Smithy Posted May 26, 2021 Posted May 26, 2021 (edited) Here's an updated pic of the underside of the LEMEC board, hopefully the problem is on that side or I have some serious dismantling to do! Edited May 26, 2021 by Smithy
Smithy Posted May 26, 2021 Posted May 26, 2021 I think I've spotted something off. T7 on the bottom of the PCB has no BAT54 diode piggy backed on top of it. I must have missed it. I'll solder one on now.
Smithy Posted May 26, 2021 Posted May 26, 2021 Update: Soldering the BAT54 diode on top of T7 did not fix the issue with the 4 superflux LEDs staying on.
latigid on Posted May 26, 2021 Author Posted May 26, 2021 I could not see your picture of the soldering As the behaviour is common to a column (two columns, but they are only separated by RJ4/8) it is probably caused by 1. Wrong transistor type or otherwise an error with T16. Yep, that's on the top side of lemec_L! 2. The pin driving T16, so R16 and IC4, pin 15. With luck you just have a solder bridge to +5V (pin 16). Good luck!
Smithy Posted May 26, 2021 Posted May 26, 2021 27 minutes ago, latigid on said: 2. The pin driving T16, so R16 and IC4, pin 15. With luck you just have a solder bridge to +5V (pin 16). I tried soldering a bridge between pin 15 and pin 16 of IC4 and no luck. The 4 leds still light when seq_l is loaded. I presume thats exactly what I was meant to do? I just have to remove the switch caps and light shields to be able to separate the boards again I presume? Cheers!
Smithy Posted May 26, 2021 Posted May 26, 2021 Also I seem to have rectified the LED on switch 24 lighting up when the buttons of the other MEC switches are pressed at least. I think there was a bridge between one of the transistors an unused pad.
Smithy Posted May 26, 2021 Posted May 26, 2021 2 hours ago, Smithy said: Here's an updated pic of the underside of the LEMEC board, hopefully the problem is on that side or I have some serious dismantling to do! Fixed the picture of the underside of the board.
Smithy Posted May 26, 2021 Posted May 26, 2021 2 hours ago, Smithy said: Here's an updated pic of the underside of the LEMEC board, hopefully the problem is on that side or I have some serious dismantling to do! fixed the image.
latigid on Posted May 26, 2021 Author Posted May 26, 2021 41 minutes ago, Smithy said: I tried soldering a bridge between pin 15 and pin 16 of IC4 and no luck. The 4 leds still light when seq_l is loaded. I presume thats exactly what I was meant to do? What I meant was to desolder a potential bridge there. Generally you don't want the output shorted to the power supply. But a constant voltage here would mean that the transistor base was always in the high state and not able to switch as required with the 595 pulses. 41 minutes ago, Smithy said: I just have to remove the switch caps and light shields to be able to separate the boards again I presume? I guess that's the case... light|shields and keycaps can stay on!
latigid on Posted May 26, 2021 Author Posted May 26, 2021 28 minutes ago, Smithy said: fixed the image. Thanks, it works. Can't see anything obvious. You can check the components I mentioned before. It could also be a too-long resistor leg, also on RJs? Before desoldering all of the switches, you might try to remove those resistors.
Smithy Posted May 26, 2021 Posted May 26, 2021 1 hour ago, latigid on said: Thanks, it works. Can't see anything obvious. You can check the components I mentioned before. It could also be a too-long resistor leg, also on RJs? Before desoldering all of the switches, you might try to remove those resistors. I trusted my cutting of the RJ leads and went ahead and de-soldered all the Mattias switches in the Lemec PCB. Turns out there was a short between the bottom leg of T16 and the unused pad to the right of it! Thank god for my desoldering station otherwise this would have taken much longer, if i could even do it all with a manual pump!I owe you an expensive beer when I'm done! I'm going to test the superflux leds now with the diode test on my multimeter in case the heat has damaged them. I also found an issue in the RH Lemec board earlier. Turning Encoder 4 lights up the LEDs in the 3 switches below it. I'll post more detail on that later.
Smithy Posted May 26, 2021 Posted May 26, 2021 4 hours ago, Smithy said: I thought IC5 - the 74HC165 was the culprit as some pins were bent so I de-soldered it. Unfortunately I broke pin 13 / pin C clean off while trying to straighten it. The issue with the Superflux LEDs staying on when they shouldn't be existed before this btw! I re-soldered the chip again hoping that it was unused, but now Encoder 6 is unresponsive when turning it clockwise / counterclockwise. At least I presume pin 13 is responsible for this encoder, i could be wrong. No big deal there, I can buy another 74HC165 off ebay and replace it. Andy can you confirm that pin 13 in IC5 is linked to Encoder 6 before I order the replacement SN74HC165? Thanks!
latigid on Posted May 26, 2021 Author Posted May 26, 2021 12 minutes ago, Smithy said: I trusted my cutting of the RJ leads and went ahead and de-soldered all the Mattias switches in the Lemec PCB. Turns out there was a short between the bottom leg of T16 and the unused pad to the right of it! Thank god for my desoldering station otherwise this would have taken much longer, if i could even do it all with a manual pump!I owe you an expensive beer when I'm done! I'm going to test the superflux leds now with the diode test on my multimeter in case the heat has damaged them. I also found an issue in the RH Lemec board earlier. Turning Encoder 4 lights up the LEDs in the 3 switches below it. I'll post more detail on that later. Clean work, you're doing great! That is a via that brings the SR signal to the transistor.
latigid on Posted May 26, 2021 Author Posted May 26, 2021 10 minutes ago, Smithy said: Andy can you confirm that pin 13 in IC5 is linked to Encoder 6 before I order the replacement SN74HC165? Thanks! That's right! Not sure exactly what your issue is here, but if you've narrowed it down to pin 13, IC5, you could bodge wire it to pin 3 on J5? Pin 1 of the connector has a square pad.
Smithy Posted May 26, 2021 Posted May 26, 2021 (edited) 3 minutes ago, latigid on said: That's right! Not sure exactly what your issue is here, but if you've narrowed it down to pin 13, IC5, you could bodge wire it to pin 3 on J5? Pin 1 of the connector has a square pad. I mentioned it early that some pins were bent on that IC and I desoldered it and tried to straighten them but snapped that pin clean off the IC! So it will have to be replaced as the copper sticking out of the IC absolutely tiny and I doubt i can bridge it. Edited May 26, 2021 by Smithy
Smithy Posted May 28, 2021 Posted May 28, 2021 So the issue with the LeMEC RH I'm having is that when I turn ENCSW4 clockwise or anti-clockwise, the 2 superflux LEDs and MEC switch SW20 light up directly below when turning that encoder. As soon as i stop turning the encoder the LEDs go off . If i keep it in between the detents the leds stay on. I think keypresses are being registered in MIOS studio also. Any ideas where to check on the bottom side of the PCB or the far left hand side of the top PCB before I go de-soldering Mattias switches again? Here are some pics: I must point out that I lifted the top pad for R13 so ended up soldering the resistor lead to the trace directly I believe. See pic below: I'm getting continuity between that leg of R13 and pin 3 aka QD output of IC4 - SN74HC595. But i presume thats okay? Just thought it was worth mentioning.
latigid on Posted May 28, 2021 Author Posted May 28, 2021 What output do you get from MIOS Studio with "set debug on"? The encoders are directly connected to 165 inputs, so IC4 is not involved here. Looks like there are a lot of blobs around IC3? Encoder pins connect to Plate J1, pins 8 and 9, if that helps. The encoder shouldn't hit anything below it, but you could try to slip a piece of card in between the boards to rule out unintentional short circuits. R13 does go to pin 3 of that IC. But make sure that it doesn't connect anywhere else.
Smithy Posted May 28, 2021 Posted May 28, 2021 I get quite a lot with one single turn of the encoder (from one detent to the next detent - clockwise in this example.) [196444.183] MBNG_MATRIX_NotifyToggle(1, 20, 0) [196444.183] MBNG_DIN_NotifyToggle(2020, 0) [196444.184] [EVENT] id=BUTTON:2020 hw_id=BUTTON:2020 bank=0 fwd_id=LED:2024 type=NoteOn value=0 label= [196444.185] MBNG_DOUT_NotifyReceivedValue(2024, 127) [196444.186] MBNG_MATRIX_DOUT_NotifyReceivedValue(2, 24, 127) [196444.188] MBNG_MATRIX_NotifyToggle(1, 36, 0) [196444.189] MBNG_DIN_NotifyToggle(2036, 0) [196444.189] No event assigned to BUTTON hw_id=2036 [196444.192] MBNG_MATRIX_NotifyToggle(1, 52, 0) [196444.193] MBNG_DIN_NotifyToggle(2052, 0) [196444.193] No event assigned to BUTTON hw_id=2052 [196444.196] MBNG_MATRIX_NotifyToggle(1, 4, 0) [196444.196] MBNG_DIN_NotifyToggle(2004, 0) [196444.197] [EVENT] id=BUTTON:2004 hw_id=BUTTON:2004 bank=0 fwd_id=LED:2015 type=NoteOn value=0 label= [196444.198] MBNG_DOUT_NotifyReceivedValue(2015, 127) [196444.199] MBNG_MATRIX_DOUT_NotifyReceivedValue(2, 15, 127) [196444.201] MBNG_MATRIX_NotifyToggle(1, 28, 0) [196444.201] MBNG_DIN_NotifyToggle(2028, 0) [196444.202] [EVENT] id=BUTTON:2028 hw_id=BUTTON:2028 bank=0 fwd_id=LED:2031 type=NoteOn value=0 label= [196444.203] MBNG_DOUT_NotifyReceivedValue(2031, 127) [196444.204] MBNG_MATRIX_DOUT_NotifyReceivedValue(2, 31, 127) [196444.206] MBNG_MATRIX_NotifyToggle(1, 44, 0) [196444.207] MBNG_DIN_NotifyToggle(2044, 0) [196444.207] No event assigned to BUTTON hw_id=2044 [196444.210] MBNG_MATRIX_NotifyToggle(1, 60, 0) [196444.210] MBNG_DIN_NotifyToggle(2060, 0) [196444.211] No event assigned to BUTTON hw_id=2060 [196444.214] MBNG_MATRIX_NotifyToggle(1, 12, 0) [196444.214] MBNG_DIN_NotifyToggle(2012, 0) [196444.214] [EVENT] id=BUTTON:2012 hw_id=BUTTON:2012 bank=0 fwd_id=LED:2016 type=NoteOn value=0 label= [196444.215] MBNG_DOUT_NotifyReceivedValue(2016, 127) [196444.216] MBNG_MATRIX_DOUT_NotifyReceivedValue(2, 16, 127) [196444.244] MBNG_ENC_NotifyChange(12, 1) [196444.245] [EVENT] id=ENC:12 hw_id=ENC:12 bank=0 fwd_id=DISABLED:0 type=CC value=2 label= [196444.270] MBNG_MATRIX_NotifyToggle(1, 60, 1) [196444.270] MBNG_DIN_NotifyToggle(2060, 1) [196444.271] No event assigned to BUTTON hw_id=2060 [196444.274] MBNG_MATRIX_NotifyToggle(1, 12, 1) [196444.274] MBNG_DIN_NotifyToggle(2012, 1) [196444.276] [EVENT] id=BUTTON:2012 hw_id=BUTTON:2012 bank=0 fwd_id=LED:2016 type=NoteOn value=127 label= [196444.276] MBNG_DOUT_NotifyReceivedValue(2016, 0) [196444.277] MBNG_MATRIX_DOUT_NotifyReceivedValue(2, 16, 0) [196444.279] MBNG_MATRIX_NotifyToggle(1, 28, 1) [196444.279] MBNG_DIN_NotifyToggle(2028, 1) [196444.281] [EVENT] id=BUTTON:2028 hw_id=BUTTON:2028 bank=0 fwd_id=LED:2031 type=NoteOn value=127 label= [196444.281] MBNG_DOUT_NotifyReceivedValue(2031, 0) [196444.282] MBNG_MATRIX_DOUT_NotifyReceivedValue(2, 31, 0) [196444.283] MBNG_MATRIX_NotifyToggle(1, 44, 1) [196444.284] MBNG_DIN_NotifyToggle(2044, 1) [196444.284] No event assigned to BUTTON hw_id=2044 [196444.288] MBNG_MATRIX_NotifyToggle(1, 4, 1) [196444.288] MBNG_DIN_NotifyToggle(2004, 1) [196444.289] [EVENT] id=BUTTON:2004 hw_id=BUTTON:2004 bank=0 fwd_id=LED:2015 type=NoteOn value=127 label= [196444.290] MBNG_DOUT_NotifyReceivedValue(2015, 0) [196444.291] MBNG_MATRIX_DOUT_NotifyReceivedValue(2, 15, 0) [196444.293] MBNG_MATRIX_NotifyToggle(1, 20, 1) [196444.293] MBNG_DIN_NotifyToggle(2020, 1) [196444.294] [EVENT] id=BUTTON:2020 hw_id=BUTTON:2020 bank=0 fwd_id=LED:2024 type=NoteOn value=127 label= [196444.294] MBNG_DOUT_NotifyReceivedValue(2024, 0) [196444.296] MBNG_MATRIX_DOUT_NotifyReceivedValue(2, 24, 0) [196444.297] MBNG_MATRIX_NotifyToggle(1, 36, 1) [196444.298] MBNG_DIN_NotifyToggle(2036, 1) [196444.298] No event assigned to BUTTON hw_id=2036 [196444.301] MBNG_MATRIX_NotifyToggle(1, 52, 1) [196444.301] MBNG_DIN_NotifyToggle(2052, 1) [196444.302] No event assigned to BUTTON hw_id=2052 The blobs around IC is the reflection of flux against the light, the light makes it look like solder. Its looking like I'll need to desolder the Mattias switches and inspect the top side. I'll wait til you've looked at the debug messages. Thanks again Andy.
latigid on Posted May 29, 2021 Author Posted May 29, 2021 Not easy to debug sorry... Basically there is no reason that you should get matrix DIN toggle events when rotating an encoder. There might be some sort of unintentional short between the boards (e.g. from a diode and you push the encoder button?). IC3 is the shift register responsible for the input side of the matrix, so maybe run the hot air around there or consider replacing that chip? The associated pull up/RN is right next to it
Smithy Posted May 29, 2021 Posted May 29, 2021 10 hours ago, latigid on said: Not easy to debug sorry... Basically there is no reason that you should get matrix DIN toggle events when rotating an encoder. There might be some sort of unintentional short between the boards (e.g. from a diode and you push the encoder button?). IC3 is the shift register responsible for the input side of the matrix, so maybe run the hot air around there or consider replacing that chip? The associated pull up/RN is right next to it Pushing the Encoder button on ENSW4 behaves as it should, no extra inputs or anything. I tried reflowing the IC3 pins with hot air but no luck. I also desoldered the Mattias switches and took pics of the boards:Le MEC RH 1.3R top side: ENC Plate 1.0 Bottom side: I'm stumped! Going to order a replacement for IC3 anyways.
Smithy Posted June 1, 2021 Posted June 1, 2021 Been looking for shorts while waiting for the 165 ICs to arrive and still can't find anything. However I decided to temporarily add arduino headers to J-1 to 3 to see if something on the ENC Plate PCB was shorting out something on the Le MEC RH PCB. Basically the PCBs would be further apart. No such luck there, i'm beginning to think the short is somewhere on the Le MEC RH PCB. I've been checking the small the tiny vias for shorts also but no luck there. Its driving me round the bend but I'll persist. I'll update the thread when the 165s arrive and I replace them.
latigid on Posted June 1, 2021 Author Posted June 1, 2021 Just to ask the obvious: are your resistor networks soldered on the right way? As you have a working lemec_L board, you can probe around for voltages and see where things differ. The parts that drive the fourth column of LEDs are: Matrix column RJ4/ RJ8, T15/16 (front side), R24/R25, IC4 pins 1/15. If the rest of the LEDs in the rows work, then there is no issue with the sink sides of the matrix.
Smithy Posted June 1, 2021 Posted June 1, 2021 (edited) 40 minutes ago, latigid on said: Just to ask the obvious: are your resistor networks soldered on the right way? As you have a working lemec_L board, you can probe around for voltages and see where things differ. The parts that drive the fourth column of LEDs are: Matrix column RJ4/ RJ8, T15/16 (front side), R24/R25, IC4 pins 1/15. If the rest of the LEDs in the rows work, then there is no issue with the sink sides of the matrix. The resistor networks are definitely soldered correctly: Any suggestions for a noob on how to read voltages in the appropriate places without frying the boards? :P I reflowed all points you mentioned but no luck. Can't thank you enough for the help. Edited June 1, 2021 by Smithy
latigid on Posted June 2, 2021 Author Posted June 2, 2021 4 hours ago, Smithy said: Any suggestions for a noob on how to read voltages in the appropriate places without frying the boards? :P Find a spot to clip your 0V lead e.g. the middle pin of the slide switch on the USB board, or solder a wire to the middle pin of the power headers there. Then just go through point to point, measure on the chips, the RJs etc. BTW, does fluxtest.NGR run properly?
Smithy Posted June 2, 2021 Posted June 2, 2021 (edited) 10 hours ago, latigid on said: Find a spot to clip your 0V lead e.g. the middle pin of the slide switch on the USB board, or solder a wire to the middle pin of the power headers there. Then just go through point to point, measure on the chips, the RJs etc. BTW, does fluxtest.NGR run properly? Fluxtest ran fine I'm pretty sure when I had the superflux CC and Mattias switches soldered. Only interesting thing I've spotted so far is that R24 and R25 seem to be inverted on the Le MEC RH board. I.E. I'm measuring GND on the opposite side compared to the resistors on the Le MEC 1.0 pcb. But maybe the orientation is just flipped between Boards? All the diodes are in the correct orientation also. Edited June 2, 2021 by Smithy
