Sign in to follow this
Followers 0
arti492
Roland tr707 - broken sequencer
6 posts in this topic
I have a roland tr-707 with broken sequencer and midi.
Sounds are triggered by buttons, but not by the sequencer.
It's possible to connect mb808 with roland tr-707 but not per midi??
Edited by arti492
Share this post
Link to post
Share on other sites
Is the DIN Sync still functional?
Share this post
Link to post
I don't know.
Edited by arti492
Share this post
Link to post
did you try to reinitialize it? (HOLD TRACK WRITE AND PATTERN A AND POWER ON)
If reinitialisation is impossible, you can check Ram soldering (IC14 et IC15)if you don' t see any problem, resolder them
I had the same problem and after resolder ram and reinitialize, it works now.
good luck!
Edited by matoz
Share this post
Link to post
Thans, i will check it. :)
Edited by arti492
Share this post
Link to post
So, did you put it in step mode? ie, take it out of song mode.
(It's song & patterns will be full of garbage with no batteries installed, or if they are flat / been missing etc)
The amount of times i've bought 707's & 727's that people said were not working, but it was just in the wrong mode? about 4 times.
Share this post
Link to post
Followers 0
