Sifam Knobs Bulk order #2
Altitude
  • Replies 52
  • Created
  • Last Reply
Top Posters In This Topic
Ok,
Here is the scoop:
"Selco only has stock on one part no. in the 3/04 series.
It is 3/04DRP110-006, gray body, black pointer, line at 90 degrees from flat.
We have an obsolete trio knob that has three colors- gray/black/aqua or gray/black/yellow.
DRN110-006 is in stock.
DR111 gray and black are not in stock.
C111 caps in all colors are in stock."
They have the DR110 006 and all color caps 0,58$ for the knob 0,33$ for the cap
And they have these things for 0.50$ ea
Edited by Altitude
Link to comment
Share on other sites
Oooh, finally a chance to acquire some cool knobs in 3-shot. Are those hard finish only? Never mind. They look cool!
Those 3-shot are actually 4/04/DR 110 006 for the d-shaft and 4/04/TP110 006 for the spline shaft. Gotta give this a short ponder before PM:ing later tonite...
All of a sudden I wanted in. Dangnabbit! :frantics:
Link to comment
I'm assuming they are D shaft. The colors she says they have is gray/black/aqua and gray/black/yellow
the 3/04 parts they have limited stock of are $0.75 ea
BOTH the DR110 and DRN110 parts are 0.58 ea plus 0.33 for the cap
Edited by Altitude
Link to comment
Ok Altitude,
i'm not sure about two colour soft touch collets, they are used in x0xi0 kit and i have asked Brian to be sure about reference.
I suppose that's 3/02/S151 006 Pointer close to shaft. About these knobs do you if i need to order caps or it's already include ? i need those which caps are removable to mount them in the "Bank and Mode selection" x0xb0x potentiometers.
I don't know if i must order about shaft size 6 mm or 1/4 in ?
[Edit]
Ok confirmation from Brian,
3/02/S151 250 quantity = 20
About caps color and quantity reference C151
red 4
Orange 4
Green 4
Blue 4
Yellow 4
The others one i need : 3/04/DRP110 006 and pointer close to flat, Black Body
Quantity and colors for Pointer :
Red 16
Orange 16
Green 16
Blue 16
Yellow 16
If you have advise for x0xb0x use i'm very interested in case i have made a mistake.
Thanks a lot.
K.
Edited by kroutshev
Link to comment
YAY!
I looked into the pdf catalogue and did not see these because they aren't in there. They look even better than the 3/04 :)
Only thing is that i can't find these knobs with Grey Base/Black Middle and Red pointer????!!!!!
So my actual wishlist is:
50 RED (if they are available)
50 4/04/DR110 006/26 DK GREY091/BLACK005/BRIGHT GREEN127
50 4/04/DR110 006/26 DK GREY091/BLACK005/BRIGHT AQUA128
50 4/04/DR110 006/26 DK GREY091/BLACK005/MAGENTA129
50 4/04/DR110 006/26 DK GREY091/BLACK005/ORANGE023
50 4/04/DR110 006/26 DK GREY091/BLACK005/YELLOW010
Total: 300
50 DRN110 006/26 BLK
50 C110
please let me know if it's possible :)
Edited by lameth
Link to comment
Hi Altitude,
Ok in that case i'd like to order knobs which are for 0.50 ea, fussy knobs with Grey Base/Black Middle and Red pointer
I need 80 of them.
And about "3/02/S151 250" knobs, i have read that i can order 10 minimum.
I need 20 of them with C151 caps in red.
Please could you tell me if i'm right ?
Thanks a lot.
K.
Link to comment
DSL: I'll email them and see if they have those. I'll just ask what they have in D shaft so I dont have to keep emailing them
Kroutshev: Not sure where you read that, I am dealing with Sifam's distributor in the US (Selco Products). Anything that they do not have in inventory (which is pretty limited by the looks of it) is a special order item with a 500 or 1000 piece minimum order and 10 week lead time
Link to comment
DRN110 are available, all the other stuff is special order other than what I mentioned above
So from all your postings i get that the only option is the DRN110 with color caps because all the 3/04 k_3_04_DRP110.gif and 4/04 k_4_04_DR110.gif are only on order with minimum quantity of 500? That's bad :( (except we get this much orders!)
I will wait for your post what they have available in D-Shaft and on stock before i bug you with questions about the other possible Knobs ;)
Link to comment
This is where i have read that => http://www.sifam.com/knobDetails.asp?kType=Knobs_Collet&Type=3_02_S151
Base diameter: 15.5 (mm)
Height (inc cap): 14.3 (mm)
Shaft Depth: 7 (mm)
2 Colour: Y
Pack size: 10 pcs
And about fussy one 0.5$ ea, are they available ? and i need pointer close to shaft, is it ok ?
Thanks.
Bruno
I am not in Europe so I cannot deal directly with Sifam, just their US distributor so anything you see on the Sifam site does not really apply (other than what style knobs the have). http://catalog.selcoproducts.com/category/conventional-push-on-knobs
I put a request in for a list of whats in stock so we dont have to do this "do they have this or that?" thing anymore
Edited by Altitude
Link to comment
Guest
Reply to this topic...
