Psykhaze Posted July 12, 2016 Posted July 12, 2016 Need some technical advice about a question: May encoders be managed in a switch matrix design? see http://wiki.midibox.org/doku.php?id=switch#connection it may allow to manage large encoders numbers by having less DIN/DOUTs inputs outputs Bests, JK
Hawkeye Posted July 14, 2016 Posted July 14, 2016 Quote No, you can't handle encoders this way. Correct, imho because otherwise some encoder-turning events might get lost. A matrix always has a limited scan time per input line. Normal tactile switches are pressed at least a hundred milliseconds or so, these events will always be captured. But fast-turned encoders might pulse the input lines much faster and for shorter durations. Best regards, Peter
Psykhaze Posted July 14, 2016 Author Posted July 14, 2016 Thanks for the precision peter , i didn't get why at first sight =) now clear. Bests, JK
