lis0r Posted April 5, 2014 Report Posted April 5, 2014 Hi all, I've got my MB-6582 working enough to play with it a bit, while I add the finishing touches. I'm mystified by the feedback pots though. They seem to have little effect on the sound, other than making it quieter. They also seem to effect the sound all the time, even when "ext in" isn't switched on. Have I done something wrong? Thanks! Lisa
TK. Posted April 6, 2014 Report Posted April 6, 2014 Hi Lisa, They seem to have little effect on the sound, other than making it quieter. They also seem to effect the sound all the time, even when "ext in" isn't switched on. yes, the pots will affect the sound regardless of the "ext in" switch. Therefore turn the pot full left if you don't want to use the feedback option. You should hear an effect with "ext in" on, cutoff low, resonance high, pot at least in middle position. Best Regards, Thorsten.
