mutronic Posted March 8, 2021 Posted March 8, 2021 (edited) Hello all I am currently preparing my first SID Synth build with the MB6582 boards, and I have some questions regarding the power supply options. I guess my main question regarding the power options is which option would one recommend? What power socket would I use? I noticed there is an expansion connector. Is this for connecting other MB6582's? Edited March 8, 2021 by mutronic
dwestbury Posted March 8, 2021 Posted March 8, 2021 (edited) 22 hours ago, mutronic said: ...my main question regarding the power options is which option would one recommend? What power socket would I use? Since you're looking for recommendations, I would suggest using Power supply Option E: http://www.midibox.org/dokuwiki/doku.php?id=wilba_mb_6582_psuopte IMHO, this is likely to be the simplest to setup, with the fewest parts. But best of all, it enables you to use a standard (and readily available) 12V DC "wall wart" power adapter, as long as it supports at least ~1.5 amps. In terms of the PCB mounted power connector, that option is really up to you, but to keep the retro spirit alive, many have chosen the 7-Pin circular DIN, which is what the original C64 used. https://www.aliexpress.com/item/32981543684.html?spm=a2g0o.productlist.0.0.140c60d5kCwIHg&algo_pvid=feec72e8-76ab-4f5b-b02b-a65975ddf4f1&algo_expid=feec72e8-76ab-4f5b-b02b-a65975ddf4f1-2&btsid=0bb0623316152126363434357e0c5f&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_ If you go this route, you'll also need to swap the tip on your power brick with a 7-PIN male DIN receptacle. Rean makes a good quality one that's readily available. https://www.mouser.com/ProductDetail/REAN-Neutrik/NYS323G-U?qs=%2B86TLfaev2%2FQ5iVm8npeOw%3D%3D Best! Edited March 9, 2021 by dwestbury
mutronic Posted March 13, 2021 Author Posted March 13, 2021 In the BOM for the base board it says in the notes for the 220 Ohm resistor [Solder Last Must Match LED Brightness] - How would the resistor affect the LED brightness?
the_duckchild Posted March 15, 2021 Posted March 15, 2021 there is an an entire bank of 16 resistors for the LEDs - if you use anything but red the brightness can vary a lot so 220 Ohm might not be suitable. I have white and they are way too bright i need to open it up and change them tbh! worth playing with resistor values here - higher resistance, dimmer LEDs. 1
