Problem acces Midibox.org
xarolium
probably you´ve made some host entries last year, when the DNS server was down?
It will still direct you back to the old IP address, which will not work anymore.
Best regards,
Peter
Edited by Hawkeye
Well, the error is exactly what I told you... fix your /etc/hosts file!!!
Remove the last line:
78.129.178.152 midibox.org www.midibox.org wiki.midibox.org svnmios.midibox.org forum.midibox.org
because this IP isn't valid anymore!
You added this line last year during the last server move.
Am 16.07.2011 um 05:41 schrieb Julien VOIRIN:
MacBook-de-Julien-VOIRIN:~ julienvoirin$ cat /etc/hosts
# Host Database
# localhost is used to configure the loopback interface
# when the system is booting. Do not change this entry.
127.0.0.1 localhost
255.255.255.255 broadcasthost
::1 localhost
fe80::1%lo0 localhost
I tried with my G5 and it works ; there is not the ip of midibox
how do i change that stuff ? and what is that for ? is it relevant to the svn ??
sorry to make you loose your time, i am definitly not an expert with computer OS
very best regards
