pay_c Posted June 6, 2004 Posted June 6, 2004 Hi there!Question about the Seq: How do you control it in Cubase SX? I mean... has Cubase SX any Midipatchbay Function?The Seq has to receive the Midiclock Signal and the notes (from some keyboard). But I can´t find any solution how to send the notes to the Seq *always* and then send them back to the specified instrument.I just came up with a solution using a hardware Midimerger (thnx TK again! ;) ) and nothing more. Has anyone implemented the Seq completely within Cubase SX?Greetz!
pay_c Posted June 15, 2004 Author Posted June 15, 2004 OK... since nobody ever had the same prob... :-/Nobody using lame Win with lame Cubase with superb MBSeq?*sigh*So, I built the external Merger (used some old PIC 16F). The notes directly come out of the keyboard into the Seq together with the Midiclock of Cubase.The only thing: I gotta use the Midimerger Function of the Seq a lot. While having it off as playing appregios, I gotta turn it on to just use the keyboard.But hence... it works! So whatever...Greetz!
doc Posted July 13, 2004 Posted July 13, 2004 Hi pay_c,ähm ...now I'm in the same trouble...after finishing my SEQ I also try to find a "connection" way.I also use the merger for this now. But I would be lucky if there would be another way. I use various synth modules (not only the SID), each on a seperate MIDI port. The cabling confusion is getting over my head when I use the merger ... :PI think there must be a kind of patchbay function we could use. Do you know if there is a kind of ReWire for Midi available ?In fact, I don't have ReWire but perhaps it can do this already ?The best thing would be a VST plug-In that manages the various midi Ports.I keep on searching !If I don't find a VST solution I think about building a MIDI-Switch Matrix (MIDIBOX128 controlled) which is also able to switch several midi merger between any connections (I also have a lot of old PICs). Tell me what you think about that idea.greetsDOC
goyousalukis Posted July 13, 2004 Posted July 13, 2004 Don't know if it'll help or not, but the midiox site also has Midi Yoke which gives you up to 16 additional software midi drivers. You can then set up a Midi-Ox device map that routes midi signals.http://www.midiox.com/myoke.htmJustin
