DavidBanner Posted May 8, 2006 Report Posted May 8, 2006 thanks thomas,I have a lights out, lights out 2000 and last out games on their way from ebay - all 3 for £1! now that is a proper deal if I've ever seen one... Quote
DavidBanner Posted May 9, 2006 Report Posted May 9, 2006 Lights out 2000 has red/green leds under each button!!!I'm well happy with my purchase, 3 different styles of buttons, 75 buttons in total Quote
dengel Posted May 9, 2006 Author Report Posted May 9, 2006 OK, I got my Lights Out today, and I have to hand it to Tiger - that's some quality construction The buttons are thick -and yes, very tall as mentioned by Th0mas! They have an excellent feel.To go more into detail, the PCB that the buttons sit on is a 5x5 matrix similar to that of a PC keyboard. If you need a 5x5 square, congratulations - you're done! Disconnect the key matrix board from the processor "game" board and go to town. The LEDs are all prewired and resistored.This doesn't hold true if you want to use the boards in other configurations than 5x5. Obviously, when you cut the board, the interconnections that lead to the matrix will be broken, and you'll have to wire the buttons individually. Each individual button is a square ring of contact traces, finger-jointed together with an LED in the center. These rings are all interconnected to each other, so if you are looking to use the original board it looks like there are a few things to do:1) scrape the traces away that connect the buttons, so each button is like an island unto itself.2) drill vias to the inside and outside of the rings, like so:...3) and solder some leads through the back to create the new button.4) You'll also need to attach leads to the red LED in the center, and add an inline resistor if you aren't using a DOUT module for lighting control. If you want, you can remove the LED and replace it with your own.This is of course the poor man's way - if you want, making your own PCBs would be a much better choice. Also, the height of the buttons will require the use of standoffs to push the buttons back from the board, so make sure you plan on that when mounting. Quote
stryd_one Posted May 10, 2006 Report Posted May 10, 2006 Hey Moderators... I'e noticed a few posts lately with that big gap at the bottom, is that a fault with the forum? Just bringing it to your attention, delete this post when you've seen it :) Quote
DavidBanner Posted May 10, 2006 Report Posted May 10, 2006 i want to use my buttons as individual buttons....do you think it's possible to cut the grid up and keep all the squares intact?I'm not so sure, I'm thinking I may have to lose half of em and cut down the middle of a row Quote
dengel Posted May 10, 2006 Author Report Posted May 10, 2006 With a dremel cutting disc and some patience you probably can keep that from happening. I just posted a board design for my buttons here - can you etch? If you can, I'll draw you a schematic + some cash in exchange for your services. Quote
DavidBanner Posted May 10, 2006 Report Posted May 10, 2006 hey D,would happily etch for free - but it's not one of my skills... Quote
docbrown Posted July 10, 2006 Report Posted July 10, 2006 I like to revive this thread because I'm curious about how the buttons really looks like. Anybody have an internal picture of this toy?thanks.. Quote
MRE Posted July 18, 2006 Report Posted July 18, 2006 hmm this now has me thinking about:Simon Says - only 4 color buttons, but there was an advanced version made by someone else that had 8Touch Screen Sudoku puzzle games - There are some nice blue backlight ones that are full graphic LCD screens with touch grids!Electronic Chess - would be an interesting visual live system of placing pieces (notes) on the board.. 8 X 8 so two together would be 8 X 16 Quote
th0mas Posted July 20, 2006 Report Posted July 20, 2006 baaahhahaha the electronic chess idea is golden. Imagine that as a pattern controller for a sequencer like seq24, glass peices with LED's underneath.. oh man. Quote
MRE Posted July 24, 2006 Report Posted July 24, 2006 yeah.. I was attempting to wrap my head around that..Sort of a chess battle, but you cant really play by standard rules.This excedes the capabilities of midibox without some added hardware and software but here was my idea:1:Each 'player' assigns their special pieces (knight, rook, king, queen, bishop) individual samples.2:pawns are assigned the basics of the song.. percussion.. and may be changed by software in order to keep the song going. So, software has final say so as to what that piece will represent based on the song.3:players take turns placing pieces. Two boards side by side would be 8 patterns by 16 notes right?The hard part is figuring out how to identify each piece. One way to pull it off would be to place an led on the bottom of each piece that has a unique frequency pulse. The board gets scanned and determines the piece and location by the pulse train. Quote
th0mas Posted July 25, 2006 Report Posted July 25, 2006 I was thinking more that each square was just a different button that you assigned to a different sample or pattern, and you didn't need to identify peices.But, if you want to identify peices, any electronic chess game you get is already doing so since well.. that's how it works. You'd have to reverse engineer how it's doing it but rest assured it's already possible on the board (how is another question) Quote
MRE Posted July 26, 2006 Report Posted July 26, 2006 Some may have patterns on the bottom that the board somehow recognizes, but for the most part, its done by tracking.Example:The machine knows that at the start of the game, that the corners are Rooks. By doing a scan (much like the button scan for MB) It knows that the pieces are there. Now, on your turn, if during a scan it detects that the piece has been picked up (was there, now its gone), It is assuming the piece is still a Rook. So, when you place it down again, it detects so on the following board scan. Again, it assumes that you put down the Rook. You could just as easilly put down a pawn and it would assume that piece is the Rook.If I remember right, most of those machines place small button magnets in the base of the pieces, and each square has a small coil under it acting as a hall effect sensor, and they are scanned as a matrix. The new ones (pretty plastic/glass) may be using infrared/optical stuff but its all the same.The REALLY cool ones used an X/Y sled with an electromagnet to move its own pieces around, and drag yours off the board when it takes your pieces. Some even moved your piece back rather than just an anoying buzz when you made an invalid move. Quote
MRE Posted July 26, 2006 Report Posted July 26, 2006 I was thinking more that each square was just a different button that you assigned to a different sample or pattern, and you didn't need to identify peices.But, if you want to identify peices, any electronic chess game you get is already doing so since well.. that's how it works. You'd have to reverse engineer how it's doing it but rest assured it's already possible on the board (how is another question)That would be a lot easier though wouldn't it? Placing a piece or removing it serves as the mute function or whatever.. Man.. a glass set with multicolor LEDs would just be sweet looking.. Quote
docbrown Posted July 26, 2006 Report Posted July 26, 2006 I was thinking more that each square was just a different button that you assigned to a different sample or pattern, and you didn't need to identify peices.Kind'a like a monome in color.. very cool.. 8) Quote
MRE Posted August 17, 2006 Report Posted August 17, 2006 http://www.kbtoys.com/genProduct.html/PID/4717118/ctid/17/INstock/Y/D/has a 1-9 number pad, 4 directional buttons (u,d,l,r) and 6 'mode' buttons.. not to mention the typical sudoku type display. (9x9 squares, in which a number from 0-9 can be written into each square).http://www.kbtoys.com/genProduct.html/PID/2724159/ctid/17/INstock/Y/D/apparently these have a motion sensor in them.. Quote
DrBunsen Posted December 14, 2006 Report Posted December 14, 2006 Leapfrog Learning DrumLetters and numbers etc. light up on top of drum each time you tap it. Mackenzie, Queensland, Australia, pickup only. But there surely will be others around Quote
