USB Mass Storage device STM32 Can't get it recognised anywhere!
#1
Posted 03 March 2010 - 21:01
As I have to wait to recable my LCDs in my MBSEQ till the weekend, I thought I would test my newly soldered MBSD cable and MB_CORE_32 using the USB Mass Storage device app available in MIOS32 downloads. I have used the ultra low cost MBSD route i.e. a Mini SD adapter with the cables soldered then putting a Micro SD card into the adapter.
When I plug in my Mini SD card, I get all the right signs from Windows XP SP2, an STM Mass storage device is found. But it seems that as Windows trys to create the removable device something goes wrong. The Removable device starts to appear in My Computer, then disappears. This appearing/disappearing goes round continuously but the device is never actually available (this creates a great glitchy sound of Windows alert playing all over the place, cool but not what I want!). I've tried this on 4 different machines today, Windows XP and Vista plus Macbook and Ubuntu desktop. The Windows machines at least try to recognise the SD card, Mac OS and Ubuntu see nothing. I always connect direct to a USB port, that is I have no hubs etc involved.
I've been over my Mini SD adapter and checked continuity, all fine. I've triple checked the schematic and I'm 99 percent sure that's fine (admit to being human though!). I have measured 3.3v on the SD card when hooked up to the CORE_32, fine. I've tried 3 different Micro SD cards, a SanDisk and two no names. Always the same behaviour :(
The only thing which seems a bit strange is that the status LED starts to flash once I plug in the SD card. Is it supposed to do that? Or is that a sign that the USB power can't handle powering up the SD card?
Other than that, does anyone have any suggestion why this may be happening?
Thanks in advance
David
#2
Posted 03 March 2010 - 23:14
Quote
It shouldn't flash - do you mean the same dimming effect which will be performed by the bootloader after power-on?
This indicates that something resets the core.
E.g. a short circuit once the card has been connected.
After reset, and after the application has been restarted, the IO pin drivers will be enabled, and if this causes a short (-> power drop), the core will boot again.
Period.
Since you already checked the adapter, the issue could be located at the core side.
E.g., check that J24 is connected to 3.3V position (not 5V!), check that R30 resistor arrays *not* mounted, check with a multimeter that there is no short between SI/SO/SC/RC pins
Buy TK a Beer Disclaimer: buying TK a beer gets you absolutely nothing in return likesuchas firmware enhancements, technical advices and MIDIbox troubleshooting assistance.
#3
Posted 07 March 2010 - 12:30
Thanks for the speedy reply.
I would say this is exactly what is happening.
For sure it is 3.3v. I originally had R30, but I removed it after rechecking the MBSEQ interconnection PDF and making my first post
I have double checked a few times, there is no short to be measured between those 4 lines, when the SD card adapter is plugged in or not.
The only thing I have found with a good poking around with my multimeter on j16 is that between VSS and VCC there is a resistance which seems to constantly shift around. This is regardless of the SD card adapter being plugged in or not. I guess this is ok?
So I'm a bit stuck now
Best Regards
David
Edited for smilies!
This post has been edited by monokinetic: 07 March 2010 - 12:33
#4
Posted 07 March 2010 - 19:55
it would be interesting if the MBSEQ V4 application is able to read the SD Card, or if the core will be rebooted as well.
In the most recent release (beta16) I integrated a command interface to access debugging functions from the MIOS32 terminal, which is part of MIOS Studio 2:
Could you please try it?
Just enter "help" to test that the communication is working, and "sdcard" to retrieve informations from the SD Card
#5
Posted 07 March 2010 - 23:51
What a funny coincidence, this afternoon I was just thinking, what I would need is a way to test this on MBSeqV4 firmware and a few hours later I found your post!!!
I will more than happily try it..... I uploaded MBSeqV4 beta 16 and the result of entering sdcard in MIOS Studio V2 is this:
[46078.002] SD Card Informations [46078.002] ==================== [46078.002] -------------------- [46078.002] CID: [46078.002] - ManufacturerID: [46078.002] - OEM AppliID: [46078.002] - ProdName: SD128 [46078.002] - ProdRev: 0 [46078.002] - ProdSN: 0x00004661 [46078.002] - Reserved1: 41 [46078.002] - ManufactDate: 82 [46078.002] - msd_CRC: 0x38 [46078.002] - Reserved2: 1 [46078.002] -------------------- [46078.003] -------------------- [46078.003] - CSDStruct: 0 [46078.003] - SysSpecVersion: 0 [46078.003] - Reserved1: 0 [46078.003] - TAAC: 127 [46078.003] - NSAC: 0 [46078.003] - MaxBusClkFrec: 50 [46078.003] - CardComdClasses: 437 [46078.003] - RdBlockLen: 9 [46078.003] - PartBlockRead: 1 [46078.003] - WrBlockMisalign: 0 [46078.004] - RdBlockMisalign: 0 [46078.004] - DSRImpl: 0 [46078.004] - Reserved2: 0 [46078.004] - DeviceSize: 1943 [46078.004] - MaxRdCurrentVDDMin: 5 [46078.004] - MaxRdCurrentVDDMax: 6 [46078.004] - MaxWrCurrentVDDMin: 5 [46078.005] - MaxWrCurrentVDDMax: 6 [46078.005] - DeviceSizeMul: 6 [46078.012] 0 root dir entries, data area commences at sector #2069. [46078.012] 123873 clusters (253691904 bytes) in data area, filesystem IDd as FAT32 [46078.013] Content of root directory: [46078.013] - MIOS [46078.013] Found 1 directory entries. [46078.013] -------------------- [46078.013] [46078.013] Checking SD Card at application layer [46078.014] ===================================== [46078.014] Deriving SD Card informations - please wait! [46079.464] SD Card: 'NO NAME ': 253 of 253 MB free [46079.464] File MBSEQ_B1.V4: doesn't exist [46079.465] File MBSEQ_B2.V4: doesn't exist [46079.465] File MBSEQ_B3.V4: doesn't exist [46079.465] File MBSEQ_B4.V4: doesn't exist [46079.465] File MBSEQ_B5.V4: doesn't exist [46079.465] File MBSEQ_B6.V4: doesn't exist [46079.465] File MBSEQ_B7.V4: doesn't exist [46079.465] File MBSEQ_B8.V4: doesn't exist [46079.465] File MBSEQ_M.V4: doesn't exist [46079.466] File MBSEQ_S.V4: doesn't exist [46079.466] File MBSEQ_G.V4: doesn't exist [46079.466] File MBSEQ_C.V4: doesn't exist [46079.466] File MBSEQ_HW.V4: doesn't exist or hasn't been re-loaded [46079.466] done.
Wow, what a really helpful tool! These are exciting times in the world of Midibox, thanks for all your hard work everyone involved in the new MIOS studio! (Now we just need to get it working over IP and we could do remote assistance of people's hardware over the net
Anyway, I get no power reset type behaviour when plugging in the SD Card when running the new MBSeqV4 beta 16 i.e. the status LED stays on.
So I guess that means the Core32 is reading the SD card fine and the problem is with the USB MSD firmware?
If I can be of any assistance with finding out why the USB MSD firmware is not working, please let me know
Otherwise consider this case closed.
Kind Regards
David
This post has been edited by monokinetic: 07 March 2010 - 23:54
#6
Posted 08 March 2010 - 00:20
the MBSEQ application uses the status LED for a different purpose, but since it's even possible to read the directory, the communication between core and SD Card seems to be ok.
Could you please try usb_mass_storage_device_v1_1.zip?
This version uses exactly the same SD Card driver like the MBSEQ release. The latest changes have been added by Phil to support MMC and HCSD - although your card seems to be a common type, it seems that the changes solve previous access problems.
If the MSD application still crashes, it will be very difficult to debug this remotely :-/
(even with a TCP/IP connection to the core ;)
#7
Posted 08 March 2010 - 22:04
TK., on 08 March 2010 - 00:20, said:
Of course. Gave it a quick try this evening, just on one computer but it seems to have the same behaviour as MSD v1.0 i.e. not recognised usb device, core resetting.
Ah well, to be honest I would rather our time goes towards something that makes noise rather than an SD Card reader
Cheers
David
#8
Posted 09 March 2010 - 19:50
[26217.108] SD Card Informations [26217.108] ==================== [26217.108] -------------------- [26217.108] CID: [26217.110] - ManufacturerID: [26217.110] - OEM AppliID: [26217.110] - ProdName: D016W [26217.110] - ProdRev: 32 [26217.112] - ProdSN: 0x097a1a00 [26217.112] - Reserved1: 6 [26217.112] - ManufactDate: 415 [26217.114] - msd_CRC: 0x18 [26217.114] - Reserved2: 1 [26217.114] -------------------- [26217.114] -------------------- [26217.116] - CSDStruct: 0 [26217.116] - SysSpecVersion: 9 [26217.116] - Reserved1: 2 [26217.118] - TAAC: 0 [26217.118] - NSAC: 50 [26217.118] - MaxBusClkFrec: 31 [26217.118] - CardComdClasses: 1432 [26217.120] - RdBlockLen: 0 [26217.120] - PartBlockRead: 1 [26217.120] - WrBlockMisalign: 1 [26217.122] - RdBlockMisalign: 1 [26217.122] - DSRImpl: 0 [26217.122] - Reserved2: 0 [26217.122] - DeviceSize: 1019 [26217.124] - MaxRdCurrentVDDMin: 7 [26217.124] - MaxRdCurrentVDDMax: 1 [26217.124] - MaxWrCurrentVDDMin: 6 [26217.126] - MaxWrCurrentVDDMax: 3 [26217.126] - DeviceSizeMul: 7 [26217.126] - EraseGrSize: 31 [26217.128] - EraseGrMul: 28 [26217.128] - WrProtectGrSize: 18 [26217.128] - WrProtectGrEnable: 0 [26217.130] - ManDeflECC: 2 [26217.130] - WrSpeedFact: 0 [26217.130] - MaxWrBlockLen: 0 [26217.130] - WriteBlockPaPartial: 0 [26217.132] - Reserved3: 0 [26217.132] - ContentProtectAppli: 0 [26217.132] - FileFormatGrouop: 1 [26217.134] - CopyFlag: 1 [26217.134] - PermWrProtect: 1 [26217.134] - TempWrProtect: 0 [26217.136] - FileFormat: 3 [26217.136] - ECC: 3 [26217.136] - msd_CRC: 0x6d [26217.136] - Reserved4: 1 [26217.138] -------------------- [26217.138] -------------------- [26217.138] Partition 0 start sector 0 (invalid type, assuming superfloppy format) [26217.140] Volume label '' [26217.140] 0 sector/s per cluster, 0 reserved sector/s, volume total 0 sectors. [26217.142] 0 sectors per FAT, first FAT at sector #0, root dir at #0. [26217.144] (For FAT32, the root dir is a CLUSTER number, FAT12/16 it is a SECTOR number) [26217.146] 0 root dir entries, data area commences at sector #0. [26217.148] 0 clusters (0 bytes) in data area, filesystem IDd as FAT12 [26217.148] Content of root directory: [26217.150] Found 0 directory entries. [26217.150] -------------------- [26217.150] [26217.150] Checking SD Card at application layer [26217.152] ===================================== [26217.152] Deriving SD Card informations - please wait! [26217.154] SD Card: '': 4294 of 0 MB free [26217.154] File MBSEQ_B1.V4: doesn't exist [26217.156] File MBSEQ_B2.V4: doesn't exist [26217.156] File MBSEQ_B3.V4: doesn't exist [26217.158] File MBSEQ_B4.V4: doesn't exist [26217.158] File MBSEQ_B5.V4: doesn't exist [26217.160] File MBSEQ_B6.V4: doesn't exist [26217.160] File MBSEQ_B7.V4: doesn't exist [26217.160] File MBSEQ_B8.V4: doesn't exist [26217.162] File MBSEQ_M.V4: doesn't exist [26217.162] File MBSEQ_S.V4: doesn't exist [26217.164] File MBSEQ_G.V4: doesn't exist [26217.164] File MBSEQ_C.V4: doesn't exist [26217.166] File MBSEQ_HW.V4: doesn't exist or hasn't been re-loaded [26217.166] done.
Which doesn't look so healthy. I replaced the card with a 2GB card and it works much better. The 16 MB card works fine in windows and in os x though.
MB6582 with 8xSSM2044 & 2xSSM2164
SammischFM
MBSEQv4
HAWK-800EX
TR9090
x0xb0x
Trummaskin 90
GM5x5x5
#9
Posted 09 March 2010 - 22:40
Can you tell us exactly what make/model/type the 16MB card is please? I guess that there is something strange about that card. It appears that it isn't being initialized properly.
There can be various causes of this, the MIOS32 driver attempts to initialize as per the SD spec but some cards deviate from the spec. I know that MicroSD cards don't "have" to support SPI mode (which is what we use) but all other cards "should" work
Cheers
Phil
#10
Posted 10 March 2010 - 00:43
Quote
FAT12 is unusual, I never tested this format with DOSFS.
However, since MBSEQ will use a new FAT driver (FatFs), there is a certain chance that the card can be successfully read with beta17
#11
Posted 10 March 2010 - 01:27
DOSFS is supposed to support FAT12/16 and 32 but as you say I have never tried it with FAT12 either....
If it doesn't work, it should be posible to reformat the disk as FAT32 I suppose?
Cheers
Phil
#12
Posted 10 March 2010 - 05:02
i still have a usb msd problem.
i am using a 4gb microSDHC.
similar to monokinetic above my led flashes then stays off.
windows reports 'usb device not recognized'.
i just updated to latest msd v1.1 and it's the same result.
only just noticed there's beta16 mbseq so i'm off to try the 'help' & 'sdcard' for more info.
s.
#13
Posted 10 March 2010 - 05:26
not sure what it all means, but i do know windows has formatted my 4gb to 128kb
and i've just tried formatting when connected via mbseq in msd mode and it only will reformat to 128kb!!!
here we go:
[1193893.687] SD Card Informations
[1193893.687] ====================
[1193893.687] --------------------
[1193893.687] CID:
[1193893.687] - ManufacturerID:
[1193893.687] - OEM AppliID:
[1193893.687] - ProdName: SD04G
[1193893.687] - ProdRev: 56
[1193893.687] - ProdSN: 0xb4013e85
[1193893.687] - Reserved1: 0
[1193893.688] - ManufactDate: 152
[1193893.688] - msd_CRC: 0x76
[1193893.688] - Reserved2: 1
[1193893.688] --------------------
[1193893.688] - CSDStruct: 1
[1193893.688] - SysSpecVersion: 0
[1193893.688] - Reserved1: 0
[1193893.688] - TAAC: 14
[1193893.688] - NSAC: 0
[1193893.688] - MaxBusClkFrec: 50
[1193893.688] - CardComdClasses: 1461
[1193893.689] - RdBlockLen: 9
[1193893.689] - PartBlockRead: 0
[1193893.689] - WrBlockMisalign: 0
[1193893.690] - RdBlockMisalign: 0
[1193893.690] - DSRImpl: 0
[1193893.690] - Reserved2: 0
[1193893.690] - DeviceSize: 0
[1193893.690] - MaxRdCurrentVDDMin: 3
[1193893.690] - MaxRdCurrentVDDMax: 5
[1193893.690] - MaxWrCurrentVDDMin: 4
[1193893.690] - MaxWrCurrentVDDMax: 1
[1193893.690] - DeviceSizeMul: 6
[1193893.690] - EraseGrSize: 31
[1193893.690] - EraseGrMul: 28
[1193893.690] - WrProtectGrSize: 0
[1193893.690] - WrProtectGrEnable: 0
[1193893.690] - ManDeflECC: 0
[1193893.690] - WrSpeedFact: 2
[1193893.692] - MaxWrBlockLen: 9
[1193893.692] - WriteBlockPaPartial: 0
[1193893.692] - Reserved3: 0
[1193893.692] - ContentProtectAppli: 0
[1193893.692] - FileFormatGrouop: 0
[1193893.692] - CopyFlag: 0
[1193893.692] - PermWrProtect: 0
[1193893.694] - TempWrProtect: 0
[1193893.694] - FileFormat: 0
[1193893.694] - ECC: 0
[1193893.694] - msd_CRC: 0x28
[1193893.694] - Reserved4: 1
[1193893.694] --------------------
[1193893.694] Partition 0 start sector 0 (invalid type, assuming superfloppy format)
[1193893.694] Volume label 'NO NAME '
[1193893.694] 1 sector/s per cluster, 6 reserved sector/s, volume total 256 sectors.
[1193893.694] 1 sectors per FAT, first FAT at sector #6, root dir at #8.
[1193893.696] (For FAT32, the root dir is a CLUSTER number, FAT12/16 it is a SECTOR number)
[1193893.696] 512 root dir entries, data area commences at sector #40.
[1193893.696] 216 clusters (110592 bytes) in data area, filesystem IDd as FAT12
[1193893.698] Content of root directory:
[1193893.698] - MBSEQ_HW.V4
[1193893.698] Found 1 directory entries.
[1193893.698] --------------------
[1193893.698]
[1193893.698] Checking SD Card at application layer
[1193893.698] =====================================
[1193893.698] Deriving SD Card informations - please wait!
[1193893.701] SD Card: 'NO NAME ': 0 of 0 MB free
[1193893.701] File MBSEQ_B1.V4: doesn't exist
[1193893.701] File MBSEQ_B2.V4: doesn't exist
[1193893.701] File MBSEQ_B3.V4: doesn't exist
[1193893.701] File MBSEQ_B4.V4: doesn't exist
[1193893.701] File MBSEQ_B5.V4: doesn't exist
[1193893.701] File MBSEQ_B6.V4: doesn't exist
[1193893.701] File MBSEQ_B7.V4: doesn't exist
[1193893.701] File MBSEQ_B8.V4: doesn't exist
[1193893.701] File MBSEQ_M.V4: doesn't exist
[1193893.701] File MBSEQ_S.V4: doesn't exist
[1193893.703] File MBSEQ_G.V4: doesn't exist
[1193893.703] File MBSEQ_C.V4: doesn't exist
[1193893.703] File MBSEQ_HW.V4: valid
[1193893.703] done.
any help?
s.
#14
Posted 10 March 2010 - 07:44
SammischFM
MBSEQv4
HAWK-800EX
TR9090
x0xb0x
Trummaskin 90
GM5x5x5
#15
Posted 10 March 2010 - 09:51
Debug messages: thats a bug, I will fix this in beta17 as well.
#16
Try reformatting using this program http://www.sdcard.or...mers/formatter/
It should reformat the card correctly... If possible I would connect the card directly to the PC (or through a USB adapter) rather than using it via mbseq.
EDIT: Make sure you turn on "FORMAT SIZE ADJUSTMENT" !
This post has been edited by philetaylor: 10 March 2010 - 09:54
#17
Posted 10 March 2010 - 14:04
OK, I'll wait and try it out in beta17!
SammischFM
MBSEQv4
HAWK-800EX
TR9090
x0xb0x
Trummaskin 90
GM5x5x5
#18
Posted 13 March 2010 - 09:06
[39114.704] SD Card Informations
[39114.704] ====================
[39114.705] --------------------
[39114.705] CID:
[39114.705] - ManufacturerID:
[39114.705] - OEM AppliID:
[39114.707] - ProdName: D016W
[39114.707] - ProdRev: 32
[39114.707] - ProdSN: 0x097a1a00
[39114.707] - Reserved1: 182
[39114.709] - ManufactDate: 415
[39114.709] - msd_CRC: 0x18
[39114.709] - Reserved2: 1
[39114.710] --------------------
[39114.738] - CSDStruct: 0
[39114.738] - SysSpecVersion: 9
[39114.738] - Reserved1: 2
[39114.738] - TAAC: 0
[39114.738] - NSAC: 50
[39114.738] - MaxBusClkFrec: 31
[39114.738] - CardComdClasses: 1432
[39114.738] - RdBlockLen: 0
[39114.738] - PartBlockRead: 1
[39114.738] - WrBlockMisalign: 1
[39114.738] - RdBlockMisalign: 1
[39114.738] - DSRImpl: 0
[39114.738] - Reserved2: 0
[39114.738] - DeviceSize: 1019
[39114.738] - MaxRdCurrentVDDMin: 7
[39114.738] - MaxRdCurrentVDDMax: 1
[39114.738] - MaxWrCurrentVDDMin: 6
[39114.738] - MaxWrCurrentVDDMax: 3
[39114.738] - DeviceSizeMul: 7
[39114.738] - EraseGrSize: 31
[39114.738] - EraseGrMul: 28
[39114.738] - WrProtectGrSize: 18
[39114.738] - WrProtectGrEnable: 0
[39114.738] - ManDeflECC: 2
[39114.738] - WrSpeedFact: 0
[39114.738] - MaxWrBlockLen: 0
[39114.738] - WriteBlockPaPartial: 0
[39114.738] - Reserved3: 0
[39114.738] - ContentProtectAppli: 0
[39114.738] - FileFormatGrouop: 1
[39114.738] - CopyFlag: 1
[39114.738] - PermWrProtect: 1
[39114.738] - TempWrProtect: 0
[39114.738] - FileFormat: 3
[39114.738] - ECC: 3
[39114.738] - msd_CRC: 0x6d
[39114.738] - Reserved4: 1
[39114.738] --------------------
[39114.738] Failed to open root directory - error status: 13
[39114.738]
[39114.738] Checking SD Card at application layer
[39114.738] =====================================
[39114.738] SD Card: Invalid FAT
[39114.738] File MBSEQ_B1.V4: doesn't exist
[39114.738] File MBSEQ_B2.V4: doesn't exist
[39114.738] File MBSEQ_B3.V4: doesn't exist
[39114.740] File MBSEQ_B4.V4: doesn't exist
[39114.740] File MBSEQ_M.V4: doesn't exist
[39114.742] File MBSEQ_S.V4: doesn't exist
[39114.742] File MBSEQ_G.V4: doesn't exist
[39114.744] File MBSEQ_C.V4: doesn't exist
[39114.744] File MBSEQ_HW.V4: doesn't exist or hasn't been re-loaded
[39114.746] done.
SammischFM
MBSEQv4
HAWK-800EX
TR9090
x0xb0x
Trummaskin 90
GM5x5x5
#19
Posted 13 March 2010 - 12:51
FatFs reports error status 13, which stands for invalid file system.
So, neither FatFs nor DosFs are able to read this SD Card, therefore no hope for this strange format.
Phil prepared a new application which allows to format SD Cards, you could beta test this one.
#20
Posted 13 March 2010 - 14:43
Quote
The updated app is in the trunk/apps/troubleshooting/sdcard_tools directory of svn.
If you don't have the build environment setup, please let me know and I will send you the hex file.
It uses the MIOS_Studio 2.0 console to send simple commands to sdcard_tools which allow dir, cd, mkdir, rename and format. Please be aware that the format doesn't currently ask for ANY confirmation, it just does it!
I am working on the file copy routine at the moment, it should be completed later todaym
Cheers
Phil
Help
