jensah Posted March 7, 2011 Posted March 7, 2011 Hello Trying to figure out how to make a simple adapter for the 2 LCD:s that's needed for the LC, since the pinout is completely different, did anyone make a adapter card for it or what? I'm thinking of making a perfboard with a ribbon cable in and do as in the tutorial document and 2 ribbon cables out with the correct pinout. Does anyone have a simpler solution?
nebula Posted March 7, 2011 Posted March 7, 2011 Rectangular housings and crimp pins, similar to this: http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=WM2525-ND You crimp the pins to the end of individual wires, then push the pins into the housing. The result is a connector which will mate with a multi-pin header. You could create adapter cables for each type of LCD. You would need to solder a header (optionally right-angle) to the LCD.
julienvoirin Posted March 8, 2011 Posted March 8, 2011 (edited) the LCDs share the same pins, except for 1 wire, being the adress so the best is to do what's done for harddrives in computer : ribbon cable. just isolate the adress wire and it is OK connector is the following http://radiospares-fr.rs-online.com/web/1927350.htmlHE10 Rq : if pinout of LCD and Core differ, just rearrrange order on Core's connector , it is easier than rearranging on each LCD !! (i did this on my seq v2) Edited March 8, 2011 by julienvoirin
