Mixed DIN/DOUT board -- clock and latch chaining?
latigid on
I'm working on a sort of hybrid DINX6/DOUTX4 board and I have a question on how to treat SC and RC. The BLM is proof that chaining the clock works even when the DIN/DOUT parts are not equal in length. But on DIN/OUTX4 boards sold by SmashTV normally one splits the J8/9 ribbon with an intermediate header. On this board I have the choice to go serial or parallel, so I wonder what the best way is, or if it really matters.
Many thanks,
Hm, that (and the lack of sleep ;-)) explains my confusion a few weeks back :-). RCs on J8/J9 do come from different 74HCT541 pins, but...
while "beeping through" connections from the core to the SEQ CS, only 6 connections (single RC line) were needed to wire up the SEQ CS, but 7 connections (two RC lines, that are common on the SEQ CS board, but I did not know that then) to wire up the TPD :-).
Does it have something to do with the maximum possible serial chain length? Wilba (SEQ CS PCB) connected the RCs, Ilmenator (TPD PCB) kept them separate... Does it make no difference or was it just a violation of well-established norms and standards? :-)
Many greets,
Peter
No problem :-). Probably within software, the output pins 13/Y5 (RC1 on J8/9 the STM32F4 board) and 14/Y4 (RC2 on J8/J9 ofthe STM32F4 board) of the '541 are switched in unison/at the same time, but I also have the strong feeling, one should not connect the RCs in the serial chain :-).
Many greets,
Peter
In the past J8/9 RC1/RC2 was a common line at the core (MBHP_CORE_PIC, MBHP_CORE_STM32), but always routed as separate lines at DIN/DOUT PCBs.
With MBHP_CORE_LPC17 and MBHP_CORE_STM32F4 I introduced separate RC1/RC2 lines at J8/9 core side for future enhancements.
This feature isn't used by MIOS32 yet (it just sets both pins at once), but it could be used in future for whatever reason.
  • 3 weeks later...
Hi
Is that a work in progress? because i'm not sure about your ground plane (bottom?) :pout:
As side note, if you are looking for smallest possible pcb and low profile, I successfully use micromatch connector for my system, still 100% compatible with actual MBHP wire specification, you can have micromatch at one side of the ribbon and header at other side.
Best
Zam
Hi
yes I was not clear because I don't clearly get the layer :) My first thinking was top layer=ground plane
Some observation:
-At hc595 power distribution, maybe it's better to connect first to caps, then to pin 16
-The remaining 5V trace at bottom layer between the two 165 can bee traced easy at top layer, like you do for other with half din trace at bottom layer
-You can simplify rc/sc/so chain at 595. All trace have angle at some point, most of them can be axed X at bottom and Y at top. Also you have some room to move digital trace more left by one or two steps, this will reduce the bottom trace at ground plane
-RC line at lower 595 to J8/9 can maybe use the same "pattern" as other ones with X bottom trace, an then top trace (via) // all other digital line. This will reduce a lot the long trace cutting ground plane
Just some ideas:happy:
Best
Zam
Thanks for your feedback. Some thoughts in reply:
I see what you mean, but that would involve a layer change of either +5V or the caps. At the moment the IC pin/socket acts as a conduit.
It adds a few vias, but I think you're right. I was wondering whether a plane break would actually help to decouple the longer signals running to J8/9A
Not a biggie, but I straightened them. But moving the traces to the left means SC starts to intercept the isolation for the caps = plane break.
This would have intercepted the +5V line, but I found another way around.
Again, I appreciate your input.
Best,
Andy
