i want to connect one Encoder directly to J5a
i know that in my Code i have to
initalize this pins:
  // initialize pin 2 of J5A,  as Digital input with internal Pull-UP //connect to ground
    MIOS32_BOARD_J5_PinInit(0, MIOS32_BOARD_PIN_MODE_INPUT_PU);
    MIOS32_BOARD_J5_PinInit(1, MIOS32_BOARD_PIN_MODE_INPUT_PU);
and i also can observe the state of the J5a pin by putting following code into APP_Background:
MIOS32_BOARD_J5_PinGet(0)
MIOS32_BOARD_J5_PinGet(1)
all clear so far, and working good with buttons (with hardware debouncing ):
debouce-circuit
how does a Encoder-Code look like (without any Acceleration), and how does Hardware debouncing look like (the same like for buttons?), i want to use as less code then possible...
thx 4 any tips
  • 5 months later...
Hi!!!
Leveraging the topic.
I use the LCP1769
I'm testing the example "014b_enc_j5_relative".
It only works J5A (A0 ... A3) and J5B (A4 ... A7) does not work.
This example tests all inputs A0 ..... A7 on the J5A and J5B connector? How do I set up so that all inputs A0 .... A7?
I tested J5A / B as analog inputs and they all worked. I just set "#define MIOS32_AIN_CHANNEL_MASK 0x00ff"
This Settings in "mios32_config.h" are working for 0-7A (5a,5b) - i am on a stm32f4
// AIN define the deadband (min. difference to report a change to the application hook)
#define MIOS32_AIN_DEADBAND 31 //7Bit
Edited by Phatline
Hi !!
Strange, would not that just be for analog inputs? A0 .... A3 work fine without setting "#define MIOS32_AIN_CHANNEL_MASK 0x00ff".
I do not want analog inputs. I want 4 encoders
Tks Marco.
ahhh sorry, may fault...
what i have done with J10A-B (if you replace J10 with J5 i think its the same)
@top of programm (declaration)
// ENCODER            SR begin with 1, ENC with 0)   //    setup the Pinout of Encoders
    const mios32_enc_config_t encoders[1] = {{ .cfg.type=DETENTED2, .cfg.speed=FAST, .cfg.speed_par=3, .cfg.sr=7, .cfg.pos=0 }};
void APP_Init(void){
  BLM_SCALAR_Init(0);   // initialize BLM_SCALAR driver
// Set GPIO @ J10A+B
  int pin;
  for(pin=0; pin<16; ++pin){
    MIOS32_BOARD_J10_PinInit(pin, MIOS32_BOARD_PIN_MODE_INPUT_PU);}
// Set Menue Encoder
  int enc;
  for(enc=0; enc<4; ++enc) {
    mios32_enc_config_t enc_config = MIOS32_ENC_ConfigGet(enc);
    enc_config.cfg.type = DETENTED3; // see mios32_enc.h for available types
    enc_config.cfg.sr = 0; // must be 0 if controlled from application
    enc_config.cfg.pos = 0; // doesn't matter if controlled from application
    enc_config.cfg.speed = FAST;
    enc_config.cfg.speed_par = 0;
    MIOS32_ENC_ConfigSet(enc, enc_config);}
void APP_SRIO_ServicePrepare(void)  {
  // get current J10B value and update all encoder states
    int enc;
    u16 state = MIOS32_BOARD_J10B_Get();
    MIOS32_ENC_StateSet(enc, state & 3); // two pins
    state >>= 2; // shift to next two pins
Just got a flashback: this is actually a known issue and I thought that I fixed this some years ago... somehow the change didn't find it's way into the repository.
I updated mios32/LPC17xx/mios32_board.c, please update your repository
1 hour ago, TK. said:
Acabei de receber um flashback: este é realmente um problema conhecido e achei que consertei isso há alguns anos ... de alguma forma, a mudança não encontrou o caminho para o repositório.
Eu atualizei o mios32 / LPC17xx / mios32_board.c, atualize seu repositório
Atenciosamente, Thorsten.
Hi TK,
Thank you so much!!! Now it works !!!! I've been looking for where the bug would be for two days and today I would look at "mios32_board.c". Thanks for the quick help !!!
Marco.
Edited by kmargos
