novski Posted May 30, 2014 Report Posted May 30, 2014 (edited) Hi I have a question regarding the NG App. I have a bunch of Buttons that have a wrong layout of the LEDs. They are Parallel with different direction. Now i asked the friends of microkontroller.net for advice and they say that it is possible to make a Array with a 74HCT595 and let them work in a H-Bridge way together and Pulse the two LEDs from each direction. Is that possible to do with the NG App? Thanks Novski edit: this is the link. Its German sorry for those who don't understand... http://www.mikrocontroller.net/topic/335089?goto=3674282#3674282 Edited May 30, 2014 by novski
ilmenator Posted May 30, 2014 Report Posted May 30, 2014 If you (or TK) wrote a modified driver this was absolutely possible.
novski Posted May 31, 2014 Author Report Posted May 31, 2014 Did anybody ever use a Charly circuit with Midibox? Seams to be quite powerful... http://en.wikipedia.org/wiki/Charlieplexing#Charlieplexing
Zam Posted May 31, 2014 Report Posted May 31, 2014 you want to light both LED at same time with fast pulse ? I just ask because you will have yellow colour :rolleyes:
novski Posted June 1, 2014 Author Report Posted June 1, 2014 Yes. That wold be great! To get a Color for each Button. Mute, Solo, Select...
novski Posted June 7, 2014 Author Report Posted June 7, 2014 Regarding the German discussion i linked above i now know: Charlyplexing is not possible with HC595 because the Tristate OE! is one signal for all outputs. I didn't find a Chip with multiple OE until now. Exept makting a uC working as a HC595 there is no solution for this... best regards novski
novski Posted June 7, 2014 Author Report Posted June 7, 2014 Regarding this Button that i can't use i made my decision to use the Sparkfun Button Pads again. I now have some questions to RGB LEDs wiring. I want to use 3 Color LEDs. I can't find much information about that quite new feature. A found a drawing from Protodeck http://www.midibox.org/dokuwiki/lib/exe/detail.php?id=protodeck&media=protodeck:ledsdout.png But i think it should be easier somehow without those NPN Transistors driving the Selection Lines. Did i mis a schematic somewhere or is there no documentation available yet? Thanks for a hint.. novski
TK. Posted June 7, 2014 Report Posted June 7, 2014 The usage of source drivers (the transistors) is for pro users who want to get perfect results. I'm unsure if this really makes a big difference. It's more important that you try to keep the number of selection lines per matrix as low as possible (8 is acceptable, 4 is perfect) Best Regards, Thorsten.
novski Posted June 8, 2014 Author Report Posted June 8, 2014 Thanks TK. I looked trou the parameters of NG .NGC and was surprised how much was added since i read that last time! Thats really a great work. Thank you so much. i will have 3 selection lines and 8 rows with each color to get 24 RGB Backlit Buttons. I didn't find a parameter to set the number of selection lines in the .NGC..? necessary? best regards novski
novski Posted June 9, 2014 Author Report Posted June 9, 2014 (edited) ok. I tried a bit around today but can't figure out how that all works. I added a DOUT4 to my core and took one resistor Array out of it by making short connections where the Array resistor was before. Then i added this code to my NGC file: # test D-OUT Matrix DOUT_MATRIX n=2 rows=8 mirrored_row=0 inverted_sel=0 sr_dout_sel1=1 sr_dout_sel2=0 sr_dout_r1=2 sr_dout_r2=0 i connected a LED to D0 of SR3 (Cathode) and D0 SR4 (Anode). I loaded that code to my Core and the LED went ON. I was surprised. Then i tried to find out the command to lit a LED one by one and found that the normal LED comand: "EVENT_LED id=999 hw_id=16 value=127" makes i go dark. Value=0 makes it go on. Can somebody explane me why its hw_id=16 and not 8 ? Im confused thanks novksi Edited June 9, 2014 by novski
novski Posted July 24, 2014 Author Report Posted July 24, 2014 (edited) made new post because nobody reacted. Edited July 26, 2014 by novski
