Speed up scanrate of NG by kicking out other scanroutines?
FantomXR
Hey people,
some of you already know that I'm very interested in getting the keyboard-handling as smooth as possible. Some of you also know too that the higher scanrate of the KB-app allows a much higher velocity-resolution than in NG. NG is very limited in this case and only allows a few (like 10-20) velocity-values. What I'm trying to achieve is, to modify NG in that way that the scanrate of the digital I/Os respective the I/Os where the keyboard is connected to is higher to get a better velocity resolution. The reason for that is, that NG allows a much easier way to modify the keyboard parameters and also due to the SD-card it's very easy to make a backup of your configuration. I had it now a few times, that (for whatever reason) MB_KB was reset.
So I took a closer look at the source code of what is going on under the hood in NG. As far as I can see the Period-Scanning is in both apps NG and KB 1ms.
I'd like to know what blocks NG to give the digital I/O scanning a higher scanrate. Are there any other routines running in background that I can simply disable if I don't need them? I'll do some test the next days but if anyone can give some hints on this, I'd be happy to read them! ;-)
Thank you very much!
Best,
Chris
In src/mios32_config.h you could change the number of DOUT pages from 32 to 1:
#define MIOS32_SRIO_NUM_DOUT_PAGES 1
This will increase the scan rate by factor 32
Compile will fail with:
src/mbng_matrix.c:53:3: error: #error "not prepared for != 32 pages - many variable types have to be adapted!"
src/mbng_matrix.c: In function 'MBNG_MATRIX_DOUT_NotifyReceivedValue':
the appr. "#error" line has to be removed
It says, that all LED_MATRIX related functions won't work anymore, such as LED rings
Alright... I tried it! But without any changes. I get the following velocity values only:
1, 8, 18, 28, 39, 49, 59, 69, 79, 89, 100, 110, 120, 127
As you see there is kind of "logic" behind that... but I think you go with me if I say that 14 steps out of 127 is not that much ;)
Here is my test configuration:
RESET_HW
KEYBOARD n=1   rows=12  dout_sr1=1  dout_sr2=2  din_sr1=1  din_sr2=2 \
               din_inverted=0  break_inverted=0  din_key_offset=32 \
               make_debounced=1 \
               scan_velocity=1  scan_optimized=0  note_offset=28 \
               delay_fastest=50  delay_fastest_black_keys=0  delay_slowest=200
EVENT_KB id=1  type=NoteOn chn=1 key=any use_key_number=1 range=0:127
SRIO num_sr=2
//edit: Alright, I set scan_optimized=1 and I get a lot more velocities! Great! Are there any other ways to speed up the scanrate or is that going to deep? ;)
Thanks already for that!
Edited by FantomXR
Yes, you could remove unusued functions from APP_SRIO_ServiceFinish() in src/app.c
E.g.
  • remove SCS functions if the SCS isn't connected to DIN pins.
  • remove MBNG_MATRIX_GetRow() if no BUTTON_MATRIX is used
  • remove MIOS32_ENC_UpdateStates if no encoders are connected
That's all what can be improved, the additional overhead is caused by the application itself, at the end you would come to a downstripped version like MIDIbox KB ;-)
However, if it turns out that the removals from APP_SRIO_ServiceFinish help, then I could add runtime options to disable certain functions in future so that no recompile is required.
If it can helps, I'm using midibox ng and i'm getting 24 different values on fatar tp 40m, but i'm using the map feature.
I also used MidboxKb for a long time and i was sometimes getting some stuck notes. Then i switched to midibox ng when the MAP feature was added, everything is now working great, i really can't explain the problem i had with with midiboxkb.
# reduce number of SRs for faster scan
# with 2 SRs the scan takes ca. 500 uS instead of 2.5 mS
SRIO num_sr=2
# keyboard configuration
               din_inverted=0  break_inverted=0  din_key_offset=40 \
               scan_velocity=1 scan_optimized=1  note_offset=21 \
               delay_fastest=60  delay_fastest_black_keys=0  delay_slowest=300 \
make_debounced=0
# using an interpolation map to define the velocity curve
MAP1/BYTEI  0:0 40:24 71:52 100:85  127:127
# send MIDI event with mapped velocity value
EVENT_KB id=1  type=NoteOn chn=1 key=any use_key_number=1 range=0:127  kb_velocity_map=map1  kb_transpose=0
1
4
7
17
19
22
25
29
33
37
41
45
53
57
63
67
73
89
95
102
109
116
122
127
Edited by aurel33
