xarolium Posted July 20, 2011 Report Posted July 20, 2011 Dear Midiboxer, Since the server change i couldn't open the Midibox.org page with my computer I try to delete passeword saved on Mozilla but nothing change Please could you help me? Thank you Xarolium Quote
Hawkeye Posted July 20, 2011 Report Posted July 20, 2011 (edited) Hi, probably you´ve made some host entries last year, when the DNS server was down? It will still direct you back to the old IP address, which will not work anymore. Best regards, Peter Edited July 20, 2011 by Hawkeye Quote
jojjelito Posted July 20, 2011 Report Posted July 20, 2011 No entries in the hosts file at home, but it still won't direct me the right way. Wonder if my ISP is just slow on updating the DNS? It works at the office oddly enough. Quote
julienvoirin Posted July 20, 2011 Report Posted July 20, 2011 Well, the error is exactly what I told you... fix your /etc/hosts file!!! Remove the last line: 78.129.178.152 midibox.org www.midibox.org wiki.midibox.org svnmios.midibox.org forum.midibox.org because this IP isn't valid anymore! You added this line last year during the last server move. Best Regards, Thorsten. Am 16.07.2011 um 05:41 schrieb Julien VOIRIN: MacBook-de-Julien-VOIRIN:~ julienvoirin$ cat /etc/hosts ## # Host Database # # localhost is used to configure the loopback interface # when the system is booting. Do not change this entry. ## 127.0.0.1 localhost 255.255.255.255 broadcasthost ::1 localhost fe80::1%lo0 localhost 78.129.178.152 midibox.org www.midibox.org wiki.midibox.org svnmios.midibox.org forum.midibox.org MacBook-de-Julien-VOIRIN:~ julienvoirin$ I tried with my G5 and it works ; there is not the ip of midibox how do i change that stuff ? and what is that for ? is it relevant to the svn ?? sorry to make you loose your time, i am definitly not an expert with computer OS very best regards Quote
xarolium Posted July 22, 2011 Author Report Posted July 22, 2011 Thank you for your help Problem Solved Quote
