Hey people,
I have a problem  and I hope you can help me.
I've created a PCB based on MF_NG. Schematic and layout see here:
mf_PCB.thumb.png.976d59c8c4757521f70fb81
mf_schematic.thumb.png.5c39cdcdfdcd7dc1c
I have a PicKit3 to program the 18F4520. I use the MBLAP X to flash the bootstrap to the PIC. The programming seems to work fine. I don't get any error messages.
As stated on the MIOS Troubleshooting page there seems to be a problem with the ID when working with MBLAP. See here (bottom):
http://ucapps.de/howto_debug_midi.html
So I also flashed the bootstrap-workaround which also ran fine.
If I now connect the MF_NG via MIDI to a core, I get this error message:
[395386.494] [MIOS32_MIDI_Receive_Handler] Timeout on port 0x20
Do you know what that could cause?!
Best,
Chris
Quote
I've just noticed, I've used the PIC18F4520 instead of PIC18F452. Could that be the problem?
I built a Midibox Midi Monitor a while ago and I used a 18F452 as per shematic, the bootloader flashed no problem.
http://ucapps.de/mbhp/mbhp_core_v3.pdf
I did get the wrong PIC at first a 18F4520, not 18F452
  • 3 weeks later...
