oliq Posted October 26, 2020 Report Posted October 26, 2020 Tried a few fans for my MB6582 build, they are all pretty noisy. Anyone recommend one that doesn't sound louder than my computer?
Hawkeye Posted October 26, 2020 Report Posted October 26, 2020 If you're using 8580 or 6582 SIDs: heatsinks and maybe some passive ventilation holes in the case bottom will be sufficient - using this setup since 10 years now without any problems! :). If you are using 6581 SIDs, that's a different story though, as they run hotter. Many greets and have fun with your MB6582! :) Best regards, Peter
oliq Posted October 29, 2020 Author Report Posted October 29, 2020 Thanks, I'm on the 8580s and I bought some copper heat sinks for them so perhaps I'll just leave my fan disconnected. Be interested if any users of other chips have found quieter fans.
Noise-Generator Posted October 30, 2020 Report Posted October 30, 2020 Use 5v and you have a silent Fan
m00dawg Posted December 9, 2020 Report Posted December 9, 2020 Heya Hawkeye where'd you get those heatsinks? Back to the fans, I use Noctua 40mm in my Deepmind since the stock fans were loud. Prusa 3D printers also use Noctua 40x10's (though I replace those with more powerful fans). At any rate, thought I haven't tested it, my plan is to try out a a 5V Noctua for my MB6582.
Hawkeye Posted December 9, 2020 Report Posted December 9, 2020 @m00dawg hi, hope you're fine in this mad world! :) Got them off Reichelt, simple low-profile DIP 28 sinks i think - 10 years ago, my memory is not the best ;-). Many greets! Peter
m00dawg Posted December 9, 2020 Report Posted December 9, 2020 5 hours ago, Hawkeye said: @m00dawg hi, hope you're fine in this mad world! :) Got them off Reichelt, simple low-profile DIP 28 sinks i think - 10 years ago, my memory is not the best ;-). Many greets! Peter As fine as one can expect in 2020 :P But hey for all the crap 2020 was it at least got me back to working on my MB6582! Although by "working on it again" it's mostly populating new boards :P The new JST connectors are a game changer! So here's hoping I can finally have a functional 6582 after t....err some amount of years ;) Ah...hmm...I was asking as I tried to find some on Mouser (US) but wasn't able to find ones that look like they would fit. I am using the slide on ones at the moment but was thinking something more low profile and with less mechanical concerns might be better. 1
m00dawg Posted December 16, 2020 Report Posted December 16, 2020 Update, I'm rocking the Noctua (NF-A4x10, 5V) and am running it off the 5V header. At full speed it is a tad loud but does seem to keep the SIDs rather cool. I do have heatsinks on them but the heatsinks without the fan get warm (not hot) to the touch after some time of running. As expected the ones furthest from the fan are warmer than the ones next to it. All of them seem to be cooler to the touch though. So far it doesn't seem to make a huge impact to the 5V rail. I'm using the 5V switcher often recommend, although I am using it in an external power supply I made and am supplying the 6582 with 9 and 5V directly. So I can't speak to other power configurations. I also haven't checked to see if it has an impact on noise. Really I just got the dern thing assembled and in fact one thing that may change the temps is I lost the case screws so the top isn't fully attached. In any case, if you need a pretty stout fan the Noctua seems like a good choice.
