lukas412 Posted June 7, 2005 Report Posted June 7, 2005 Hello everyone,I found a hammond enclosure, that is perfect for my midibox, but reading the forums, I had read that FPE will only cut flat panels. Well I contacted them yesterday and they told me that they can in fact cut my panel into a pre-made Hammond enclosure. So I will let you all know what the results are when I get it back. And it turns out that the enclosure will cost me about the same as the aluminium panel would have cost from FPE. For those who don't know Frontpanel Express is the US counterpart to Shaffer. They use Frontpanel Designer aswell. It will probably be a while, cause the enclosure I need is'nt stocked by anyone and its like a month lead time.Luke
SuperBad Posted June 10, 2005 Report Posted June 10, 2005 Not to post spam but try this guy... chris.montplaisir@alliedelec.com He told me he can get hammond stuff pretty quickly. I am getting ready to order an enclosure for myself. Tell me a little more about how you are doing the Transaction with FPE. I might do this with the design i have come up with for my FM.Bobby
lukas412 Posted June 10, 2005 Author Report Posted June 10, 2005 Well, I emailed them, and they told me that if I send them the enclosure, they will cut it for me, and that it doesnt have to be a flat panel. Same way you would if you were using their material, do your design, and submit it to them through Frontpanel designer. Unfortunatly, I think my controller needs more space between the knobs, so Im not quite sure its gonna fit in a hammond now. Im still working on it, so Ill let you know how it goes. Thanks for the tip, Ill email the guy. Thanks,Luke
mikeb Posted June 10, 2005 Report Posted June 10, 2005 lukas, are they charging more or is it about the same?
lukas412 Posted June 13, 2005 Author Report Posted June 13, 2005 Actually it will cost me a bit less if i send them the enclosure. What they would charge me for a piece of anodized black aluminium will pay for the enclosure i was lookin at.Luke
bcbox Posted June 14, 2005 Report Posted June 14, 2005 yeah, it's all CNC. They do beautiful panels. you can send in your own or use their stock. There's no charge for using your own material - just send it in. I've used them twice and both times the parts came back beautiful.
