Smithy Posted January 20, 2024 Report Posted January 20, 2024 Also check out the wooden case that Technobreath designed. It's a simple case based on Sauraen's metal enclosure that he repurposed. I modified the 8 mounting holes so they would fit the wooden case. I'll be using 8 threaded inserts for m3 screws that I bought on eBay. You can find the pdf here: http://wiki.midibox.org/doku.php?id=mbqg_tb_case Quote
Smithy Posted January 20, 2024 Report Posted January 20, 2024 (edited) Just found a cheap source on AliExpress for the m3 threaded inserts for wood: https://a.aliexpress.com/_EwPghFj Be sure to select m3xm5x6mm Edited January 20, 2024 by Smithy Quote
