d2k Posted March 17, 2003 Report Posted March 17, 2003 Hi...Can peeps using the panasonic motor faders from allcorp gimme a few pointers with using them and tell weather or not they were able to make use of the touch sensor input capability on the core module...cheers...dan
LO Posted March 17, 2003 Report Posted March 17, 2003 I have not used the touch sensor on the core; but you can just connect up buttons for each fader and it will work the sameThe firmware has a built in touch sensor ie when the fader is moved by hand for some milli seconds the fader is disengagedIm just about to get in to using my faders seriously as my case is complete now!!!!!!! just finishing the graphicsFor me this method is much better as I cannot afford ALPS faders.=LO=
Steven_C Posted March 18, 2003 Report Posted March 18, 2003 Go the panasonics go! (I'm waiting for mine to arrive!) ;D
d2k Posted March 18, 2003 Author Report Posted March 18, 2003 Hi Lo...but you can just connect up buttons for each fader and it will work the same...Not sure i quite get this, do you mean u just assign a regular button as touch sensor? and press that to disengage the motor? But u say the f/w already takes care of this when u move a fader...hmmmmmMebbe i wont bother with it, what's the benefit of it nehow...?TaDan
Guest Perka Posted March 18, 2003 Report Posted March 18, 2003 Does anybody know if it is possible to buy the panasonic faders somewhere in Europe, and not from the US?/P
LO Posted March 18, 2003 Report Posted March 18, 2003 "but you can just connect up buttons for each fader and it will work the same... "Im fairly sure that "T" said this was possible??!!But like I say Im yet to get serious with them!Might have to switch to the MIOS MF as it has a calibration menu by the sounds of it.im a bit scared of this whole [glow=red,2,300]MIOS[/glow] thing to tell the truth! :o
d2k Posted March 18, 2003 Author Report Posted March 18, 2003 hehe, me too LO... :PI did get the new MIOS runnin fine on the quad SID i'm doing - and it really behaves and looks like an OS, complete with reboot messages ;). It's just all the files with funny extentions and all that coding that scares me... :o
Ian_Hurlock Posted March 19, 2003 Report Posted March 19, 2003 There is a diagram that relates to the fader takeover button thingy on the site somewhere ;DIan
d2k Posted March 19, 2003 Author Report Posted March 19, 2003 Hey Ian...Yeah, i remember seeing that pdf u talk of before the site got re-jigged, since then i havnt seen it - still none the wiser on the subject tho...TaDan
d2k Posted March 19, 2003 Author Report Posted March 19, 2003 :) okay, musta saved that pdf a while back cos i just found it on me HD, i put it here (T, dunno if u need/have a backup of it already but u cudnt see it on the site so just grab this copy if need be) http://www.notapplicable.co.uk/mbhp/mbhp_din_touchsensors.pdfSo, what do the pink dots represent in that pic? Which pin of the motorfader?AdiosDan
LO Posted March 19, 2003 Report Posted March 19, 2003 hiYou can only attach them to the MF's if you have touch sensor tracks.otherwise I guess you can attach thumbtacks? I dont know the meaning of this! standard buttons is what I took it to mean.LO
Ian_Hurlock Posted March 20, 2003 Report Posted March 20, 2003 They are just momentary's.That's all the switch on the touch sensor of a touch sensitive fader is.Use the same buttons as you have used elsewhere on your panel or woteverian
TK. Posted March 20, 2003 Report Posted March 20, 2003 Now this issue has been discussed here:http://www.midibox.org/cgi-bin/yabb/YaBB.cgi?board=concepts;action=display;num=1048075587Best Regards, Thorsten.
Guest altech Posted March 21, 2003 Report Posted March 21, 2003 Where I can to buy Panasonic fader even so ???!In Germany, for example? Also, I try to find circular LCD matrix or scale, who know where to find that /in Germany for ex./Can I to use for a Jog/Shattle function ALPS encoder SRGP series, 10 pulses?BR Albert >
Dimitris_FX_freak Posted March 22, 2003 Report Posted March 22, 2003 After some research on Panasonic faders i come up with: http://www.panasonic.com/industrial/components/potentiometers.htmCheck the Slide Potentiometers/EVA(B)NL/EVA(B)NC which offer: Compact and 3-track version available — servo, touch sensor and audio. The only thing is that I cant find them anywhere in Europe so if anyone knows a Panasonic dealer who can do less than 10 pieces I would like to make an order :)Regards DimitrisPS. STOP WAR make music :-/
Guest altech Posted March 23, 2003 Report Posted March 23, 2003 Hey, Dimitris...Big thanks for reply! and what talk about circular LCD scale and ALPS Jog/Shuttle/Scrab encoder, 10 pulses?BR Albert >
