matrigs Posted November 12, 2006 Report Posted November 12, 2006 i don't get it - i connected 3 pots 10k linear to my ain module and none of the pots ever reached value 127, stopping at about 123. i used the most cheap pots but i guess that shouldn't happen anyway?bad soldering doesn't come to mind - i checked everything a few times.
matrigs Posted November 12, 2006 Author Report Posted November 12, 2006 okay i got it - i soldered the ain module wrong by putting the bypass caps between the output of every chip and the connector to the core module...if i could suggest maybe a few small improvements to the ucapps site? those pictures how to solder the ain module could be clickable and bigger - my mistake was caused by them and maybe a few else people might get confused by them? i could even make those bigger pics with my digital cam. oh and there is a mistak on the ain site - there is written that you should solder the bypass cap between VSS and ground but in the pdf it's VDD and ground - that was my second failure....cheers !
doc Posted November 12, 2006 Report Posted November 12, 2006 oh and there is a mistak on the ain site - there is written that you should solder the bypass cap between VSS and ground but in the pdf it's VDD and ground - that was my second failure....... VSS is ground. Would make no sense to connect it from ground to ground ;DgreetsDoc
matrigs Posted November 12, 2006 Author Report Posted November 12, 2006 everything is possible for a noob :>why couldn't they call it just ground instead of VSS ? :Dokay the most important thing is that i made it. maybe i could make a tutorial for wiki on this ?cheers.
TK. Posted November 12, 2006 Report Posted November 12, 2006 I've fixed the typo.Yes, a tutorial in the wiki is always welcome! :)I would add a link from the MBHP_AIN to this tutorial thereafterBest Regards, Thorsten.
