Phatline Posted February 9, 2020 Posted February 9, 2020 (edited) i cant get it working, tryd for ours (meanwhile for days...) i want to read the J5 Pins periodicaly (want to read a IR-Sensor) that should do the job: void APP_Init(void){ MIOS32_BOARD_J5_PinInit(4, MIOS32_BOARD_PIN_MODE_ANALOG); } void APP_Tick(void){ s16 state = MIOS32_BOARD_J5_PinGet (4); MIOS32_MIDI_SendDebugMessage("val: %d ", state ) ;} MIOS-Monitor print: val: 0. Its No Hardware Issue, since: When config the J5 Pins as DIN or DOUT, i can get and set them with no problems && when using J5A/B in combination with APP_AIN, i get "normal" values (>0!)... ... also i all different variations in mios_config like...: #define MIOS32_AIN_CHANNEL_MASK 0x00ff #define MIOS32_AIN_CHANNEL_MASK 0x0000 #define MIOS32_DONT_SERVICE_AIN 1 #define MIOS32_DONT_SERVICE_AIN 0 #define MIOS32_DONT_USE_AIN 1 #define MIOS32_DONT_USE_AIN 0 also if i try to set the Pin Value (joke it) MIOS32_BOARD_J5_PinSet (4, 3); and then make a PinGet, i become 0 ( && J10 do the same when set to PIN_MODE_ANALOG!!! bug? Edited February 22, 2020 by Phatline
Phatline Posted February 22, 2020 Author Posted February 22, 2020 (edited) I cant find out the issue... i am looking into mios32_ain.c and mios32_board.c and when i break it down to the J5 Part, a code for initialze and get the J5 Pins would be like this (debuging give me a 0) void APP_MIDI_Tick(void){ // Test J5 Pin every second static int secflag = 0; secflag++; if( secflag > 1000) { secflag = 0; // this table maps ADC channels to J5.Ax pins typedef struct { u8 chn; GPIO_TypeDef *port; u16 pin_mask; } adc_chn_map_t; static const adc_chn_map_t adc_chn_map[8] = { { ADC_Channel_11, GPIOC, GPIO_Pin_1 }, // J5A.A0 { ADC_Channel_12, GPIOC, GPIO_Pin_2 }, // J5A.A1 { ADC_Channel_1, GPIOA, GPIO_Pin_1 }, // J5A.A2 { ADC_Channel_4, GPIOA, GPIO_Pin_4 }, // J5A.A3 { ADC_Channel_14, GPIOC, GPIO_Pin_4 }, // J5B.A4 { ADC_Channel_15, GPIOC, GPIO_Pin_5 }, // J5B.A5 { ADC_Channel_8, GPIOB, GPIO_Pin_0 }, // J5B.A6 { ADC_Channel_9, GPIOB, GPIO_Pin_1 }, // J5B.A7 }; // set analog pins GPIO_InitTypeDef GPIO_InitStructure; GPIO_StructInit(&GPIO_InitStructure); GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL; int i; for(i=0; i<8; ++i) { GPIO_InitStructure.GPIO_Pin = adc_chn_map[i].pin_mask; GPIO_Init(adc_chn_map[i].port, &GPIO_InitStructure); } MIOS32_MIDI_SendDebugMessage("J5A Pin0: %d", MIOS32_SYS_STM_PINGET(GPIOC, GPIO_Pin_1) ) ; MIOS32_MIDI_SendDebugMessage("J5B Pin0: %d", MIOS32_SYS_STM_PINGET(GPIOC, GPIO_Pin_4) ) ; } if i break it down to get J5A Pin 0 and J5B Pin0 the code should look like this? (this again debugging return me 0 and 0! void APP_MIDI_Tick(void){ // Test J5 Pin every second static int secflag = 0; secflag++; if( secflag > 1000) { secflag = 0; // set analog pins GPIO_InitTypeDef GPIO_InitStructure; GPIO_StructInit(&GPIO_InitStructure); GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL; // PIN J5A 0 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1; GPIO_Init(GPIOC, &GPIO_InitStructure); // PIN J5B 0 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4; GPIO_Init(GPIOC, &GPIO_InitStructure); MIOS32_MIDI_SendDebugMessage("J5A Pin0: %d", MIOS32_SYS_STM_PINGET(GPIOC, GPIO_Pin_1) ) ; MIOS32_MIDI_SendDebugMessage("J5B Pin0: %d", MIOS32_SYS_STM_PINGET(GPIOC, GPIO_Pin_4) ) ; } And i cant find:" MIOS32_SYS_STM_PINGET()"? >>> it isnt: http://www.midibox.org/mios32/manual/_s_t_m32_f4xx_2mios32__sys_8c.html because there isnt a "STM_PINGET" ? or is it? ... on this point my research stops, since i cant find it just try to find out where the problem is, since the simple and userfriendly "MIOS32_BOARD_J5_PinGet (4);" wont work... Edited February 22, 2020 by Phatline
Phatline Posted February 22, 2020 Author Posted February 22, 2020 (edited) also if i follow this tip: Quote and make a code like this: void APP_MIDI_Tick(void){ // Test J5 Pin every second static int secflag = 0; //initalize secflag++; //ms counter if( secflag > 1000) { secflag = 0; //reset counter static int init = 1; if (init == 1) { init = 0; // run only @ first time // Init J5A0 and J5B Pin 0 as Analog Inputs GPIO_InitTypeDef GPIO_InitStructure; GPIO_StructInit(&GPIO_InitStructure); GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1; // J5A 0 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL; GPIO_Init(GPIOC, &GPIO_InitStructure); GPIO_StructInit(&GPIO_InitStructure); GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4; // J5B 0 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL; GPIO_Init(GPIOC, &GPIO_InitStructure); } static u8 value = 0; // initalize variable // Get Pin State J5A 0 value = MIOS32_SYS_STM_PINGET(GPIOC, GPIO_Pin_1); MIOS32_MIDI_SendDebugMessage("J5A Pin0: %d", value ); // Get Pin State J5B 0 value = (u8)MIOS32_SYS_STM_PINGET(GPIOC, GPIO_Pin_4); MIOS32_MIDI_SendDebugMessage("J5B Pin0: %d", value ); } and or not add this lines in mios32_config.h: (it doesnt matter) #define MIOS32_DONT_SERVICE_AIN 1 #define MIOS32_DONT_USE_AIN 1 return me a debugging messages of 0 and 0 Edited February 22, 2020 by Phatline
Phatline Posted February 22, 2020 Author Posted February 22, 2020 (edited) Can anyone confirm that this simple code Work/not Work? j5pinget.zipj5pinget.zipj5pinget.zip anyone with a STM32F4 can test this.... the code should not hang your device since it is only call every second. thx 4 help. #include <mios32.h> #include <FreeRTOS.h> #include <task.h> #include "app.h" // Init J5A+B Pin 0 as ANalog Input void APP_Init(void){ MIOS32_BOARD_J5_PinInit(0, MIOS32_BOARD_PIN_MODE_ANALOG); MIOS32_BOARD_J5_PinInit(4, MIOS32_BOARD_PIN_MODE_ANALOG); } void APP_Background(void) {} // Get J5A-B Pin 0 every second void APP_Tick(void){ static int seccount = 0; // init counter seccount++; if (seccount > 1000) { seccount = 0; // reset counter static s16 state = 0; // Get J5A0 state = MIOS32_BOARD_J5_PinGet (0); MIOS32_MIDI_SendDebugMessage("J5A-Pin0: %d ", state ) ; // Get J5b0 state = MIOS32_BOARD_J5_PinGet (4); MIOS32_MIDI_SendDebugMessage("J5B-Pin0: %d ", state ) ; } } void APP_MIDI_NotifyPackage(mios32_midi_port_t port, mios32_midi_package_t midi_package){} void APP_SRIO_ServicePrepare(void){} void APP_SRIO_ServiceFinish(void){} void APP_DIN_NotifyToggle(u32 pin, u32 pin_value) {} void APP_ENC_NotifyChange(u32 encoder, s32 incrementer){} j5pinget.zip Edited February 22, 2020 by Phatline
Antichambre Posted February 23, 2020 Posted February 23, 2020 (edited) Hi, Your if condition is never true cause you put initialization to 0 and increment of seccount in the same hook. APP_Tick is called by TASK_Hooks every ms. #include <mios32.h> #include <FreeRTOS.h> #include <task.h> #include "app.h" static int seccount = 0; // Init J5A+B Pin 0 as ANalog Input void APP_Init(void){ MIOS32_BOARD_J5_PinInit(0, MIOS32_BOARD_PIN_MODE_ANALOG); MIOS32_BOARD_J5_PinInit(4, MIOS32_BOARD_PIN_MODE_ANALOG); } void APP_Background(void) {} // Get J5A-B Pin 0 every second void APP_Tick(void){ seccount++; if (seccount > 1000) { seccount = 0; // reset counter static s16 state = 0; // Get J5A0 state = MIOS32_BOARD_J5_PinGet (0); MIOS32_MIDI_SendDebugMessage("J5A-Pin0: %d ", state ) ; // Get J5b0 state = MIOS32_BOARD_J5_PinGet (4); MIOS32_MIDI_SendDebugMessage("J5B-Pin0: %d ", state ) ; } } void APP_MIDI_NotifyPackage(mios32_midi_port_t port, mios32_midi_package_t midi_package){} void APP_SRIO_ServicePrepare(void){} void APP_SRIO_ServiceFinish(void){} void APP_DIN_NotifyToggle(u32 pin, u32 pin_value) {} void APP_ENC_NotifyChange(u32 encoder, s32 incrementer){} Edited February 23, 2020 by Antichambre
Phatline Posted February 23, 2020 Author Posted February 23, 2020 no, my code on this point is right: the word "static" initialize a variable only @ first run, after that - the init-value "0" is ignored. this is really handy 1
Antichambre Posted February 23, 2020 Posted February 23, 2020 Ahah sorry, I learnt something today! thanks!
TK. Posted February 23, 2020 Posted February 23, 2020 Could you please try following tutorial application: https://github.com/midibox/mios32/tree/master/apps/tutorials/005_polling_j5_pins It shows the intended way, how to use J5 pins as inputs. And it's also a good test application to ensure, that the pins are (still) working. Best Regards, Thorsten.
Phatline Posted February 23, 2020 Author Posted February 23, 2020 hi i tested the tutorial now, and set as Digital Input- as the Tutorial is, it works. it sends midi notes when moving the potentiometers. but when changing the initalitaion to void APP_Init(void) { // initialize all LEDs MIOS32_BOARD_LED_Init(0xffffffff); // initialize all pins of J5A, J5B and J5C as inputs with internal Pull-Up int pin; for(pin=0; pin<12; ++pin) MIOS32_BOARD_J5_PinInit(pin, MIOS32_BOARD_PIN_MODE_ANALOG); } and let the rest of the tutorial untouched, it doesnt send anything when moving any of the 8 potentiometers. the Analog mode doesnt work - or what do i miss here?
TK. Posted February 23, 2020 Posted February 23, 2020 MIOS32_BOARD_* functions are intended for reading the pins in digital, and not in analog mode. For Analog readouts you've to use the AIN driver. See following tutorial: https://github.com/midibox/mios32/tree/master/apps/tutorials/011_ain Best Regards, Thorsten.
Phatline Posted February 23, 2020 Author Posted February 23, 2020 i just read the documentation; http://www.midibox.org/mios32/manual/group___m_i_o_s32___b_o_a_r_d.html#gae4a1b2afe98fdf86a5b20216fe4c2bbd Quote MIOS32_BOARD_PIN_MODE_ANALOG: select analog input mode (default) for me it seemed that it should work... When using AIN-Driver, the AINs are read in background. can i then manually command to start a read out? (maybe in combination with "#define MIOS32_DONT_SERVICE_AIN 1"?) background to this quest: i have 4 IR Diodes, and one IR Receiver (my AIN) i have to cycle ON/OFF-the 4IR Diodes... So i have to Activate a Diode, read the state, deactivate it, then the next Diode, read the AIN State, its importend to do this in perfect timing. (in order to calculate a XYZ-Read out of my hand)
TK. Posted February 23, 2020 Posted February 23, 2020 Analog pins are permanently polled by the AIN driver, this is done via DMA in background (so that the CPU isn't loaded) If you've to set pins before the next scan, then just use a AIN ServicePrepare callback. See also following tutorial which shows how to scan a touchscreen - actually a similar handling like described for your use case: https://github.com/midibox/mios32/tree/master/apps/tutorials/022_glcd_touchpanel Best Regards, Thorsten.
