schoko Posted September 11, 2003 Report Posted September 11, 2003 After finishing the module i want to try it out, but nothing happen....It should be workin as standalone....Then i tried to search the error, i measured the supply voltageon the AN2131SC, the eeprom, all other ics have power everything fine...I also checked the diodes (all 3) seems fine too...Midi in reacts when a midi device is plugged in( the midi in leds are blinking)Can anyone help plz?
TK. Posted September 12, 2003 Report Posted September 12, 2003 Which operating system are you using?It should regognize the new USB device immediately after you plugged it into the socket. If not, there must be a bad junction between the USB pins of the cypress chip and the socket. Check also the crystal and the reset inputs.Best Regards, Thorsten.
schoko Posted September 15, 2003 Author Report Posted September 15, 2003 I soldered all contacts again..... still nothing happen...how can i determine if the crystal is allright?I measured about 1,5 V on the crystal is that o.k.?Its my only chance to get it run i couldnt figure out any errors, all pins have contacts to the pcb, as far as i can measure it with my voltmeter.....how can i check the reset inputs?i am using xpthx in advance
TK. Posted September 15, 2003 Report Posted September 15, 2003 Unfortunately the crystal can only be checked with a scope...the frequency is too high to get a meaningful value on a common multimeter.Reset: it sends a short +3.3V pulse during power-on and should be low (0V) thereafter.Did you every use a USB device with your PC? On some mainboards not all USB plugs are enabled by default, maybe you only have to change this in your BIOS setup.Best Regards, Thorsten.
schoko Posted September 15, 2003 Author Report Posted September 15, 2003 thx for your quick reply...i have enabled the usb ports in the bios..it was the first thing i did...I guess the short 3,3v impuls on the reset button cant also be measured by a multimeter...but i think i measured a voltage of 3,3v all the time, notsure have to check it again...if thats the case (always 3,3) what to do?is this then caused by bad soldering? Means itcant reset the usb chip at startup?Hopefully not would be a difficult task to fullfill
TK. Posted September 15, 2003 Report Posted September 15, 2003 but i think i measured a voltage of 3,3v all the timeSure, this is definitely the error. The USB chip is permanently in reset state and therefore doesn't start.Just take a look into the schematic http://www.ucapps.de/mbhp/mbhp_usb.pdf for the supply voltages of the cap and the resistor. Note: If the resistor or the cap isn't tied to Vss/Vdd, possibly also other components are affected. Just follow the Vss/Vdd tracks with your multimeter to find the bad junctions.Best Regards, Thorsten.Addendum: the AN2131SC has a high-active reset, the PIC a low-active reset. This means: if you notice that the PIC doesn't run, check that the reset input MRST# of the PIC is on 5V level, and not 0V like for the AN2131SC
schoko Posted September 16, 2003 Author Report Posted September 16, 2003 Still doesnt work...i measured 3.3v (Vcc - reset) and 10 kOhm reset to Vssall the time....the function should be a short impuls...the wiring is ok... i checked out everything, means theonly thing i finaly could do now is checking a new crystalor measuring it with a scope.......(badly that i can hardly check that out)Cond. C3 couldnt unload....thats the faultIs that this correct?
TK. Posted September 17, 2003 Report Posted September 17, 2003 You could unsolder the resistor and capacitor and test them as RC circuit (+3.3V -> C -> R -> ground) just to ensure that they are not damaged (but the probability that you have fried them is very low). The voltage between C and R must be 0V after < 1 second (you won't regognize the pulse...)If these parts are ok, the only reason why you see 3.3V would be that you've soldered the USB chip in the wrong direction...Best Regards, Thorsten.
schoko Posted September 18, 2003 Author Report Posted September 18, 2003 To finally complete this, for the information and to getto the next trouble, i removed c3 and r27, then the module got recognised...under w98 i can choose the supplied driver, but for win xp (@sp1)when i choose the driver (archive 1_1)then i got the message, that there hasnt been found any hardware....the driver doesnt work........so another time i need any help plz
TK. Posted September 19, 2003 Report Posted September 19, 2003 Hi,alright, but you should try to find the hardware related problem with the reset pin sooner or later to avoid random reset pulses which can crash or hangup your windows (as the M$ driver is extreme unstable)Could you please check if the EZ driver from the http://www.ucapps.de/mbhp/mbhp_usb_v1_0.zip works better? I don't mean the driver in the mbhp_usb\ subdirectory (here you should use v1.1), but the wintendo driver for EZ-USB under ez-usb\driver\Best Regards, Thorsten.
schoko Posted September 22, 2003 Author Report Posted September 22, 2003 Just tested it out and it works under xp, but the driver problem is the same then before ( the link u gave linksto v1_1 not 1_0.. just for the records)i managed it to install it under win98 se, then i load up the firmware, and then it works under xp too...like u describe it, the important thing was to burn the eeprom...The reset problem was the c3 cond..he decided to rest in peace........just to inform you and maybe other ppls who maybe get or got similar probs...thx for your support....the next midi project is waitingschoko
pay_c Posted September 23, 2003 Report Posted September 23, 2003 Thnx for that. Just finished my MIDI Int, too. I ran into the same problem: Win XP does not accept that EZ USB driver and so the EZ Control Panel does not recognize the chip. I'll try too burn it under Win2000.
pay_c Posted September 24, 2003 Report Posted September 24, 2003 The same prob at my house: The device is not recognized by WinXP nor by Win2000. Better said: It is recognized&installed, but the driver does not work (Win does not install it - something missing?).So the EZ Manager does not get connection to the device.I dont think that I soldered anything wrong (I also have experiences with SMD soldering). All LEDs are coming up normal, the USB conn works fine and so on. I do think its a software prob as stated above.As I dont have access to a Win98 PC to burn the EEPROM, what can I do?btw: Isnt that funny? That thing can only be programmed under Win98 (or others), but wont run on that OS. On the other hand it will run under Win2k/XP but there you cant burn it! ... weird ... :P ::)
d2k Posted September 24, 2003 Report Posted September 24, 2003 I programmed the usb module AND use it exclusivly in XP and I had no probs - once all the connections were A-OK the firmware burnt fine, and XP recognised it no prob...
TK. Posted September 25, 2003 Report Posted September 25, 2003 MIOS V1.4 will provide a function to read from/write into a BankStick (24LCxx and 24LCxxx) directly via MIDI. This means, that you will be able to burn the MBHP_USB firmware via a MIOS core. And btw.: it will also open the possibility to clone a MIDIsport 2x2, of course only for the people who already own this MIDI interface.Best Regards, Thorsten.
pay_c Posted September 26, 2003 Report Posted September 26, 2003 ???It worked under XP? Weird... Gotta try that again. Perhaps on another computer...That with MIOS: YES!!! Really really cool news again, TK.
LO Posted September 27, 2003 Report Posted September 27, 2003 HiUSB module finished Plug it in and yes it is found however when I go through the new hardware wizard it starts installing but stops and reports the following error:An error occurred during the installation of the deviceA service installation in this INF is invalid :(Im guessing this is a similar error to that which other are reporting?I have tried installing many times and every time the same error. Im using Windows XP service pack 1Ill try with win98 sometime soon?Any ideas?peaceLO
d2k Posted September 27, 2003 Report Posted September 27, 2003 dunno if any of u seen this thread:http://www.midibox.org/cgi-bin/yabb/YaBB.cgi?board=troubleshooting;action=display;num=1059601633lists some probs/way i done shit whilst gettin the usb module to work in XP a while back - dunno if it may elp yas...BestDan
LO Posted September 28, 2003 Report Posted September 28, 2003 thanks for the tips however I am still havin probsI cant seem to get: version 1.0 the link still seems to point to ver 1.1 it would be nice to be able to try this stuff on me own PCSo I tried it on another PC Win 98 yay it lets me install the ezUSB driver. but once it is installed I still can not seem to burn the ChipSince I am using an 24LC256 instead of the 24LC64 is there anything I need to change in the settings of the control panel?I also notice that the power led does not have enough grunt to light the led i.e. I can measure only 1v but I have checked all the ICs and they measure the correct voltage ie 5v or 3.25-3.3v and earths seem OK.getting desperate........ThanksLO
TK. Posted October 2, 2003 Report Posted October 2, 2003 Could somebody of you please check if one of these drivers is working under XP:http://www.ucapps.de/tmp/cypress_drivers.zipthe .inf file is located in the root directory, the .sys files can be found under */lib/i386/free/*.sysBest Regards, Thorsten.
LO Posted October 2, 2003 Report Posted October 2, 2003 No I still had probs I guess its just my setup ???
pay_c Posted December 8, 2003 Report Posted December 8, 2003 At laaaast: It´s working. :)I had to install the drivers on an old Win98 Comp (the WinXP one always had probs with the driver "Deinstallation routine incorrect" or similar). But: Then it didn´t work there (no idea why). Back on the WinXP comp and voila: It worked.So: I had to install the firmware on Win 98 to get it running on WinXP. Just for the records and for those guys, who didn´t get it running up to now.Greets
