MEEF Posted August 30, 2006 Report Posted August 30, 2006 Nah just teach him how to use it to make music, and bring them both :) haha that reminds me of this guy - Quote
docbrown Posted August 30, 2006 Report Posted August 30, 2006 haha that reminds me of this guy - Son, forget about learning your ABC's, better learn Abelton and your 1's & 2's!! ;D ;D Sweet!!Our future MIDIbox'ers. Quote
URBatORB Posted September 9, 2006 Report Posted September 9, 2006 The Joysticks from my Thrustmaster Joypad are working with my Midibox too. From one I had removed the spring - it still works fine. :D/Daniel Quote
Phattline Posted June 4, 2007 Report Posted June 4, 2007 Hmm, I dont know the quality of these...but they look bretty much the same....http://shop.conrad.nl/Elektronica,044_meetapparatuur/Componenten/Passieve_componenten/Schuif_potmeter/420030.html Quote
liinnerd Posted June 9, 2007 Report Posted June 9, 2007 They work great! and look great too!But keep in mind that you need to order the Joystick Pot and the Jostick Cap (Soft Touch Knob) separatly. --> (http://www.conrad.nl/goto/?product=710047) Grtz,Richard Quote
Phattline Posted June 20, 2007 Report Posted June 20, 2007 Today I got the datasheet of this thing...but there are no dimensions....only electrical dataPS2-Joystick-datasheet.pdfPS2-Joystick-datasheet.pdf Quote
Phattline Posted June 28, 2007 Report Posted June 28, 2007 today the parts arrived, I measured them and finally drawed them in CAD (dxf format), I found out that are not good for vectorboards (the holes are´nt vectorboard compatible...anyway I dont need vectorboards)To remove the middle spring is work for 3 minutes.DXF.rarDXF.rar Quote
cimo Posted November 27, 2007 Report Posted November 27, 2007 hihas anybody opened the conrad joysticks to remove the spring?The ones i have are different from those pictured by Phattline, mine have the switch sitting beside (outside) the little box containing the mechanism the spring is contained in the bottom of the box and i haven t been able to reach iti would spare a broken joystick if anybody has already done thatsimone Quote
Sasha Posted November 27, 2007 Report Posted November 27, 2007 I recycled alot of these joysticks from PS2 and all have pushbutton mounted at side. Only difference is that some have metal, but most have plastic shaft. I removed spring from one for testing and everything went just fine. Quote
cimo Posted November 27, 2007 Report Posted November 27, 2007 hilet s see if they are the same: the spring in mine is contained between a bigger white piece of plastic and a black "cap" that can move vertically inside the white piece, right in the bottom of the joystick , don t ask for photos cause my camera decided to stop working without asking my permission, anyway.. removing the black part implies spoiling, if a little, some little pins that will retain the black part from "jumping off" the white part.I managed to take apart the whole thing and remove the spring but i couldn t do a perfectly clean job.I was also wondering if anybody has just shortened the spring instead removing it so that you can have a "no auto centering" joystick but still the pressure feeling of the center position.simone Quote
Sasha Posted November 27, 2007 Report Posted November 27, 2007 Sorry, I`m not sure exactly what I`ve did, it was long time ago. I should open it again to see. Quote
cimo Posted November 28, 2007 Report Posted November 28, 2007 ok here is my experience:this is for the joystick sold at conrad (the cheapest one, ps2 style) pn: 425608open the four little brakets/legs in the bottom using a 1.5 mm flat screwdriver or similar, beware: only one chance, if you try to reopen the case again the legs will probably break.push the white plastic part apart from the metal case.inside the white part there is the black part, the spring is contained inside therethere are 4 rails where the inner black plastic part moves inside the white one, in between 2 of those rails you can see a little fissure, stick the screwdriver (you need a very small one) in that fissure and push, gently the black part out of the white part, probably you ll break, if a little bit, a little pin that keeps the black part from being thrown out by the springremove the spring and trim it so that it will be just about 5mm deep (about 1 and a half turn), this will keep the joystick free from autocentering but not wobblingput everything together, there you gosimone Quote
JMS Posted June 11, 2008 Report Posted June 11, 2008 i have a ton i mean ton of broken console controllers here. looks like a great idea for some knobs. the midibox is going to be fun! thanks TK and the rest of the midibox crew! Quote
JMS Posted June 15, 2008 Report Posted June 15, 2008 does anybody want some used ps2 or xbox or gamecube buttons/joysticks? i have a pair of ps2 joystick sitting around waiting for my midibox. i know the ps2 controllers have 2-10k pots and a switch all mounted in the assemblies. i can test the pots with my DMM to make sure they are good before i send a set out to whoever. Quote
lucem Posted August 24, 2008 Report Posted August 24, 2008 Reichelt got Joysticks (with switch), too, for everyone in or near Germany...Part number is RKJXP122002http://www.reichelt.de/?;ACTION=3;LA=3;GROUP=B254;GROUPID=3136;ARTICLE=73910;START=0;SORT=artnr;OFFSET=16;SID=29GTNDrawQAR0AAEzNeL8b818f36f83eb03fb3bd5a3134141b5ea Quote
cimo Posted August 24, 2008 Report Posted August 24, 2008 They are way cheaper at Conrad, not Alps though. Quote
