dwestbury Posted September 28, 2020 Posted September 28, 2020 (edited) Has anyone tried to use JST XH connectors and cables to join their MB-6582 PCBs? They look to be about half the height of standard DuPont connectors, so they should fit nicely inside a closed PT-10 case. Curious about the overall durability and bend radius, etc.? https://www.amazon.com/dp/B07XNZV995/ref=cm_sw_r_cp_api_i_4uMCFb7TCFS47 Edited September 29, 2020 by dwestbury
m00dawg Posted September 28, 2020 Posted September 28, 2020 I haven't tried it but would love to see if this may work! The cabling issue for me was what prevented me from properly finishing my MB6582 to the point I just started to design a rackmount control surface for it. I'd still like to finish that (and these days with laser cutters maybe I can without breaking the bank). I love my sammichSID but working on patches has proven to be really difficult with the software and would be just soooo much better with a proper control surface. There was a modification that used right angle SIL headers that was interesting. Still very cramped but it worked, and allowed the panel to be separated from the base if needed. Good luck, please do share what you find!
JohnnieBee Posted September 29, 2020 Posted September 29, 2020 Hi Darrell This looks like an interesting solution to the problem of linking the two boards. But note that the cables need to be very short in order to reduce noise, the ones you linked to are 300mm, just under 12” to those of us still using imperial units and I’m fairly sure that they would be too long. The Amazon seller lists a similar set of cables that are 100mm that might be better but from what I remember from the original build discussion that may still be a bit “iffy”. Need to find the reference in the original thread, a quick effort to search didn’t locate what I was looking for, I’ll try and find time over the next couple of days to do a more thorough search. Best John
dwestbury Posted September 30, 2020 Author Posted September 30, 2020 (edited) Amazon is amazing. I received some samples in the mail today, within 24hrs of placing my order and with free shipping. More importantly, I can confirm that even at the 300mm cable length, there's no discernible evidence of noise or instability in the communications between the control surface and the base PCB, over a >2hr period of testing. I did wind up having to tie-wrap the cables to get the "spaghetti mess" under control and properly tucking them into the PT-10 case was a little bit clumsy. I'm thinking @JohnnieBee may be right and 100mm cables will be a bit easier to manage... 8 Pin JST XH Cables @ 100mm https://www.amazon.com/gp/product/B07XKRZD7Z/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1 2 Pin JST XH Cables @ 100mm https://www.amazon.com/gp/product/B07XNTQK5M/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1 I'll report back after some additional testing... Cheers all, -Darrell Edited September 30, 2020 by dwestbury
dwestbury Posted October 12, 2020 Author Posted October 12, 2020 (edited) Just as I expected, the 100mm JST XH cables are a much nicer fit (and look), but what's most important is they leave enough room for the case to close properly. Now I feel comfortable recommending this solution to anyone that's looking for quick removal access to service their control surface. Edited October 16, 2020 by dwestbury
m00dawg Posted October 12, 2020 Posted October 12, 2020 (edited) My goodness that looks fantastic and no having to hand solder or crimp any cables! Looks great! I was so excited I broke out my MB6852 which has been sitting on my closet all sad and alone for years. It will still take some work before it's ready to go beyond the connectors. I'm a bit worried the board may have some bad pads if I recall. However I think it's worth a shot. It looks like from the photos you use regular straight and right angle SIL connectors? I noticed the linked JSTs appear to include the straight connectors but I couldn't find right angled ones. Any suggestion on options there? Edited October 12, 2020 by m00dawg 1
dwestbury Posted October 16, 2020 Author Posted October 16, 2020 (edited) On 10/12/2020 at 7:03 PM, m00dawg said: It looks like from the photos you use regular straight and right angle SIL connectors? I noticed the linked JSTs appear to include the straight connectors but I couldn't find right angled ones. Any suggestion on options there? I ordered the angled JST XH connectors from AliExpress, but they haven't shown up in the mail yet (usually takes about 5-6 weeks to make their way into the US from Asia). https://www.aliexpress.com/item/4000029760504.html?spm=a2g0s.9042311.0.0.349a4c4dKTIGpV So, for now I'm using standard angled SIL headers, which seem to do the trick. The mount is flush and the connections are solid. Edited October 16, 2020 by dwestbury
m00dawg Posted October 16, 2020 Posted October 16, 2020 Makes sense. That's probably what I will do too. I have a pile of right angle IDC strips I can cut and use. Really excited to try this out!
m00dawg Posted December 16, 2020 Posted December 16, 2020 Quick update on this, the method worked wonderfully! I've got my MB6582 up and running using this method. The only thing I had to do we Dremmel the backside of the top half a bit (in the front) as my right angled connections were a bit too tall (the JSTs are on the baseboard and I'm using the JST cables though couldn't find the right angled JSTs outside of AliExpress and figured that would be a long wait). Apart from that, it's working beautifully!
dwestbury Posted December 16, 2020 Author Posted December 16, 2020 That’s awesome @m00dawg. Glad to hear that this approach worked out and your long standing project is moving ahead! Cheers... 1
sbm Posted January 19, 2021 Posted January 19, 2021 Excellent this was a solution I was looking for too for my build :)
dwestbury Posted January 20, 2021 Author Posted January 20, 2021 On 1/19/2021 at 4:23 PM, sbm said: Excellent this was a solution I was looking for too for my build :) Cheers @sbm good luck with your build!
sbm Posted February 12, 2021 Posted February 12, 2021 Thanks Darrell! I received the cable assemblies and looks like I have the version with both headers being straight, not half as right-angle. I'll have to check clearances but maybe I can gently bend the pins to fix that. Otherwise I'm shelving the build for now as there seems to be part shortages and I have to wait.
