f33000 - 0x92fb2ff5 com.apple.SearchKit 1.2.2 (1.2.2) <3b5f3ab6a363a4d8a2bbbf74213ab0e5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit 0x92fb3000 - 0x9303dfe3 com.apple.DesktopServices 1.4.8 (1.4.8) <a6edef2d49ffdee3b01010b7e6edac1f> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv 0x9303e000 - 0x9304cffd libz.1.dylib ??? (???) <a98b3b221a72b54faf73ded3dd7000e5> /usr/lib/libz.1.dylib 0x93099000 - 0x930b8ffa libJPEG.dylib ??? (???) <50b881dd5a5795d38405c9c88c2806fa> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib 0x94191000 - 0x941d3fef com.apple.NavigationServices 3.5.2 (163) <7f4f1766414a511bf5bc68920ac85a88> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices 0x94247000 - 0x94a45fef com.apple.AppKit 6.5.9 (949.54) <4df5d2e2271175452103f789b4f4d8a8> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x94a8b000 - 0x94accfe7 libRIP.A.dylib ??? (???) <e9c5df8bd574b71e55ac60c910b929ce> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib 0x94acd000 - 0x94c06ff7 libicucore.A.dylib ??? (???) <f2819243b278259b9a622ea111ea5fd6> /usr/lib/libicucore.A.dylib 0x94c07000 - 0x94c61ff7 com.apple.CoreText 2.0.4 (???) <c7a222be1b51a9954eae716adbd5626a> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText 0x94c97000 - 0x94d2aff3 com.apple.ApplicationServices.ATS 3.8 (???) <eda9db16110de6b7fd9436cd0daa787d> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS 0x94f26000 - 0x951a2fe7 com.apple.Foundation 6.5.9 (677.26) <c68b3cff7864959becfc7fd1a384f925> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x951c3000 - 0x951dbff7 com.apple.CoreVideo 1.6.0 (20.0) <587c9c8966070a7d50276db35e1c76aa> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo 0x951dc000 - 0x95213fff com.apple.SystemConfiguration 1.9.2 (1.9.2) <41d5aeffefc6d19d471f51ae0b15024f> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration 0x95362000 - 0x9538bfff libcups.2.dylib ??? (???) <ee771753dd1111b656a2daa234a9e971> /usr/lib/libcups.2.dylib 0x9538c000 - 0x954bffe7 com.apple.CoreFoundation 6.5.7 (476.19) <a332c8f45529ee26d2e9c36d0c723bad> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x9552e000 - 0x95543ffb com.apple.ImageCapture 5.0.2 (5.0.2) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture 0x95574000 - 0x9557ffe7 libCSync.A.dylib ??? (???) <d88c20c9a2fd0676dec62fddfa74979f> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib 0x95581000 - 0x95648ff2 com.apple.vImage 3.0 (3.0) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage 0x959a3000 - 0x959a5ff5 libRadiance.dylib ??? (???) <aefd52482869bb5010672679d151167e> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib 0x959a6000 - 0x95caefe7 com.apple.HIToolbox 1.5.6 (???) <eece3cb8aa0a4e6843fcc1500aca61c5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x95caf000 - 0x95cb4fff com.apple.CommonPanels 1.2.4 (85) <c135f02edd6b2e2864311e0b9d08a98d> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels 0x95cb5000 - 0x95cb9fff libmathCommon.A.dylib ??? (???) /usr/lib/system/libmathCommon.A.dylib 0x95cbb000 - 0x95cc2ff7 libCGATS.A.dylib ??? (???) <1339abfb67318d65c0130f76bc8c4da6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib 0x95cc3000 - 0x95ccafe9 libgcc_s.1.dylib ??? (???) <e280ddf3f5fb3049e674edcb109f389a> /usr/lib/libgcc_s.1.dylib 0x95ccb000 - 0x95d45ff8 com.apple.print.framework.PrintCore 5.5.4 (245.6) <9ae833544b8249984c07544dbe6a97fa> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore 0x95d46000 - 0x95dcdff7 libsqlite3.0.dylib ??? (???) <aaaf72c093e13f34b96e2688b95bdb4a> /usr/lib/libsqlite3.0.dylib 0x95dce000 - 0x9646efeb com.apple.CoreGraphics 1.409.5 (???) <a40644ccdbdc76e3a0ab4d468b2f9bdd> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics 0x9646f000 - 0x964a9fe7 com.apple.coreui 1.2 (62) /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI 0x964aa000 - 0x96506ff7 com.apple.htmlrendering 68 (1.1.3) <1c5c0c417891b920dfe139385fc6c155> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering 0x966da000 - 0x96737ffb libstdc++.6.dylib ??? (???) <f75e5133d72769de5ce6c06153fc65f6> /usr/lib/libstdc++.6.dylib 0x96738000 - 0x9673afff com.apple.securityhi 3.0 (30817) <b3517782ad664a21e4fd60242e92723e> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI 0x9674b000 - 0x96893ff7 com.apple.ImageIO.framework 2.0.6 (2.0.6) <7f73ef328c8e8566f3f204b5a540a7f0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO 0x97166000 - 0x971bfff7 libGLU.dylib ??? (???) <64d010e31d7596bd8f9edc6e027d1d0c> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib 0x971c0000 - 0x971c0fff com.apple.Carbon 136 (136) <eb3c292d5544512f86e1e4e743c23f8e> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon 0x971c4000 - 0x972a4fff libobjc.A.dylib ??? (???) <3ca288b625a47bbcfe378158e4dc328f> /usr/lib/libobjc.A.dylib 0x972a5000 - 0x97357ffb libcrypto.0.9.7.dylib ??? (???) <8ac6abef4b3bb125c8bf84634421bcee> /usr/lib/libcrypto.0.9.7.dylib 0x97358000 - 0x97440ff3 com.apple.CoreData 100.2 (186.2) <44df326fea0236718f5ed64084e82270> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData 0x97441000 - 0x974ceff7 com.apple.LaunchServices 292 (292) <a41286c7c1eb20ffd5cc796f791070f0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices 0x974dc000 - 0x975a7fef com.apple.ColorSync 4.5.3 (4.5.3) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync 0x975a8000 - 0x975b1fff com.apple.speech.recognition.framework 3.7.24 (3.7.24) <da2d8411921a3fd8bc898dc753b7f3ee> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition 0xfffe8000 - 0xfffebfff libobjc.A.dylib ??? (???) /usr/lib/libobjc.A.dylib 0xffff0000 - 0xffff1780 libSystem.B.dylib ??? (???) /usr/lib/libSystem.B.dylib Does anyone have any idea how to get these working? I was all excited to load up the 127 arps patch and possibly contribute some patches if I could make some good ones! Thanks, John
dcer10 Posted December 21, 2009 Posted December 21, 2009 (edited) I also tried changing the 32/64 java prefs but no luck there. Edited December 21, 2009 by dcer10
