bill Posted July 12, 2006 Report Posted July 12, 2006 Hello,Is there a documented, or standardised way to connect one 7Seg Display (common cathode) to one 74HC595.(No multiplexing)My question is about Pin reference, so the code i'm going to do could be reused.(Using MIOS_DOUT_SRSet)If no one knows, i will connect that way :Q0 -> A Q1 -> B Q2 -> C Q3 -> D Q4 -> E Q5 -> F Q6 -> G Q7 -> DotPLease tell me what you think :) Quote
TK. Posted July 12, 2006 Report Posted July 12, 2006 See mm_leddigits.c of the MIDIbox MM application (non multiplexed)Best Regards, Thorsten. Quote
Jidis Posted July 13, 2006 Report Posted July 13, 2006 Bill,Keep in mind the actual part pinning varies from brand to brand. I've learned the hard way on the duals. I've got at least two different pinnings of common anode dual digit here.I'd like to see what you're doing with them regardless. I like those things. :DGeorge Quote
bill Posted July 13, 2006 Author Report Posted July 13, 2006 Thanks,for those who wonder, here is the pin order i found in mm_leddigits.c // a // --- // ! ! // f! g !b // --- // ! ! // e! !c // --- // d h // pin order : habcdefg (from pin0 to pin 7) Finaly, i decided not to use this non multiplexed mode, because over 2 chars, it's a waste of hardware, and for the comfort, i think 3 digits is a minimum to display a 7bit value in decimal, and it could be very nice to display two of those values for ex : c032 127 (i send a CC032 value 127)So, i plan to work on the Midimon Mtc display, (so hardware plans allready exists!), and i have informations in the leddigits.inc file :)http://www.midibox.org/forum/index.php?topic=7156.msg46782#msg46782 Quote
bill Posted December 8, 2014 Author Report Posted December 8, 2014 8 years later... I found that this thing save money and soldering time : http://www.dx.com/p/diy8-x-seven-segment-displays-module-for-arduino-595-driver-250813 Quote
