downerczx Posted January 3, 2011 Report Share Posted January 3, 2011 I was happily using my sammichSID the other day jamming out with a friend. Then, today I tried to power it up, and... nothing. I checked the power supply (12V 500ma regulated enercell from radio shack) and I only get 6VDC. I don't get anything on AC. Does this sound correct or should it be reading 12V? thanks. Quote Link to comment Share on other sites More sharing options...
phunk Posted January 3, 2011 Report Share Posted January 3, 2011 (edited) I was happily using my sammichSID the other day jamming out with a friend. Then, today I tried to power it up, and... nothing. I checked the power supply (12V 500ma regulated enercell from radio shack) and I only get 6VDC. I don't get anything on AC. Does this sound correct or should it be reading 12V? thanks. You should get exactly 12V out of a regulated DC powersupply. They often have little switches where you can "dial in" the voltage needed. It might be you accidently moved them to the 6V setting... Edited January 3, 2011 by phunk Quote Link to comment Share on other sites More sharing options...
downerczx Posted January 3, 2011 Author Report Share Posted January 3, 2011 It doesn't have any switches. I wonder if something failed in the unit. I guess I'll take it back to Radio Shack. Quote Link to comment Share on other sites More sharing options...
Wilba Posted January 3, 2011 Report Share Posted January 3, 2011 Are you sure that power supply isn't switchmode? I thought the enercell ones were switchmode, and would make a lot of noise on the audio. Quote Link to comment Share on other sites More sharing options...
downerczx Posted January 3, 2011 Author Report Share Posted January 3, 2011 (edited) It's this one: http://www.radioshack.com/product/index.jsp?productId=3832491 is there a possibility it won't show 12V unless there is a load on it? Edited January 3, 2011 by downerczx Quote Link to comment Share on other sites More sharing options...
technobreath Posted January 3, 2011 Report Share Posted January 3, 2011 I thought the whole point with a regulated supply was to keep the voltage constant no matter what load is on it unless you overload it or something... I would take it back to the shack. Quote Link to comment Share on other sites More sharing options...
Starfire Posted January 3, 2011 Report Share Posted January 3, 2011 I'm using this one: http://www.allelectronics.com/make-a-store/item/PS-1251/12-VDC-500-MA-REGULATED-POWER-SUPPLY//1.html 12.16 out under no-load and 12.09 under load, can't complain, cheap too! Quote Link to comment Share on other sites More sharing options...
downerczx Posted January 6, 2011 Author Report Share Posted January 6, 2011 Well, they swapped it for a new one. It measures a healthy 14V with the meter and now the Sammich powers up fine! Quote Link to comment Share on other sites More sharing options...
