florian Posted November 15, 2013 Report Posted November 15, 2013 (edited) i had the chance to have a seq 4 kit from smash ( long wait, but can't be more happy). I usually ever use kingsbright flat top leds when i solder. I don't read for instance the manual ( will certainly not read it before some build), so i don't know what deserve the bicolor leds. My set is around a red light scheme so i hope to replace the kits leds, if not too complicated. I want to use kingbrights reds flat tops led instead of the green one. AND IWANT TO FOUND BICOLOR RED/BLUE . If the blue is not eye burner. Do you know if it exist??? any advice??? thanks!! Edited November 16, 2013 by florian
TK. Posted November 15, 2013 Report Posted November 15, 2013 If a suitable bicolour LED doesn't exist, I could add an option to the firmware which inverts the GP LED instead of activating a second colour. Best Regards, Thorsten.
Altitude Posted November 16, 2013 Report Posted November 16, 2013 .. AND IWANT TO FOUND BICOLOR RED/BLUE . If the blue is not eye burner. Do you know if it exist??? any advice??? thanks!! Knock yourself out: http://www.unique-leds.com/index.php?target=categories&category_id=198
kristal= Posted November 16, 2013 Report Posted November 16, 2013 Specifications for 3mm Green 4000mcd Water Clear :cool:
florian Posted November 16, 2013 Author Report Posted November 16, 2013 ok thanks for your answer!! not sure if i will not just stick with the kits one... After all functionality is here... anyway i'm just soldering the lpc board now... the nxp board splittage was rude, hope it will work after that....
florian Posted November 16, 2013 Author Report Posted November 16, 2013 was a lonely saturday evening..... But not really boring: But's it's far from end, and a usual i'm pissed off me, because i wsn't able to order all that i need in advance, and now blocked.... Will try to make a list here, hope someone wille help me to validate it, and will make the mios studio thing in the core now.... About the leds: TK: "If a suitable bicolour LED doesn't exist, I could add an option to the firmware which inverts the GP LED instead of activating a second colour." sorry, idon't understand that... What is "invert the GP" ?? semi lighted?? you can have a good result without dual colors leds without loss of funcctionality??? (sorry i don't read the manual for instance, just want to build it as soon as possible to play with it....) many thanks for explanations!!
florian Posted November 17, 2013 Author Report Posted November 17, 2013 (edited) so let's go for the final list of things i need to run : my seq: -Maybe kingsbright leds if i go for them. -1 10 pin flat ribbon cable with -2 female idc connector 10 pin =>for connecting J1 on the frontpanel to j8/j9 on the lpc module (only conncation between the boards??? What is for the "SO" pin hole on j1 on the frontpanel?? you should not connect it...?? -2 16 pins flat ribbon -2 female idc connectors to =>To connect the screens to the lpc and the mounting hardware . Is that all???? thanks flo Edited November 17, 2013 by florian
