synthmania Posted June 17, 2020 Posted June 17, 2020 I am troubleshooting an issue on my sammichSID; basically I see that all the 24LC512 memory chips are installed; there are 5 of them. When using the SS, I can see bank A, B, C and D, but E, F and G give me the "no bank" message on display. I am curious how does the memory on the SS works, with these chips. Is each chip hosting a bank? In which case I should see banks A through E; but the last bank seems to be D. Do I have to initialize again the chips, or maybe some went bad? Thanks
m00dawg Posted June 17, 2020 Posted June 17, 2020 Check this out, specifically: Five “BankStick” slots, so you can store 4 banks of 128 patches, plus 128 “Ensembles” (engine and patch configurations) So what you're seeing is correct - A through D are normal banks and G is the ensemble bank (and yep each chip equates to one bank). I can confirm this is how it's working on my sammichSID as well. 2
Noise-Generator Posted June 17, 2020 Posted June 17, 2020 Yes. Bank E F G is not present because they don't exist but it's software enabled.
synthmania Posted June 18, 2020 Author Posted June 18, 2020 Thanks! I was wondering why there was also a couple of banks that are not usable. And totally forgot about the bank reserved for the ensemble. Thanks!
