It's not,I still get the same 9.05 volts?
Sounds like you stuffed the 7809 instead of the 7812. Measure the DC voltage on the input leg of you regulator vs the output (they are the outside legs)
I'm faily sure I did not use the 8580 parts,I just got another 12v ac,I will test,test regulator,outer legs I will check after rectifier also.. I will have more info to figure this out in next post..
back to the lab! 8)
hold on a minute, are you reading the 9.05 volts after the regulator, or directly after the rectifier? is it a 7809? if so, that could be your problem. the optimised psu only works that way because it uses the 5v ground from the c64psu for the 9VDC as well, which gives a total of 14VDC.
Yes it is the 7809a should I replace with the7812a,,
? 7809a is only for c64psu?
incase thats not the problem.before rectifier 16v after Vr it's 9.05
I'm going to repalce the VR's now and retest..
I think Mr modnaR you have figured problem! :D Keep ya updated
I was wondering why there were 2 voltage regulators?
Thanks again everyone for your help.
mr modnaR you were correct!  ::)
12 volts right on the nose!
SWEET!!! thanks alot!!!
now to upload mios ? ?(shitty computer)Wire up buttons encoder and put into case..
STELLER!!!
so stoked! the small 12v ac will work!(and take little space in case)
So I'm all good to put in pics?
Great! ! thanks again
Thai
I have pics of case in another thread,Will add more soon,Hope to have better internet connction in near future.
Having a little trouble with lcd,Checking wiring.. ???
got to do some reading..
thanks!
:D
Yes i have some problems with lcd,Showing only row of blocks? not sure about connector?
lcd is from smash tv....rewired still blocks . . will 16 pin connectors on each end normal work?
one end has 16 pin? other soddered to pins.. . confused ???
:D Ya I just read that.. Now how to load mios (basic,6 buttons and encoder)
on the search,, this is the part I worried about (very crappy computer win 98 haven't used midi on computer before,got the cable) just need the link...
thanks cause theres alot of info I could have missed that..i thought It was suposed to say ready?
thanks was just reading that,Dont have cable for this computer,
So I was hoping to get mios studio going on the other..
downloaded online versions,got to get offline version.
think I got the Idea,Now looking for midi wiring,,
off to search,,
Thanks for the helping hand..good to know there are a few
people there to help me along,,please excuse the newbi ness
reading at friends taking info home by disks/head (moving info hasn't been going so well) Cause my computers old.(process of getting new one)
Ramble ramble
thanks :D
waiting...? ?
starting upload of bootloader_v1_2pic8f452.hex
hex file contains code in mios range.
forcing reboot!
how long should it take? Am I on the right track here?
??? wating to see if some thing happens or should I press stop.reset core?
did you get the pics from smashtv? if so, did you ask for them to be pre loaded with the boot loader? if so, you don't need to upload the bootloader again!  ;D
Yes I got the kits from smash (AWSOME SERVICE)
Hope they have bootloader..
Loading mios? system resets ?
been going for hours?
will it show something eles?
ahhh confused.. ???
forcing reboot!
If you already have the bootloader on the PIC you must not load the file bootloader_v1_2pic8f452.hex !
If you want to load MIOS on a preburned PIC you'll  have to load mios_v1_9c_pic18f452.hex
(Read the README in the folder mios_update_v1_9c).
And please don't forget: You have to start the upload of MIOS within the first two seconds after power on the CORE! So .... be quick!
greets
DOC
Oh thanks,,Nice the meet you!
When exstracting(unzipping) mios pack,It didn't work properly
Left on only a few seconds..
Loading right one now..as desribed above
theres a list of system resets
and a active sensing?
Is it suposed to be doing this,I have another pic here..
How long should mios take with a very shitty computer?
thanks for your help!
Hi again,
I think, you write faster than I think ... Let me try to sort it:
What do you mean? Do you mean you are unable to extract the mios .zip file after download?  ???
You'll need the described .hex files. Otherweise what will you send to the pic? ???
Please be a little exacter!
Where are system resets (your PC, MIOS studio, Core or what) ??
Also
Where do read active sensing: In the Midi Monitor of MIOS studio, on the lcd or where?
If it's a shitty but not faulty computer it should take less than a minute (normally a few seconds). BTW the upload speed didn't depend very much on the computer speed. (midi is midi is midi ... ::) )
Another hint before you try to Upload:
Have you already read the Midi Troubleshooting at http://www.ucapps.de/howto_debug_midi.html ?
You should take the time to test your equipement with this guide. After finishing all the suggested steps you should have a verified midi connection between the core and your computer.
Finally:
I think, I speek for the community when I tell you: Please be so kind and ask questions with a little more describing words around your problem. Nobody can give an exact advise if you just smash word fragments in your posts.  ;D
greets
DOC
Very sorry for not fully describing,,
Must not have unzipped properly when first downloading  mios
tried uploading hex file,,when I realized it was wrong,it was bootloader,stopped and reaxtracted
and uploaded v_1_9...tried to upload..left for hours..in monitor,
in mois studio(not lcd)
monitior in says: #' ms [ff] system reset
did say in monitor out  #'s timestamp (unkown) 1 system message fo oo oo 7e 40 02 00 00 00 00 f7
getting many lines ot #'s (ff) system resets,and#" (fe) active sensing,plus underfined?
in monitor in
Sorry net limited
not sure what to do been reading over midi trobleshooting?
going over how to debug..
Sorry for my unclarity..
And thank ya'll for your help..
in the mios studio monitor in, it's:
00000000087386 ms / [FF] system reset
mios studio output when trying to upload is:
timestamp [unknown] sysex message: f0 00 00 7e 40 02 00 00 00 f7
I have another pic(chip) if I messed up first,with bad exstraction
limited net (waiting on new computer) maybe help by phone? pm
Thank you
Tyler
