TK. Posted March 2, 2019 Report Share Posted March 2, 2019 Hi *, The MIOS repositories are now hosted at Github: https://github.com/midibox/mios8 https://github.com/midibox/mios32 This should improve collaboration in future, because branching in GIT is much easier. It's not possible to access the old subversion repositories via SSH anymore, in future changes can only be pushed into the new GIT repositories. There are tons of documentation how to use GIT on the web, therefore I won't repeat this here. ;) Just want to mention the general workflow: we use a simplified workflow without develop branch, so: master is the latest everybody who want's to contribute has to create a feature branch, e.g. feature/my_project once you are fine with your changes, create a pull request from your branch into master, and set me as a reviewer I will review your changes, and if they are fine I will integrate them into master meanwhile everybody is able to work with your changes by switching to your feature branch Currently we've only one branch: feature/mcan (from Bruno) How to contribute: create a github account (if you don't already have one) register your SSH key in the profile inform me about your account name so that I can add it to the midibox project now you can clone the repository with git clone ssh://git@github.com/midibox/mios32 Within this repository you can create a branch with: git checkout master -b feature/<your-branch-name> You can commit changes with git commit . resp. "git commit" if you've indexed the files with "git add" before You can push committed changes to github with git push If you are working from a fresh clone, use "git checkout feature/<name>" to select your feature branch With "git branch -a" you will get an overview about the branches. There are also various GUIs available to display changes in your local repository, e.g. I prefer "gitk" Best Regards, Thorsten. P.S.: Wiki and ucapps documentation will be updated in some weeks once the new workflow is settled ;) Quote Link to comment Share on other sites More sharing options...
Antichambre Posted March 2, 2019 Report Share Posted March 2, 2019 Thank you Thorsten for also migrating the MCAN branch.In general, this is good news because the latest version of XCODE no longer supports SVN. Maybe that's why you moved it.Thank you so much. Have a good night. Bruno Quote Link to comment Share on other sites More sharing options...
latigid on Posted March 2, 2019 Report Share Posted March 2, 2019 It's a nice idea, though SVN was still fine for a passive user like me. This was discussed elsewhere, but just to be clear: you (TK.) prefer to keep control of the master line and review all changes, and you will keep the same license terms as non-commercial for personal use only (no GPL/CC-BY etc.)? This is not a request for you to change anything you don't want to of course. Quote Link to comment Share on other sites More sharing options...
TK. Posted March 2, 2019 Author Report Share Posted March 2, 2019 2 hours ago, Antichambre said: In general, this is good news because the latest version of XCODE no longer supports SVN. Maybe that's why you moved it. No, I moved because I noticed that your MCAN activity doesn't really fit with the subversion work flow anymore. ;) 27 minutes ago, latigid on said: This was discussed elsewhere, but just to be clear: you (TK.) prefer to keep control of the master line and review all changes, and you will keep the same license terms as non-commercial for personal use only (no GPL/CC-BY etc.)? This is not a request for you to change anything you don't want to of course. yes Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
Antichambre Posted March 3, 2019 Report Share Posted March 3, 2019 8 minutes ago, TK. said: No, I moved because I noticed that your MCAN activity doesn't really fit with the subversion work flow anymore. ;) Thank you but even if the workflow is now more suitable I'm not sure to be more skilled with the new format I don't know why but a repo stays something obscure for me... I hope git is easier...Best regards Bruno Quote Link to comment Share on other sites More sharing options...
monokinetic Posted March 3, 2019 Report Share Posted March 3, 2019 18 hours ago, TK. said: The MIOS repositories are now hosted at Github: aha excellent, I agree that this should make collaboration easier.... 10 hours ago, Antichambre said: I hope git is easier Heheh, define easier ;) I'm no Git expert, but if it helps, here's how I'd imagine doing things: Make a directory for this repo i.e. cd ~ mkdir mios_stuff cd mios_stuff Clone the repo to your local dir: git clone https://github.com/midibox/mios32.git Let's check to see which branches are available in the new repo: cd mios32/ ~/mios_stuff/mios32$ git branch -av * master 79292db corrected comments in source_me_* files remotes/origin/HEAD -> origin/master remotes/origin/feature/juce_5_4_3_migration 5e8148f MIOS Studio: updated release script remotes/origin/feature/mcan b7b78c2 corrected mios32_* namespace remotes/origin/master 79292db corrected comments in source_me_* files I used the -av option to show all of the branches on the remote repo. Note the * by master, that shows which branch you have checked out at the moment. It looks like TK has set you up the feature/mcan branch. Let's assume you want to do some work on that, so switch to the MCAN branch like this: ~/mios_stuff/mios32$ git checkout feature/mcan Branch feature/mcan set up to track remote branch feature/mcan from origin. Switched to a new branch 'feature/mcan' Here is where things are a bit different to SVN. I'd try and explain it but you'd be better reading this: https://git-scm.com/book/en/v2/Git-Branching-Branches-in-a-Nutshell Then basically you can do your work, doing regular commits. Those go in to the branch you have checked out currently. Then when you are ready to share them with others you push to the repo, ensuring that your push goes to the feature/mcan branch. Eventually, once we know that everything you have done in feature/mcan is OK to add to the full mios32 then someone has to merge the changes in feature/mcan branch into the master branch. Then finally everyone can use MCAN and blow their minds with so many MIDI ports to play with ;) I also recommend looking up how Git stash works (I find that invaluable) :) Sorry for the slightly long post, and apologies in advance for things that a Git expert would tell you are wrong. But that's how I plan to use it so far! 1 Quote Link to comment Share on other sites More sharing options...
southpole Posted April 7, 2019 Report Share Posted April 7, 2019 Hello Thorsten, The move to github is really excellent news! One more question on the license though: When the repository gets forked, even just to play around with personally, it is automatically public and so are any changes committed to the fork. Which in practice would amount to publishing a modified version of midibox. Does this still fall under your "personal use only" clause? Cheers, southpole Quote Link to comment Share on other sites More sharing options...
