  • Replies 52
  • Created
  • Last Reply
Top Posters In This Topic
Ok, i have to cut the pots like when you used knobs provided in ladyada kit, few years ago ;-)
But the diameter is ok. In that case i'm interested !
Edited by kroutshev
Ok,
Here is the scoop:
"Selco only has stock on one part no. in the 3/04 series.
It is 3/04DRP110-006, gray body, black pointer, line at 90 degrees from flat.
We have an obsolete trio knob that has three colors- gray/black/aqua or gray/black/yellow.
DRN110-006 is in stock.
DR111 gray and black are not in stock.
C111 caps in all colors are in stock."
They have the DR110 006 and all color caps 0,58$ for the knob 0,33$ for the cap
And they have these things for 0.50$ ea
Edited by Altitude
Oooh, finally a chance to acquire some cool knobs in 3-shot. Are those hard finish only? Never mind. They look cool!
Those 3-shot are actually 4/04/DR 110 006 for the d-shaft and 4/04/TP110 006 for the spline shaft. Gotta give this a short ponder before PM:ing later tonite...
All of a sudden I wanted in. Dangnabbit! :frantics:
I'm assuming they are D shaft. The colors she says they have is gray/black/aqua and gray/black/yellow
the 3/04 parts they have limited stock of are $0.75 ea
BOTH the DR110 and DRN110 parts are 0.58 ea plus 0.33 for the cap
Edited by Altitude
D-shaft only... No matter, just on a whim I'll take 50 4/04/DR 110 006 of each color or until the stock is gone.
/J
Edited by jojjelito
Ok Altitude,
i'm not sure about two colour soft touch collets, they are used in x0xi0 kit and i have asked Brian to be sure about reference.
I suppose that's 3/02/S151 006 Pointer close to shaft. About these knobs do you if i need to order caps or it's already include ? i need those which caps are removable to mount them in the "Bank and Mode selection" x0xb0x potentiometers.
I don't know if i must order about shaft size 6 mm or 1/4 in ?
[Edit]
Ok confirmation from Brian,
3/02/S151 250 quantity = 20
About caps color and quantity reference C151
red 4
Orange 4
Green 4
Blue 4
Yellow 4
The others one i need : 3/04/DRP110 006 and pointer close to flat, Black Body
Quantity and colors for Pointer :
Red 16
Orange 16
Green 16
Blue 16
Yellow 16
If you have advise for x0xb0x use i'm very interested in case i have made a mistake.
Thanks a lot.
K.
Edited by kroutshev
kroutshev,
Please read my post about what they have stocked, none of the items you indicated are in stock and require a 500 pcs minimum order
YAY!
I looked into the pdf catalogue and did not see these because they aren't in there. They look even better than the 3/04 :)
Only thing is that i can't find these knobs with Grey Base/Black Middle and Red pointer????!!!!!
So my actual wishlist is:
50 RED (if they are available)
50 4/04/DR110 006/26 DK GREY091/BLACK005/BRIGHT GREEN127
50 4/04/DR110 006/26 DK GREY091/BLACK005/BRIGHT AQUA128
50 4/04/DR110 006/26 DK GREY091/BLACK005/MAGENTA129
50 4/04/DR110 006/26 DK GREY091/BLACK005/ORANGE023
50 4/04/DR110 006/26 DK GREY091/BLACK005/YELLOW010
Total: 300
50 DRN110 006/26 BLK
50 C110
please let me know if it's possible :)
Edited by lameth
100 x DRD151 006
partnumber is: DRD157 006/26 BLK
please send a me the price , before you order
Edited by DSL-man
Hi Altitude,
Ok in that case i'd like to order knobs which are for 0.50 ea, fussy knobs with Grey Base/Black Middle and Red pointer
I need 80 of them.
And about "3/02/S151 250" knobs, i have read that i can order 10 minimum.
I need 20 of them with C151 caps in red.
Please could you tell me if i'm right ?
Thanks a lot.
K.
DSL: I'll email them and see if they have those. I'll just ask what they have in D shaft so I dont have to keep emailing them
Kroutshev: Not sure where you read that, I am dealing with Sifam's distributor in the US (Selco Products). Anything that they do not have in inventory (which is pretty limited by the looks of it) is a special order item with a 500 or 1000 piece minimum order and 10 week lead time
DRN110 are available, all the other stuff is special order other than what I mentioned above
So from all your postings i get that the only option is the DRN110 with color caps because all the 3/04 k_3_04_DRP110.gif and 4/04 k_4_04_DR110.gif are only on order with minimum quantity of 500? That's bad :( (except we get this much orders!)
I will wait for your post what they have available in D-Shaft and on stock before i bug you with questions about the other possible Knobs ;)
This is where i have read that => http://www.sifam.com/knobDetails.asp?kType=Knobs_Collet&Type=3_02_S151
Base diameter: 15.5 (mm)
Height (inc cap): 14.3 (mm)
Shaft Depth: 7 (mm)
2 Colour: Y
Pack size: 10 pcs
And about fussy one 0.5$ ea, are they available ? and i need pointer close to shaft, is it ok ?
Thanks.
Bruno
I am not in Europe so I cannot deal directly with Sifam, just their US distributor so anything you see on the Sifam site does not really apply (other than what style knobs the have). http://catalog.selcoproducts.com/category/conventional-push-on-knobs
I put a request in for a list of whats in stock so we dont have to do this "do they have this or that?" thing anymore
Edited by Altitude
Yes i think that's the best thing to do !
Thanks for your patience Altitude. If I'm not too late ...
50 x DR110 006
Caps (colour / pointer):
15 red / white
35 white / black
10 black / white
10 black / no pointer
... and I would also take 25 of those black/grey/red oddballs if there are any left.
