latigid on Posted September 13, 2021 Author Report Posted September 13, 2021 Once finished, post a photo in to claim your serial number! I would love to offer SN 111 but I don't think we're there yet :).
brewmaxwell649 Posted November 5, 2021 Report Posted November 5, 2021 (edited) I've got regular LCD(not OLED, they are higher(not low profile) this is not possible to use normal IDC, I was obliged to solder wire directly. Mobdro Vip Edited November 9, 2021 by brewmaxwell649
latigid on Posted November 5, 2021 Author Report Posted November 5, 2021 Could be! Also please check the clearance in the case. The OLEDs we supply are thin (y dimension) enough to fit but there is not a lot of room. I think some models of display simply won't fit in the case.
Donny-v1rus Posted January 8, 2022 Report Posted January 8, 2022 Hi im new here. I was just finishing up my seq v4+. Tested all the boards. Everything works. Went to put it together and the green power light wouldnt come on and a message for a power surge on the usb came up. I have isolated the problem to have something to do with the I2C midi 4 board. Went its connected to the core it will not power on. So far ive tried using different cables that are known to be good and ive tested both connectors on the I2C and Core (j4a) for proper contact. Im stumped.
latigid on Posted January 8, 2022 Author Report Posted January 8, 2022 So everything else works when the I2C board is disconnected? Is the cable still plugged in here? Do you measure a short circuit on the I2C board? Measure across a 100n capacitor, or what voltage do you read? Are your PICs in the right way around? How is the soldering around J1/J4A? Please upload a photo of the board to check. To check if it's the PICs, you can try to remove them and see if you get the same behaviour. Best, Andy
Donny-v1rus Posted January 8, 2022 Report Posted January 8, 2022 The core powers on when a cable is connected. I did remove the PICs and no change (forgot to mention haha). Cant send pictures for some reason. Will update with voltages
Donny-v1rus Posted January 8, 2022 Report Posted January 8, 2022 I just realised. I installed the j4a header in the wrong direction *facepalm* haha
latigid on Posted January 9, 2022 Author Report Posted January 9, 2022 Right, that would short circuit the +5V rail to 0V!
PlateOfShrimp Posted February 21, 2022 Report Posted February 21, 2022 (edited) Hello! I'm pretty close to wrapping up my build. Got everything up and running, but I'm having an issue with encoder 7 on the le-mec RH board. When I rotate the encoder, it behaves like I hit the Song button (SW23). One other thing I noticed was that if I kept rotating the encoder while on the song page, then SW22 on the le-mec LH board sometimes flickers on certain values and Phrase lights up on the JA board. Are there any obvious places I should look for a short or cold joint? Hope it's something accessible at this point or a cable issue. Edit: Ok, turns out I just needed to reflow the encoder itself. All good! Edited February 21, 2022 by PlateOfShrimp
latigid on Posted February 21, 2022 Author Report Posted February 21, 2022 Hello, You tested all of the inputs before soldering the Matias switches right? ;-) The encoders are not on a switch matrix like the buttons are, so my guess is that there is a short between the two boards. Try to see if any resistors or diodes poke through. You could consider desoldering the encoder and bridging the pins to see if it is related to that. But you mentioned "press on the encoder"; do you mean the encoder push switch? That is connected in the matrix in the same column as SW23. Diodes in that column (including on ENSW7) are connected to pin 9 of J2 and pin 5 of IC3. The encoder itself is connected through J3 pins 6/7 then through the header to pins 4/5 of IC5. A short to the adjacent pin (serial clock) might explain things. Best, Andy
PlateOfShrimp Posted February 22, 2022 Report Posted February 22, 2022 Hey Andy, thanks for the reply. I ended up getting it working after reflowing the encoder. Wish I had tried that before unmounting the UI boards from the case though haha. It was the last thing I expected to be the problem since soldering those in was such a straightforward process. Anyway, everything's going well now, and I got to play with the sequencer all afternoon. Thanks again, and I'm glad it didn't become a bigger problem.
