FantomXR Posted August 24, 2015 Posted August 24, 2015 (edited) Hey,sometimes especially when doing a glissando I get stucking notes. I can avoid this by using MIDIbox NG and set the number of shift registers to a higher value f.e. 6 or 8. But this on the other side lowers the velocity-resolution and I normally want to use the KB app for the keyboard. Do you have also those problems? I have that with different keybeds (all FATAR).And another question: MIDIbox KB features an option that is named ain_bandwidth. I can not see such kind of option in NG. May I overlook something? Because: If I connect a expression pedal to my NG, play the keyboard and move this pedal, I get also a lot of stucking notes. I think that the DAW (or the NG-app) is stressed too much because of all this informations.Thanks! Edited August 24, 2015 by FantomXR
nlate Posted August 25, 2015 Posted August 25, 2015 (edited) Hey,sometimes especially when doing a glissando I get stucking notes. I can avoid this by using MIDIbox NG and set the number of shift registers to a higher value f.e. 6 or 8. But this on the other side lowers the velocity-resolution and I normally want to use the KB app for the keyboard. Do you have also those problems? I have that with different keybeds (all FATAR). Edited August 25, 2015 by nlate reply
nlate Posted August 25, 2015 Posted August 25, 2015 Hi ChristianI got the same issue during testing of my modifications of the code. Imho the reason for that is caused by the debouncing routines in the fct: KEYBOARD_NotifyToggle() e.g. the code... // debounce processing if( kc->scan_velocity ) { if ( !kc->scan_release_velocity ) { .... }The routine doesn´t check all possible states, which could occure if the naked keybed is just played on a table. During glissandos some keys can bounce back so quickly that they accidently retrigger the make contact.This effect is minimized on buildin keybeds by the (red) felt strip at the backend and near the turning point of the keys.My code with the modified debounce check is a) not error-free and b) not in a publishable condition.So I can´t fix your issue a.t.m.Sorry and regards,Jo
FantomXR Posted August 31, 2015 Posted August 31, 2015 Hey!I'm not sure if this is really the reason for the stucking notes because a note is normally not triggered when just the make contact is active. Also the break contact needs to be active to create a note on.I think it's more a problem due to the inverted diodes on the keybed. I need to set din_inverted to 1 if I want to use this keybed (it's an old Fatar TP/8S from a Roland A70). I also discovered, that the velocity-resolution is much lower on din_inverted 1 as on other boards which don't have the inverted diodes. It get's even more dramatic when using NG instead of KB. In NG I have only about 10 velocity steps with this keybed....I checked the schematic of the keybed and it should be possible to simply cut and turn the diodes so I can use din_inverted 0. Maybe this solve those issues.Thanks,Chris
norbim1 Posted September 1, 2015 Posted September 1, 2015 Hi Chris,I built a custom keyboard with inverted diodes, and had the same issue in NG. The solution was a massive rewriting on the nlate mentioned debounce processing code. It works now perfectly without any stacking notes. I will upload my modified routines to the playground as I get close to my PC.Norbim 1
FantomXR Posted September 1, 2015 Posted September 1, 2015 Hi Chris,I built a custom keyboard with inverted diodes, and had the same issue in NG. The solution was a massive rewriting on the nlate mentioned debounce processing code. It works now perfectly without any stacking notes. I will upload my modified routines to the playground as I get close to my PC.NorbimThis sounds awesome!! Thanks!
norbim1 Posted September 1, 2015 Posted September 1, 2015 Sorry I cant upload at the moment to my playground, but attached the diff. I modified the keyboard.c only in modules/keyboard. Here is my keyboard spec from the NGC file:# keyboard configurationKEYBOARD n=1 rows=10 dout_sr1=1 dout_sr2=2 din_sr1=1 din_sr2=2 din_inverted=1 break_inverted=1 din_key_offset=32 scan_velocity=1 scan_optimized=0 note_offset=0 make_debounced=1 delay_fastest=20 delay_fastest_black_keys=0 delay_slowest=500Hope this helps.Norbim keyboard.c.diff
FantomXR Posted September 1, 2015 Posted September 1, 2015 Hey,thanks for the file! I'll try to compile the app tomorrow! I'll keep you posted.Best,Chris
FantomXR Posted September 2, 2015 Posted September 2, 2015 (edited) Sorry I cant upload at the moment to my playground, but attached the diff. I modified the keyboard.c only in modules/keyboard. Here is my keyboard spec from the NGC file:# keyboard configurationKEYBOARD n=1 rows=10 dout_sr1=1 dout_sr2=2 din_sr1=1 din_sr2=2 din_inverted=1 break_inverted=1 din_key_offset=32 scan_velocity=1 scan_optimized=0 note_offset=0 make_debounced=1 delay_fastest=20 delay_fastest_black_keys=0 delay_slowest=500Hope this helps.Norbim keyboard.c.diffHey!I checked that and compiled it. I have the problem that no Note Off is send when I release a key. Any suggestions? //edit: Okay. I did "set kb 1 release_velocity on" and it works ;) Thank you very much! I wonder if I can disable the release-velocity because I don't use it. But like I said. If I switch it off, there will be no note-offs generated :(Ah! Now I understand. There are two options:1.) Set release-velocity on, set make-debounced off: High velocity-resolution but sometimes notes will send a velocity value of 1 when pressed (even when it's pressed much harder). This behaviour is random!2.) Set release-velocity off, set make-debounced on: Lower velocity-resolution, but all notes play like they should. Edited September 2, 2015 by FantomXR
norbim1 Posted September 2, 2015 Posted September 2, 2015 (edited) Yes, the code was worked out for the second case only, because I need only this option. I know it is not an universal solution, even I'm sure it will not work with non inverted diodes. I soldered my diodes the wrong way by mistake, and it was easier to alter the code than change 138 diodes....One thing that surely works in NG is break_is_make on for organ style playing. Edited September 2, 2015 by norbim1
FantomXR Posted September 2, 2015 Posted September 2, 2015 Okay! Thanks for the code! This is definitely better than before :-)maybe TK will spend a bit time on this and can improve the app if we kindly ask him ;-)
FantomXR Posted September 17, 2015 Posted September 17, 2015 (edited) @norbim1: Which values do you use for SRIO num_sr= and debounce-cycle? Edited September 17, 2015 by FantomXR
norbim1 Posted October 13, 2015 Posted October 13, 2015 Sorry for the late answer:SRIO num_sr=2 debounce_cycles=0# keyboard configurationKEYBOARD n=1 rows=10 dout_sr1=1 dout_sr2=2 din_sr1=1 din_sr2=2 din_inverted=1 break_inverted=1 din_key_offset=32 scan_velocity=1 scan_optimized=0 note_offset=0 make_debounced=1 delay_fastest=20 delay_fastest_black_keys=0 delay_slowest=500
TK. Posted October 13, 2015 Author Posted October 13, 2015 Btw.: please update the repository - yesterday I noticed that in MBNG the KEYBOARD_Periodic_1mS() function was running in the wrong task (background instead of APP_Tick())This could cause random velocity values if LCD messages are print as well.Best Regards, Thorsten.
norbim1 Posted October 15, 2015 Posted October 15, 2015 (edited) Updated, but caused a HardFault. I have to check my working copy and the tool chain, because I have just changed to W7 from good old XP. It works with the prebuilt ng_v1_033_pre16 (excluding the modified KB handler) without HardFault, so I'm afraid the fault is at my side. Will check tomorrow.NorbimFinally I've successfully built. Ngr from memory works fine. Edited October 15, 2015 by norbim1
FantomXR Posted October 30, 2015 Posted October 30, 2015 Hey TK,in the past two weeks I ran pretty much into the problem, that the keys of the keybed do not react equally...some are more sensible than others and vice versa. I could go and create a velocity-map for every key but as you can guess this would be a lot of code and a lot of stuff to do.I'd like to ask you if you think it might be possible to somehow control delay_fastest / slowest for every key instead of the whole keyboard. Or does that require a lot of changes / addons in the code?Thanks!
TK. Posted November 8, 2015 Author Posted November 8, 2015 (edited) For the records: Christian and I worked out a calibration mode which is now available in the repository.More details about the calibration procedure at the MBKB webpage soon.Best Regards, Thorsten. Edited November 8, 2015 by TK.
aurel33 Posted November 19, 2015 Posted November 19, 2015 Hello everyone !I've just started building my midibox kb project(with a fatar tp40 keyboard), i have some question regarding the connection of a sustain pedal and aftertouch strip to the Ainser8 module.I have some trouble reading the ASCII shematics and by reading the thread it seems i need a 1k resistor, but i'm not sure where to put it.Is there some schematic available?I'm think about : the + of my sustain pedal > 1k resistor > J6.A1, and the ground to Vs. Am i right? For the aftertouch strip, i' dont have any idea, i have 2*4 strip.Thanks! Aurélien.
FantomXR Posted November 20, 2015 Posted November 20, 2015 (edited) Connect the tip to 5V and the shaft via a 1k resistor to GND. Put the analog input of the AINSER right before the resistor. 5V -----/ ---- 1k-----GND I ---> A0 BTW it doesn't matter if the tip is connected to 5V or the shaft. You can easily invert the values inside NG (should work in KB too) if the pedal works the wrong way around. Edited November 20, 2015 by FantomXR
FantomXR Posted November 20, 2015 Posted November 20, 2015 I never checked out aftertouch deeply. But as far as I know you need only three of the four pins. 5V, GND and the analog input signal. Search the forum. Someone gave some great informations about it here in this thread if I remember correctly.And the reason why you have two of those strips is that the black and white keys have separate aftertouch strips.
aurel33 Posted November 27, 2015 Posted November 27, 2015 As for velocity curves, is there a way to tweak them in midiboxkb ? A bit like in Pianoteq, where you can specify velocity range ie "Velocity = [0, 1, 14, 27, 43, 54, 66, 91, 125, 127; 0, 0, 7, 28, 64, 87, 102, 120, 127, 127]" [input:output]format.https://www.pianoteq.com/velocity_curvesThanks!
FantomXR Posted November 28, 2015 Posted November 28, 2015 Please read the documentation on ucapps. It's all there.You can approach this by using NG instead of KB.
djversus Posted October 19, 2016 Posted October 19, 2016 So wanting to start a KB project but wondering where do I get a CORE_LPC17 Module PCB? Thanks.
djversus Posted October 19, 2016 Posted October 19, 2016 (edited) or alternatively is it possible to build a MIDIbox KB with an MBHP_CORE_STM32F4 for the core? The docs make it sound like its only with a CORE_LPC17 so confused... Edited October 19, 2016 by djversus
latigid on Posted October 19, 2016 Posted October 19, 2016 In principle it should work, here's an STM32F4 build of the latest version of MBKB v1: project.hex As discussed above, MBNG should be fine (and be easier to configure). 1
