NMNN Posted October 14, 2017 Report Share Posted October 14, 2017 (edited) Lately I've been trying to use the extra functions of the CV-Gate out, specifically the possibility to send velocity with key values. From the manual: Quote Note 9 Key Value -> CV Out #1, Velocity -> CV Out #2, Gate #1 and #2 triggered Note 10 Key Value -> CV Out #3, Velocity -> CV Out #4, Gate #3 and #4 triggered etc, etc, etc When I use AOUT - channel 9 I get key and velocity from the first two CV's out, as expected. But only gate #1 is triggering. When I switch to AOUT - channel 10, I get key and velocity from the second pair of CV's out: 3 and 4. And gate #2 is firing. What I expect is when I use AOUT - channel 9, is to get CV's from 1 and 2, and gates on #1 and #2. This is consistent through the whole range of outputs. All the other functions work exactly as expected, the drum gates and the clocks nothing wrong. I found this advise: And I've scanned through the entire config, but pretty much everything is standard. I use the Wilba Front panel with the AOUT-NG with the DOUT. Here is my HW-V4: https://pastebin.com/M9aXWjEx Am I making a mistake assiging SR's? Or is it something else I'm missing? Thanks! Edited October 15, 2017 by NMNN markup Quote Link to comment Share on other sites More sharing options...
gohan2a Posted March 10, 2018 Report Share Posted March 10, 2018 Helo! Same problem, Wilba front panel two, last update but that's work well like that : Note 9 Key Value -> CV Out #1, Velocity -> CV Out #2, Gate #1 triggered Note 10 Key Value -> CV Out #3, Velocity -> CV Out #4, Gate #2 triggered Note 11 Key Value -> CV Out #5, Velocity -> CV Out #6, Gate #3 triggered Note 12 Key Value -> CV Out #7, Velocity -> CV Out #8, Gate #4 triggered Quote Link to comment Share on other sites More sharing options...
TK. Posted March 30, 2018 Report Share Posted March 30, 2018 This was a translation error in the code, it's fixed now (and enhanced by a new feature! :) http://www.ucapps.de/mios32/midibox_seq_v4_095_pre12.zip o AOUT: Channel 9..12/13..15 now set the gate pins #1/3/5/7 as documented (previously it was #1/2/3/4 due to a code translation error) New: gate pins #2/4/6/8 are now set whenever the velocity is >100. This way the pins can be used as an accent trigger Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
