btrd72 Posted May 1, 2017 Posted May 1, 2017 (edited) Hi folks ! Now that my LCD display work fine, I'm trying to get my wilba frontpanel to work... Precision: everything is soldered on the CS pcb, except the leds (I'm waiting for my frontpanel to be delivered).... When the CS pcb is NOT plugged in, I don't have any error message whether I put standard's, TK's or Wilba's MBSEQ_HW.V4 at the root of my fat 32 formatted SD Card. Turning the MB on leads me to the main page as shown here . With the wilba's MBSEQ_HW.V4 at the root of my SD card, when I plug the CS PCB (from J1 on the CS PCB to J8/9 on core module), I get this error: >> |!! SD CARD ERROR !! |<< >>| E131 (FatFs : D 0) |<< I learned german at school, but this is kind of a long time ago, so I may have misunderstood this discussion . : TK said: "E131 steht fuer ein ungueltiges Bank Format (irgendetwas stimmt nicht mit den MBSEQ_B*.V4 Files in Deiner Session)" This E131 means there is something wrong with my MBSEQ_B*.V4 in my session.....The fact is that my SD card only has the MBSEQ_HW.V4 at the FS root....No /SESSIONS directory or else...When I type sdcard in the MIOS termial, I only get MBSEQ_C.V4 and MBSEQ_HW.V4 files listed as valid (the output of sdcard tells me there is no /SESSIONS/DEFAULT/ files etc.) The previously quoted topic talks about a D9 error.....but I get a D0 error....and no luck with any search in the forum or the web... Any idea of what could have gone wrong ? Cheers, Tom. Edited May 2, 2017 by btrd72
EsotericLabs Posted May 1, 2017 Posted May 1, 2017 Try to format the sd card from the miosstudio command line?
btrd72 Posted May 1, 2017 Author Posted May 1, 2017 Ok. I formated the SD card via MIOS studio...still no luck ! The same error message appears and I can't do anything...
EsotericLabs Posted May 1, 2017 Posted May 1, 2017 no files on the SD card except MBSEQ_HW.V4? Try to create a SESSIONS directory in MIOS studio and then a new session named default? Can be done on the command line with " new DEFAULT" Hope that works. Otherwise, try to format your SD card on a computer with the FAT32 format and then reinstall MBSEQ_HW.V4 and a SESSIONS directory. Or try another SD card, preferably a small 1 or 2 GB one. Good luck!
btrd72 Posted May 1, 2017 Author Posted May 1, 2017 OK, no more SD card error after your tips EsotericLabs. Thank you. Now, when booting up my MB, the LCD display this page: G1:Unnamed G2: Unnamed G3: Unnamed G4: Unnamed NoCat 1: A1 _ _ _ _ NoCat 2: A1 _ _ _ _ NoCat 3: A1 _ _ _ _ >>> NoCat 4: A1 _ _ _ _ Is this normal ? No matter which button I push, no response from my MB...
EsotericLabs Posted May 2, 2017 Posted May 2, 2017 Did you copy the mbseq_hw.v4 file? to verify: you have a wilba control surface?
btrd72 Posted May 2, 2017 Author Posted May 2, 2017 (edited) OK, I think we can consider the SD card Problem solved since I now get a default screen when booting up my MB seq. The solution was : - to copy wilba's MBSEQ_HW.V4 at the root of the SD card file system - to create the /SESSIONS/ directory then create a DEFAULT session using MIOS terminal. See you in my next post.... Edited May 2, 2017 by btrd72
