Heyo! After lots of thinking, I've decided to build a SEQ to become the navigation system for my spaceship. I've become hopelessly addicted to modular, and am curious if someone who use's their SEQ in a similar capacity could comment.
Question one, whats the max output of analog info? 8 cv, trigger, and gate? Is more possible?
Question two, can the SEQ interpret incoming cv? For instance, can I clock the SEQ from a simple trig out of my modular?
Thanks much for the help!
There was the option of more gates (at least in V3) but I think CV is limited to 8 outs.
I was wondering whether you could clock a second AOUT module for another 8 channels, it's possible in theory but I'm not sure about the programming side. You could always build a second one!
The analogue inputs are used as gate outputs in the current setup. There is a tap tempo function however...
Yes, CV is limited to 8 outputs.
CV in is not supported, but a clock input might be available sooner or later.
See also this topic:
